Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions LCI Shifter Retrofit?
      07-14-2023, 08:10 AM   #45
Jnasratyar
Jnasratyar's Avatar
Drives: 2023 BMW M340i
2023 BMW M340i  [9.87]
Originally Posted by B58-M340iX View Post
https://www.facebook.com/groups/g20m340i/permalink/2014597062264261/
Dude, how you get in the group. I’ve been trying to join since I saw you say someone put the pre lci shifter in the lci, but they keep rejecting my ass 😭
      07-14-2023, 09:55 AM   #46
bimmerstar
bimmerstar's Avatar
Drives: 2020 BMW M340xi
if anyone wants this nugget shifter, its perfect condition. no longer need. will be up on ebay soon. perfect condition, no scratches. ran in my 2020 m340. 450 shipped with idrive controller, 275 shipped without i drive.
2024 G87 Zandvoort Blue M2 w/ Buckets - Stock 93| 0-60 TBD | 1/4 TBD | 60-130 TBD
2020 G20 Tanzanite Blue II M340 xDrive - E30 BM3| 0-60 3.28 | 1/4 11.39@123 | 60-130 9.56
Past:
2017 W205 Black C43 AMG - E40 FBO No Turbo | 0-60 3.21 | 1/4 11.18@124 | 60-130 9.17
pej744593.00
      07-19-2023, 01:41 PM   #47
JackMK
JackMK's Avatar
Drives: 2023 m340i X 2023 G87 M2
Originally Posted by bimmerstar View Post
Just an update, I finally had a chance to install the LCI shifter into my pre LCI 2020 M340. I can confirm it works! I love it. No longer have the useless shifter knob in the way to block my hand from easily selecting the surround view, traction buttons or parking. Also no need to press unlock button when doing y turns from reverse to drive etc. As mentioned above the trans software needs to be updated as I can not shift into "S" mode. I will need to figure out how to do that. larrylam646 any information on how you upgraded trans software so the s mode works?
My m340 is fully loaded so I had to purchase a shifter from Europe that had all the buttons and I still care about the engine start stop button
what aftermarket LED strips are those
      07-20-2023, 05:32 AM   #48
Pdxordts
Pdxordts's Avatar
9
Drives: BMW G29
2020 BMW Z4  [0.00]
Found this at eBay Fit perfectly. No coding necessary. Thanks for all the help
pej744593.00
      07-21-2023, 09:44 PM   #49
bimmerstar
bimmerstar's Avatar
They are from IAW.
https://infiniteautowerks.com/shop/i...ient-lighting/
Past:
      07-22-2023, 12:02 PM   #50
JackMK
JackMK's Avatar
Originally Posted by mlurker View Post
Any way to do the opposite - replace LCI with pre-LCI?
Yes it is possible, plug and play actually. Many people have done it and I’d be happy to direct you to the Facebook group for more info where I found this info out
      08-02-2023, 11:22 AM   #51
Jnasratyar
Jnasratyar's Avatar
Just did the opposite swap, swapped LCI for pre LCI, I have the LCI unit for sale if anyone’s interested. Listed in the interior parts classified.
pej744593.00
      08-02-2023, 12:02 PM   #52
ramparts
1135
Drives: M40i
You are going to need that.
If you ever need work on the car done, it will be impossible for BMW to program it
      08-02-2023, 01:33 PM   #53
Jnasratyar
Jnasratyar's Avatar
Wdym?
      08-02-2023, 01:38 PM   #54
ramparts
1135
Drives: M40i
ISTA does a calculation of vehicle parts based on your build date and factory order.
They shifter is out of scope, as it’s been replaced, which means they will not be able to program the car.
So say for example , your body domain controller, or your ecu or camera, or anything breaks ( it’s REALLY common) , and needs fixing, they won’t be able to without replacing the shifter first.
Better to hold on to it, and swap it back before any work.
You will also have issues selling the car too
Appreciate 2
PJ///M78.50
      08-04-2023, 10:45 AM   #55
Jnasratyar
Jnasratyar's Avatar
Ahhhhh, I see. Good to know, thank you.
