11-12-2018, 02:36 PM | #1 |
852
Rep 818
3.75" Slip-On Exhaust Tips for F85 - DIY
I wanted to share a simple yet inexpensive DIY upgrade for those who didn’t want to purchase an exhaust system, yet are looking for an overall stealthier look or simply wanting to match the remaining blacked out trim. p.s. This is my wife’s daily and she definitely didn’t want anything loud as she feel it’s a bit loud already. (I have exhaust valve mod). I went to the muffler shop as I wanted to raise the car on the lift making it easier to install but this can totally be done from the floor..
I bought the 3.75” slip-on tips from Burger tuning. They are currently on sale until they sell off the remaining inventory (see link below).. I do not think they will carry these afterwards so you may want to get yours ASAP if you’re interested in doing this mod. They don’t have black in stock so, only chrome or burned blue. You can get either one and powdercoat them black. I had mine done in satin black ($44). Prior to install, you need to cut off a small section of each tab which holds the tips in place. Each tip I believe has 5 tabs inside. I used simple metal cutters to do this. Get a pair of gloves and muscle these tips over your stock tips.. you may need to use decent amount of force to slap them on there so get a pair of thick gloves and give each tip several whacks to jam them on there (literally). Once installed, they will not be coming off again. For lease owners I’m sure BMW will not mind having it return with this, look 10X better than competition tips which came on my F10 M5. http://www.burgertuning.com/exhaust_...M3_M4_BMW.html Last edited by hybrid_eg; 11-12-2018 at 06:35 PM.. |
12-01-2018, 12:05 PM | #3 |
Rep 9
Do you have any pictures of the inside of the tips? I'm guessing the tabs are there to keep them installed. Why did you have to cut the tips of the tabs off? Did you do that to all of the tabs?
Thanks! |
12-03-2018, 05:37 PM | #4 |
852
Rep 818
yes each tip has 5 tabs i believe.. each tab needs to be cut otherwise it wont fit.. keep in mind these tips are not designed for F85 but for F80 instead hence the slight modification..
12-03-2018, 08:28 PM | #5 |
8
Rep 31
looks great, i took a gamble and ordered the carbon fiber ones that have a exhaust manufacturing stamped on them,
Didnt realize they made replica exhaust.. seller from China oebay.. i have had for a over a month and couldn't be happier.. solid tips and $35 bucks each. I'm actually ordering the next size up.. Trying to figure out how to add photos ? |
12-04-2018, 07:28 AM | #6 | |
94
Rep 239
12-09-2018, 03:15 PM | #7 |
792
Rep 3,151
Nice DIY. I wonder if they'll fit the E70 X5M.
Current Mods:
2004 E46 M3cs JB/CSL 2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black IG: @060Motorsports |
01-05-2019, 04:11 AM | #9 |
4442
Rep 5,733
Drives: '24 iX50; '23 i4 M50
Looks good. Any reason why you went with chrome, when the same as stock? Visually are they that much larger or are you experiencing the same discoloration as me?
https://f15.bimmerpost.com/forums/sh...t=exhaust+tips Dealer is fine with replacing my entire exhaust under warranty (tips are not replaceable), but seems like a waste when it's just the driver-side tips. And I like to avoid service as much as possible due to potential for other problems.
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
01-05-2019, 08:39 AM | #10 | |
660
Rep 120
Kief4441.50 |
01-06-2019, 12:25 AM | #11 |
792
Rep 3,151
Gentlemen, Why is there such a huge FUGLY gap between the top of your tips and your diffusers...
Current Mods:
01-08-2019, 01:27 PM | #12 |
852
Rep 818
its how the OEM tips are positioned.. my diffuser is factory while EricU is aftermarket however same concept regarding their position.
I believe OEM tips are positioned a bit down because the OEM heatshield is very close to exhaust piping where the OEM tips begin. Even when adding burger tips i would recommend before installing them to bend the heat shield a bit upward to prevent it from coming in contact with the BMS tip since clearance is going to be even closer now than with OEM tips. Why did BMW design it this way? Well that's a questions i'm unable to answer. We are posting a cheap solution to enlarge your tips and enhance looks for close to nothing cost $ wise especially for those who do not want to have an aftermarket exhaust system on a family SUV. |
EricU660.00 0-60Motorsports792.00 |
01-08-2019, 02:37 PM | #13 |
23
Rep 62
This was a good deal but I only just saw the thread and only the burnt blue/chrome tips are available. If anyone bought matte/gloss black and isn't using them message me.
01-08-2019, 05:15 PM | #14 |
852
Rep 818
you didn't read the thread.. buy whatever color they have left and take it to any powdercoater to coat it satin black.. that's what i did.. they should not charge you more than $60 bucks to coat all 4.
01-11-2019, 09:53 PM | #15 | |
150
Rep 198
01-12-2019, 02:21 PM | #16 |
660
Rep 120
12-12-2021, 08:05 PM | #17 |
Rep 9
If anyone is looking for a set of these exhaust tips let me know. I have a brand new, never used set in chrome. Could be easily powder coated black or to any color you like. Thanks - Kyle
07-13-2022, 11:00 AM | #18 | |
208
Rep 1,557
Drives: F10 M5 & F85 X5M
AW F10 ///M5 AW F85 X5///M BootMode3 STG 2///Project-Gamma Intakes///ActiveAutowerke DPs///Maxton-Design Body Kit @MeisterAutosport @RatedMClub @RatedMRally |
07-13-2022, 04:19 PM | #19 | |
689
Rep 2,717
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
Now stock exhaust tips spreads and it ends at the very end of the tip It’s 60mm at the beginning of the tip.
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
07-13-2022, 07:53 PM | #20 | ||
Rep 27
07-14-2022, 09:55 AM | #21 | |
208
Rep 1,557
07-15-2022, 12:45 PM | #22 | |
689
Rep 2,717
Drives: M3
