07-09-2021, 03:06 PM | #1 |
110
Rep 77
Sarasota / Tampa lowering springs install
New to the area and Need some recommendations on a shop to install eibach pro kit springs on my 2018 F32.
From what I've read here on the board it should be around $500 including alignment to do. I've contact two so far and they are just looking up what the "catalog" says for time, etc. and getting $1200 quotes |
07-09-2021, 03:55 PM | #2 | |
2467
Rep 5,457
Drives: F30
1 hour per corner is about right, with a proper lift. The rears will take less and the fronts a bit more. Depending on labor rates, this will put you in the $400 range. I absolutely would not pay more than $500. Add an alignment on top for another $100-150. This has been done in countless garages across America on jackstands (with a AutoZone spring compressor in my case). Point is, decide how much your time and effort is worth and go from there. Its not a rocket science type project by any means. I took my time and made it happen over a Saturday afternoon, early evening. |
Localmotion110.00 |
07-09-2021, 05:09 PM | #3 | ||
110
Rep 77
So $1200 is ridiculous then correct? I wouldn't mind doing it myself as I try most other thing diy. Would be nice to have someone to do it with me but I could manage. Only reservation is it's our only vehicle so would hate to have extended downtime without transportation |
01-27-2022, 10:38 AM | #5 |
110
Rep 77
02-07-2022, 01:28 PM | #6 | |
1623
Rep 2,036
https://x3.xbimmers.com/forums/showthread.php?t=1641417
Localmotion110.00 |
12-15-2023, 09:26 AM | #7 |
Rep 5
Look up Rogue Works, he will come to your house to install. You'll need to take it to an alignment shop afterwards but that's easy.
Localmotion110.00 |
