05-13-2023, 02:28 PM | #1 |
314
Rep 237
I’m on H&R f90 m5 springs - it’s a moderate drop. Not too low. I want to know what the absolute most aggressive offset I could run with a 20” setup. Any info appreciated. I’d also like to run a 295/285 tire setup.
05-13-2023, 04:55 PM | #2 |
162
Rep 254
Drives: M5 / X5
I have 295’s on the back with 706m wheels. With a 12mm spacer I had to take the spacer out completely and the wheels were flush. They were outside the fender and rubbing with the spacer in. I run the 15mm spacer on the front with 285s, but I think the 12mm spacer would be enough. Most everyone else seems to be running 12mm on the rear but they must have the stock 285 tires.
05-14-2023, 06:44 AM | #3 |
609
Rep 748
On 706 wheels with 285/295, I ran 12mm/5mm. It was aggressive and I wouldn’t want more but I guess you could try 15mm on front. 5mm is your limit on rear I would almost be certain.
