02-14-2019, 04:44 AM | #23 | |
325
Rep 519
2nd the MPE can pass as a stock exhaust. If I get pulled over I can just say nope it's stock look at the logo. Hard to do when you have an Akra logo on your tips. We have an obsessed cop around my parts that will ticket you for everything he can come up with. Im trying to avoid this guy as much as possible Heck there is even a "spotted" page created just for him on Facebook. |
02-17-2019, 02:28 PM | #25 |
123
Rep 353
Thanks would appreciate it. Hoping it clears the 70mm outlet of the exhaust pipe. I think if it's in the 72-74mm we're golden, and if bigger than that, some welding will do the trick.
02-17-2019, 05:13 PM | #26 |
199
Rep 292
$1180 just for the tips, I just ordered a set, First Costly Mod.
2019 MBB/Aragon M5C M Performance: Exhaust Tips/Pro Spoiler/Rear Diffuser. H&R 11/11 Spacers ACG Carbon Kevlar Pads XPEL Front PPF Ceramic Pro Silver 20% Tints Instagram #m5comp Last edited by MCOMP; 02-18-2019 at 07:34 AM.. |
02-17-2019, 05:19 PM | #28 |
199
Rep 292
2019 MBB/Aragon M5C M Performance: Exhaust Tips/Pro Spoiler/Rear Diffuser. H&R 11/11 Spacers ACG Carbon Kevlar Pads XPEL Front PPF Ceramic Pro Silver 20% Tints Instagram #m5comp |
02-17-2019, 05:59 PM | #30 |
199
Rep 292
Will do, I reached out to Vendor for fitment verification, waiting for response.Worse comes to worse I'll have them welded on or something as I love the look but am happy with Sport exhaust just not the sport tips.
2019 MBB/Aragon M5C M Performance: Exhaust Tips/Pro Spoiler/Rear Diffuser. H&R 11/11 Spacers ACG Carbon Kevlar Pads XPEL Front PPF Ceramic Pro Silver 20% Tints Instagram #m5comp Last edited by MCOMP; 02-19-2019 at 03:25 PM.. |
02-17-2019, 06:27 PM | #31 | |
472
Rep 888
Drives: 2019 M550i
02-17-2019, 06:35 PM | #32 |
292
Rep 605
If you go to the shop BMW website on your mobile device and look at M performance parts, you will see it listed for about $728. For some reason on the desktop site, it doesn't separate the main exhaust system from the tips, which are separate part numbers.
02-18-2019, 07:20 AM | #33 |
194
Rep 459
Keep us posted on fitment...
https://www.getbmwparts.com/oem-part...2456072?c=az0x I ordered the Mperf carbon replica tips to compare https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2019 F90 M5 Comp-Marina Bay Blue-B&W,HRE 21" FF04,BMC,CarbonPro wing,H&R,ZW5
2017 BMW 330i - Estoril Blue - M Sport Package 2013 Lamborghini Aventador-Pearl Green-Modified 2004 Lamborghini Gallardo-Manual 6spd -Giallo Midas Pearl Yellow-Modified 2018 Range Rover Velar S-White Last edited by Steeve19M5CP; 02-19-2019 at 05:56 PM.. |
02-18-2019, 09:20 AM | #34 |
199
Rep 292
I'm convinced the stock exhaust ends that hold the tips will have to be modified because I do not see a notch in the Performance Tip to accommodate the pins that align the tip. It will have to be cut off, Im sure any Exhaust shop will get them on for me.
2019 MBB/Aragon M5C M Performance: Exhaust Tips/Pro Spoiler/Rear Diffuser. H&R 11/11 Spacers ACG Carbon Kevlar Pads XPEL Front PPF Ceramic Pro Silver 20% Tints Instagram #m5comp Last edited by MCOMP; 02-19-2019 at 05:22 PM.. |
02-18-2019, 10:58 AM | #35 | |
194
Rep 459
2017 BMW 330i - Estoril Blue - M Sport Package 2013 Lamborghini Aventador-Pearl Green-Modified 2004 Lamborghini Gallardo-Manual 6spd -Giallo Midas Pearl Yellow-Modified 2018 Range Rover Velar S-White |
02-18-2019, 12:26 PM | #36 |
292
Rep 605
I have a measurement caliper on the way. Do you guys want diameter of the outlet pipes in mm? I must say, the finish of these tips is impressive. I must admit, though, I did not put the tips on my MPE myself, so I have no idea how much clearance they have before bolting them down.
02-18-2019, 07:45 PM | #37 | |
123
Rep 353
So the replica (that you bought) and real M performance tips (from the past) have 70mm inlets, the new F90 M5 exhaust has a 70mm outlet, so they aren't compatible unless you chop off part of the exhaust outlet pipe and weld it directly on which is incredibly difficult to get exactly right. They can't slide over each other at all. I'm hoping that the new MPerformance exhaust tips released for the F90 M5 are bigger than 70mm. That's what we need to find out. If the inlet for the tips is 72mm or bigger we're golden. |
02-18-2019, 07:46 PM | #38 | |
123
Rep 353
02-18-2019, 10:17 PM | #40 |
292
Rep 605
If the outlet is 70, and the new tips slide on and then get bolted down with a circumferential clamp, wouldn't the inlet have to be at least 72mm to slide on? Maybe not, I guess 71 might give enough clearance. Either way, I'll find out once the calipers arrive.
02-18-2019, 11:23 PM | #41 | ||
123
Rep 353
02-19-2019, 12:30 PM | #42 |
852
Rep 818
I've already posted this in the past, on both non-CP and CP F90, exhaust piping (after you remove the stock tips) isnt the same size throughout.
To fit aftermarket tips which typically have clamp and bolt hardware you will likely need to chop off the factory centering pins. In addition, factory exhaust piping is larger after the centering pins 75mm and its 70 behind the centering pins. See pic. All i'm saying depending on aftermarket tip you buy and its lenghth you may not be able to bolt it up unless you go to muffler shop and have the exit pipes adjusted to correct size.. i simply didnt want to go that route and its only a matter of time before someone makes bolt on tips using factory exhaust center pins for plug and play affair. |
02-19-2019, 04:13 PM | #43 |
292
Rep 605
That's great info. I knew the pins would have to be severed off and the stump ground down flush with the pipe, but I suppose most people could do that with a hack saw/reciprocating saw and a Dremel grinder. I guess all that's left is for me to measure the inlet diameter of the M performance tips for these guys.
MCOMP199.00 |
02-19-2019, 05:47 PM | #44 | |
194
Rep 459
