Rear tires middle section wearing faster
11-13-2014, 03:28 PM | #23 | |
30
Rep 285
And soft ride and not sharp when turning or lane changes. Spongy feel. I can feel the tires "dragging" a lot more. You'll lose a lot of performance edge because of this problems. The overall feeling I get is "cheap tires" driving with low pressures. It's acts like a tired mule... I might have to go lower psi to compensate for middle section worn and let the sides do more work...like 32psi. I'm not looking forward to it at all... |
11-13-2014, 03:40 PM | #24 | |
30
Rep 285
So I started out with 38 and saw middle noticeably wearing faster. So went to 36, nothing I noticed in change. Went back to 38.... So back down to 35. Again nothing I noticed. Now I'm on 34psi. Mind you I had Michelin PS2 ZP tires before these set and they wore lovely evenly. I don't check treads that often as I do with A/S 3s. |
11-13-2014, 03:58 PM | #26 |
25
Rep 159
Lol, he's running a 10" tire on a 9.5" rim and no one thinks that's the cause of the issue?
BMW always puts narrow tires on their vehicles for performance purposes. Unfortunately, that's not a good combo for tread wear. If you were on a corvette/camaro website, people would be recommending you put 315 tread width tires on your car. Short answer: your rims are too wide and/or your tires are too narrow. |
11-13-2014, 04:16 PM | #27 | |
30
Rep 285
I'm not sure if I understand you about BMW performance = narrow tires. Anyhow, I'm running 9.5" VMR VB3 wheels. |
11-13-2014, 04:20 PM | #28 |
30
Rep 285
11-13-2014, 07:33 PM | #29 | |
1208
Rep 2,835
The 255 General's I had were great on the rear. I wanted to go square with them by buying 2 more. Unfortunately, General stopped making them saying there wasn't enough demand. I hunted for months hoping to find someone who had 2, never did find any. But I kind of wondered if what went wrong was because the 255's were made in Brazil and the 225's were made in Mexico..... |
03-07-2021, 11:35 AM | #30 |
Rep 6
I know this thread is old but, I have the same problem so here is my three cents worth.
I have a plain-Jane 328i RWD, originally 205 55R16. Maybe for 9 years I ran RFT tires winter and summer and never had uneven wear. Then, I got a 17'' rims and Michelin Pilot Super Sport tires 225 45R17, which are, of course, non-RFT. I rotated them as I did the RFT tires before every season. The uneven wear was evident after one summer on the rears. I noticed that the Pilots run very hot compared to the other tires I had. All that stickiness generates a lot of heat so I am doubtful that the discussion on what to inflate them to is going to be productive. They will get a lot of pressure inside just from rubbing the road. By the way, I got the wheels aligned when I put the Michelins on. Personally, I suspect that the RFT characteristic has something to do with the wear pattern too. E90 is designed for RFT. When I switched my winters to non-RFT the car became more bouncy, granted on the stock 205 55R16. Still, it was noticeable and even that winter tire has a very mild increased wear around the middle. So, my next tires, for better or worse, are going to be RFT. |
03-07-2021, 12:58 PM | #31 | |
30
Rep 285
I've recently switched the rears to Falken Pro G5 Sport A/S 255x18. It is wearing evenly, except the inner side wear faster and that's normal with bit of camber on -2 deg. On unrelated issue, these Falken Pro G5 Sport A/S were very scary to drive as they were NERVOUS rearend twitching as if REAR WHEEL STEERING on its own. I later dropped the pressure from stock 39psi to 33psi and now all good. That's a lot of drop. I asked Discount Tires about this and they never heard of such issues. Thanks for your .03. |