      10-09-2023, 04:48 PM   #56
StraightG
Drives: R56 Mini, MazdaSpeed6
JackMK, would very much appreciate more information on this, I want to buy a new M340 but I can't live without center shifter because I steer with left hand and shift with right. I'm only getting an automatic because manual is not available.
Feel free to PM me, I can't initiate PM because I am new to forum.
      11-08-2023, 09:43 AM   #57
g2179
Drives: G21 330d
Hey,
could someone please share the part number of this gear selector but as the LCI version?
It should have the buttons as in the attached image, but not be the glossy variant
Also regarding the software issues, can someone confirm that that is in fact an issue for retrofitting the LCI model to a pre-LCI car?
      11-08-2023, 10:22 AM   #58
ramparts
1135
Drives: M40i
Originally Posted by g2179 View Post
Hey,
There is no adaptive button on the LCI version, so you lose the ability to press that button !
      11-08-2023, 02:11 PM   #59
g2179
Drives: G21 330d
@ramparts Just a few posts above there is a picture of one having the adaptive button?
Do you know if there is really a problem software wise when going to the BMW repair shop?
      11-09-2023, 12:40 AM   #60
ramparts
1135
Drives: M40i
This is the shifter for the g20. No adaptive button and it’s not gloss black.
That shifter posted is for a different gXX car. It’s possible to retrofit both, but as the HWEL ( hardware version ) is for a different platform, it’s going to be more involved flashing it then simply changing your manufacture date. You’ll need a donor FA similar to whatever car it came from and then just flash that module.
      11-09-2023, 02:25 AM   #61
g2179
Drives: G21 330d
Hm okay, so basically I would forever lose the possibility to use the "adaptive" mode? Not sure what it does anyways, so I don't think I would miss it
Could you explain the software difference a bit more please? If I choose the G20 version, would that mean it's working out of the box and NO problems at the BMW repair shop, whereas if I chose the other car's part with the adaptive button it would result in problems?
      11-14-2023, 07:39 AM   #62
g2179
Drives: G21 330d
ramparts I built the device into my car and it works perfectly out of the box... So I think I should be good
      11-15-2023, 02:56 AM   #63
Sierra055
296
Drives: 2023 G80 M3 SSG, 2021 Audi SQ7
I've got a RHD pre-LCI shifter for sale in the classifieds section, perfect condition if anyone is interested. It's located in Australia, but I could arrange shipping internationally at cost.
https://g20.bimmerpost.com/forums/sh....php?t=2058088
      12-23-2023, 06:24 AM   #64
PJ///M
PJ///M's Avatar
Drives: 2024 BMW X5 G05 LCI
2024 X5 G05 LCI  [0.00]
LCI to Pre-LCI
Anyone have updates on reverting back from LCI shifter paddle to Pre LCI shifter handle? Leasing 2024 X5 and wanting to switch back to handle. I would assume they make some sort of handle that would fit/clamp over the paddle but I’m new to it all. Also new to the site and forums.
I found a dealer online with a 300.00. 4 piece crystal handle/adapter/knob/start stop button. He says it doesn’t need coding and it’s the only thing I can find online to switch back.
Any help would be appreciated!
Below is a pic of my gear selector module.
      01-31-2024, 01:57 PM   #65
Yoram57
Drives: BMW g20 330e (2020)
Hello,
I’m new to the forum. Been driving a 2020 g20 330e for the past 3 years and 50K km, with great pleasure.
I bought and retrofitted a used LCI shifter. It was plug and play and all functions work properly, except S-mode.
Has anyone managed to get S-mode working on a retrofitted LCI shifter? I would like to know what coding/flash is needed. Any help is appreciated!
      02-09-2024, 01:54 PM   #66
drac
Drives: M2C|340|M340
If anyone wants my LCI shifter and wants to trade for their Pre-LCI shifter lmk!
DM me here or on IG @ g20adi
g20
