09-30-2022, 09:11 AM | #1 |
50
Rep 103
Tire pressures?
Hello,
Since the weather got cooler, my 21 M5 is saying my tires need more pressure. Looks like the computer wants 38 psi front and 39 psi rear. This is odd to me as the door sill sticker says 32/33. These are Michelin pilot sport 4s 275/285. Is the computer correct in wanting 38/39? Is this because of temperature change? Thanks, FS |
09-30-2022, 09:42 AM | #2 |
5234
Rep 10,615
At 38/39 psi, the center of my rear tires wears more than the edges. That is usually a sign of overinflation. Has anyone else seen this? I run more like 33/34, which is the light load comfort setting.
09-30-2022, 09:58 AM | #4 |
309
Rep 205
Here's some info from my '23 owner's manual. Depending on the speeds (up to 100 mph or over 100 mph) that you will be driving and whether you have the M 'Drive package, will depend on what psi to set your tires.
09-30-2022, 10:53 AM | #5 |
2272
Rep 3,297
I have mine at 44 and 45......above 100 mph frequently. LOL
Mike
09-30-2022, 11:51 AM | #6 |
1834
Rep 1,318
09-30-2022, 12:02 PM | #7 |
5234
Rep 10,615
BMWs high psi recommendations are for fully loaded weight autobahn use where the 100+ is sustained and handling is not the goal. For the occasional highway pull you don’t need to set your tires at 45 psi cold. Can’t go 100+ for long in my area of the US.
09-30-2022, 02:25 PM | #8 | |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
Correct psi is on the door 32/33. However in cold this can easily drop into the 20s and you get a warning. So in the winter I run cold pressures around 35/36 to preclude this. I usually won't reach full operating temps by the time I get to work but if I do it's still velow 40. I've found anything above 40 leads to an awful rough ride.
'07 Yamaha R1 (sold)
STi from DSM257.00 |
09-30-2022, 02:32 PM | #9 | |
1834
Rep 1,318
I personally ignore the shit out of the computer warning when I'm on track. The stupid thing squawks when I start out at 27 psi in the shittiest hot day in July on track and is still reporting "low tire pressure" when the tires ALL THE WAY ROUND read 39 psi. It's just a suggestion. Personally, for you, I'd set the psi cold at 32/33 JUST LIKE ON THE DOOR. Make sure the computer is set for the proper tire and < 100mph. TPMS's are for the really dangerous pressures of 20 in a fully loaded SUV. It's what they're for. For the people like us, they don't do much other than make us more aware. Shawn |
DarkishM5C308.50 ERC429.50 |
09-30-2022, 03:53 PM | #11 |
341
Rep 318
Same here. My sensors just went off a few days ago. Fronts were around 27 and the rears 29. Pumped them up to 33/34. Almost time for the winter swap anyways.
Current - Second 2023 XM (first one was taken back by BMW) and 2023 X7 40i
Past - 2009 X5 35d, 2011 MB E350, 2011 740i, 2015 X5 35d, 2018 M550i, 2019 X5 40i, 2021 M5C |
shawnhayes1834.00 |
09-30-2022, 03:56 PM | #12 |
50
Rep 103
You guys are right! Computer was set for >100. Such a simple fix—no way was I going to inflate tires to 38/39!
shawnhayes1834.00 BayDriverSF203.50 |
09-30-2022, 04:42 PM | #13 | |
2272
Rep 3,297
I have them set as per the display 36 front, 37 rear...... I had been putting them at 42, all around for years, never noticed any handling issues. I find infact the cars handle more crisply at higher pressures. But since this thing tells me 36/37, that is where I try to keep it. Just checked, I'm at about 32/33 now, so have to add some air. Mike
09-30-2022, 05:03 PM | #14 | |
1834
Rep 1,318
Shawn |
09-30-2022, 05:04 PM | #15 | |
1834
Rep 1,318
Shawn |
09-30-2022, 05:18 PM | #16 | |
1834
Rep 1,318
As the speed, and the g's increase, ANYWHERE near 40 psi gets squirrely on most street tires (even on hot pressures). The excess air keeps the tire from "working as designed". Most manufacturers have an "optimal" road pressure. This is usually achieved after about 20 minutes of driving on a car in 70 degree weather with the tire at the recommended cold pressure of the car (almost always 32 psi, unless you're talking about a weirdo like the i3 - I had two of them). Almost every other condition becomes a compromise. https://www.firestonecompleteautocar...ate-car-tires/ On the track, trackrats like I am, almost always note that anything DOT legal starts to slide at anything over 40 psi. Hot or cold. Despite physics (which doesn't give a shit about size of contact patch), real cars have "rollover" on tires. As the car corners, the tires roll over onto the outside edges of the tire (on the outside of the turn radius). The inner tires roll over on the inside edge. Traction seems to be compromised. Physics says that as long as the friction coefficient doesn't change, it shouldn't matter. But it DOES. Otherwise, we'd all have bicycle tires on our cars. I'm sure the reasons are more complicated, but both car and tire manufacturers agree. Inflate to recommended pressures and stay there. Shawn |
09-30-2022, 05:48 PM | #17 |
228
Rep 298
I set them ALL at 33 PSI cold. Period.
BayDriverSF203.50 DavidXJ663.00 |
09-30-2022, 06:42 PM | #18 | |
341
Rep 318
Car goes in for service/inspection/emissions in a few weeks. Plan to swap the tires to my all seasons shortly after.
09-30-2022, 09:17 PM | #19 | ||||
1834
Rep 1,318
Shawn |
09-30-2022, 10:10 PM | #20 | |
341
Rep 318
I don't drive the M5 in standing snow. So don't need the snow tires. A/S's suit my needs for the colder winter temps.
shawnhayes1834.00 |
10-01-2022, 06:02 AM | #21 |
367
Rep 1,202
Timely post, I just had my PS4s installed Thursday. I was surprised when they set my new tires at 34 PSI cold.
I usually run a couple lbs less but after seeing this thread I’ll stay at 34. Goes w/o saying, PS4s >>> P ZERO’s |
10-01-2022, 02:22 PM | #22 | |
1834
Rep 1,318
Shawn |
