05-12-2022, 07:44 AM | #1 |
182
Rep 321
Running Temperature
Can you tell me what is your normal running temperature is at? I installed the CSF Charge coolers and I don't remember running this hot. It's only 7 Celsius outside (44 F) and I am at 120C
Thanks |
05-12-2022, 08:19 AM | #3 |
1977
Rep 1,826
scotty91ss181.50 |
05-12-2022, 08:23 AM | #4 |
3617
Rep 4,532
That is engine oil temperature. 120c/248F is normal.
scotty91ss181.50 |
05-12-2022, 09:52 AM | #5 |
182
Rep 321
Thanks everyone.
I have the CSF charge coolers installed now and later this month going to finalize a Carbahn Stage 2 tune with sensor and coolers. Will post results when I get them. |
05-12-2022, 10:22 AM | #6 |
5179
Rep 10,557
The CSF charge coolers are for the intercooler system and are unrelated to the engine operating temperature. Early M5 have a 100C engine coolant thermostat that results in the engine operating at about 120C. Later M5 have a 90C thermostat that gives closer to 110C temperature on the gauge when hot. Maybe change to the later thermostat if you think your engine is running too hot. I bought one and will be changing mine.
EDIT— I am not responding correctly here, the OP’s picture is of the oil can with temp flag above so that is oil temp not coolant. But oil cooler is under car and intercoolers are on the sides. Still, there seems to be a difference in oil temps on gauges of early and late cars. Not sure why. Some say it may depend on whether the engine is in efficiency mode or sport mode, which makes sense. I drive mostly in efficiency, but will look at the gauge while in sport more closely. Last edited by pbonsalb; 05-12-2022 at 12:57 PM.. |
SatinblkF90134.00 |
05-12-2022, 11:07 AM | #7 | |
134
Rep 254
05-12-2022, 11:40 AM | #8 |
4133
Rep 7,154
Drives: F90 M5 / F15 50i
no. 100C is normal for most cars. 90c is just better
'07 Yamaha R1 (sold)
05-12-2022, 04:31 PM | #10 |
4052
Rep 3,657
Drives: 2022 M5C
Exactly where mine operates, even in the temperatures you noted.
Not a BMW guy...but certainly an M5 guy.
05-13-2022, 06:30 AM | #11 |
5179
Rep 10,557
This is always a good read. I look at it periodically but there is so much info that I can’t remember all of it. Covers a lot of topics that periodically surface in the forum (no auxiliary battery on the M5, the different cooling systems, the lithium battery, fluid change intervals, etc).
https://f90.bimmerpost.com/forums/at...2&d=1530151323 |
UglyBuzzard6354.00 |
05-16-2022, 03:11 PM | #12 | |
383
Rep 445
05-16-2022, 04:08 PM | #13 |
948
Rep 1,045
05-16-2022, 04:34 PM | #14 |
1540
Rep 2,001
Not technically the same engine, a few things different, but I concur 120c is a bit hot my 22 m5 runs at 210f which is about 100c, and my f10 m5 (pre lci) was running anywhere from 200-220 f depending on how I was driving.
09-29-2022, 08:07 PM | #15 |
IG: @M5RCY_
359
Rep 312
LCI DOES run cooler than PRE LCI
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off Dura-Coating - code: M5RCY for 20% off |
09-30-2022, 05:20 PM | #17 |
123
Rep 339
The gauge in the car is off. ISTA reports around 210F on pre-LCI.
See: https://f90.bimmerpost.com/forums/sh...9#post29189289
2018 Alpine White ///M5
