View Poll Results: Do you rev match? | |||
Yes | 85 | 65.38% | |
No | 12 | 9.23% | |
Sometimes | 33 | 25.38% | |
Voters: 130. You may not vote on this poll |
11-10-2009, 10:28 AM | #1 |
Moderator
568
Rep 4,240
Be Honest: Do you rev match?
Be Honest: Do you rev match your manual transmission vehicle? I never realized until recently but I only do it on occasion. It is like a spasm of some sort. Even the girl I'm talking to rev matches. I'm not sure if it correlates to gas mileage all that much. I do get higher mpg's than my buddies even though I don't have a light foot.
Do you rev match?
- 04 Honda S2000(gone)
11-10-2009, 10:36 AM | #2 |
I like cars
331
Rep 5,052
How else can you drive manual? If you don't rev match then the car jerks when you downshift.
My photostream: http://www.flickr.com/photos/racelap/
11-10-2009, 10:42 AM | #3 |
87
Rep 2,324
"You will get there, but it is up to you and you alone. It is what you are willing to do, and how you are willing to get there. You must be relentless, you must be tireless, you must pursue at all costs, so that you are ready, when the time is right." -Dad
11-10-2009, 10:53 AM | #4 | |
7er
9
Rep 409
Drives: 1998 BMW 740iL
How long have you been driving? With modern synchros it's simply not necessary unless you are racing and downshifting. Street driving, there's simply no need to shift faster than the synchros can handle. The trans will still last forever and it's not jerky at all. Now, if I'm in an older car with worn synchros, then yeah, rev match every time (in fact, I've had to drive a couple cars that the clutch was so bad that I had to shift wiothout using the clutch, requiing careful rev-matching to get teh car to it's destination).
1998 740iL
11-10-2009, 10:58 AM | #5 | |
Moderator
568
Rep 4,240
11-10-2009, 11:09 AM | #6 |
301
Rep 2,874
I rev match during spirited driving or on the track because it keeps the weight distribution stable, but on the commute drone, I don't bother.
11-10-2009, 11:13 AM | #7 |
115
Rep 1,347
Drives: 2011 335d
I always attempt to rev match. The key there is attempt...
11-10-2009, 11:24 AM | #8 |
Poke Her Face
27
Rep 368
This is perfect...I've been meaning to ask this question (135 = my first manual car)
For those of you that Rev match...this is only an attempt to rev match precisely correct? I'm assuming you don't know exactly what your RPM's are after downshifting at your current speed....only a rough estimation....? I personally don't downshift to often (just put it into neutral when rolling up to a stop sign/red light etc)...only downshift with I need to take a corner that requires it...and I ATTEMPT to rev match (sometimes to high/to low)
11-10-2009, 11:36 AM | #9 | |
248
Rep 1,435
You have already begun modding your 135 and you don't know how to downshift when you come to a stop?? It is something you really need to work on. You are gonna wear out those brakes extremely fast driving in that manner. Even in an auto the car downshifts for you and helps stop the cars momentum. The first manual car I ever drove I put it in neutral and came to a stop for the first week or so till I learned how to effectively downshift.. But this isn't something that you can ignore. It is part of driving a manual transmission. Not to mention you shouldn't even have to put the car in first when coming to a stop sign. You should be able to downshift into 2nd and then come to a stop and depress the clutch, rev up and continue driving from 2nd gear. The less time you spend in 1st gear the less wear on your car. Concerning your statement about "attempting" to rev match. The more miles you put on your car the less you will ever need to look down. You should know simply by listening to the exhaust note when to down shift and where your revs are in the range. A lot of people make comments about drivers and their cars on this site. Some of them are justified, some of them aren't. However, before modding your car you should really know how to drive the car properly/effectively prior to modding it. Otherwise, you are wasting your money and risking your automobile. |
11-10-2009, 11:36 AM | #10 | |
Fapmin
406
Rep 2,660
No I don't, the pedal configuration in my Jetta doesn't allow for it. The brake pedal is too high in comparison to the accelerator .
On top of that, I don't even know how to. I'm sure I could've figured it out by now if they didn't have a gay pedal set up. However, I have learned to minimize the jerkiness of downshifting and sometimes it's smooth as butter. Quote:
11-10-2009, 11:43 AM | #11 |
154
Rep 4,528
Drives: M2 CS
every single time, i understand the syncros will do some of the work but after 10+ years of driving manuals its a habit to give it a lil bleep of throttle to rev match on non aggressive downshifts and i am pretty accurate on rev matching the aggresive downshifts aswell
11-10-2009, 11:47 AM | #12 | |
248
Rep 1,435
My fleet of trucks consist of mostly automatics and about 5 manuals. They all used to be manuals. I learned how to drive a truck on manual transmissions. I only use the clutch to go from neutral to 1st and from neutral to reverse. Otherwise, you hit your RPM target and lift from the gas and shift. It works with every manual transmission. My trucks go almost 100k without clutch replacement and my drivers are downshifting. If they weren't downshifting they would never be able to slow down the trucks with a full load, the brakes would simply overheat and explode. If you want to combat that argument, ask him why he is driving a car with a clutch if he doesn't want to use it? 4 brake pads installed on a BMW are not cheap... at all. |
11-10-2009, 11:56 AM | #13 | |
Fapmin
406
Rep 2,660
11-10-2009, 12:32 PM | #16 |
228
Rep 20,998
+1...i generally do not downshift that often. and i usually will not rev match. i try to though
09' E92 335i | 6MT | Montego Blue | Black Dakota Leather | Dark Burl Walnut | Premium | Sport | Cold Weather | Nav | Sirius | Comfort Access | iPod and USB adapter
11-10-2009, 12:36 PM | #17 |
plasar
24
Rep 385
Drives: M3 Vert
Sorry, I can't agree with these points from a previous poster:
* you should downshift/engine brake or you will wear out your brakes. (Brakes are designed to slow the car down and are cheaper than transmission/clutch.) * you should start off from full stops in 2nd gear. (Ever hear of clutch slip which is synonymous with clutch wear?) * the less time you spend in 1st gear, the less wear on your car. (I don't know where to start on this one...) You can find a few links about driving a manual transmission here... read for some good advice... Driving a Manual Transmission Oh, and BForbes, it's very important to rev match with your girlfriend - if you don't, you'll find yourself grinding your own gear! |
11-10-2009, 12:52 PM | #19 | |
Moderator
568
Rep 4,240
11-10-2009, 01:16 PM | #20 |
143
Rep 1,401
IMO, BForbes needs to loose Mod status until he correctly & consistently rev matches his down-shifts. A Mod that fails to do so is a disgrace to this forum!!!!!!!!
11-10-2009, 01:36 PM | #21 | |
Moderator
568
Rep 4,240
You cut me real deep, Lib. I wonder if the 370Z forums would welcome me. They do have that rev matching button feature.
11-10-2009, 01:55 PM | #22 |
7
Rep 213
I do all the time. It'll be less jerky for passengers during down shifts. It sounds cool with a nice exhaust. You'll be doing your car a favor in the long run.
RPI GT Race Exhaust ~ RPI Scoops ~ BMC Air Filter ~ 19" BBS LM DBK ~ JL Motoring VRS Front Lip ~ Vorsteiner Diffuser Type I ~ KW Clubsports
My RPI GT Race Dyno vs. Stock: http://www.m3post.com/forums/showthread.php?t=239228 |
