04-15-2024, 10:09 AM | #45 |
51
Rep 61
Drives: BMW F31 335d
Can we go back to the posts saying how easy it is? After TurboWeasel's post I figured this was well within my capabilities with my qualifications of "has hands" and "owns ratchet". But no one else seems to be finding it trivial
04-15-2024, 11:59 AM | #46 |
6455
Rep 8,519
He left out a couple of minor details - also need triple-jointed wrists and eyes on the ends of your fingers :-)
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
04-15-2024, 01:59 PM | #47 |
63
Rep 84
Definitely not as easy as it sounded hence why I ordered the part and wanted to do it,it was just more fiddly and space constricting,other than that straightforward,on the plus side car sounds quiter and the chain is as tight as it can be,not planning on selling it anytime soon so a win win in my book.👍🏾
Watsey6454.50 |
04-16-2024, 03:52 AM | #48 |
881
Rep 1,115
Sorry guys, I forgot to mention it's only easy when there's a solar eclipse and you've had 3 shredded wheat and a boiled egg for breakfast.
04-17-2024, 04:30 AM | #49 |
51
Rep 61
Thought about taking a look at this while the sun's out and hit the first snag. I have a 70Nm torque wrench that I bought for changing the oil a couple of weeks ago. What I don't have is a 3/8" drive 24mm socket to go with the torque wrench, only a 1/2" drive. Excuse for more tool shopping I guess...
04-18-2024, 04:05 AM | #50 |
881
Rep 1,115
You can never have too many tools. Don't worry too much about torquing to 70nm. It's a tight torque for the restricted access. You need to get the socket onto the tensioner dead square to avoid rounding off the soft aluminium.
You will feel the crush washer flattening down and then it will stop, much like a sump bolt. Give it one more final ugger dugger at that point, and that's all it needs. |
gac51.00 |
04-25-2024, 06:55 AM | #52 |
51
Rep 61
05-13-2024, 03:55 PM | #55 |
14
Rep 79
Any reason not to do this job? I believe my X5 has the original 11318576201 as my build date is 11/6/2014. The car is a 2015 35d with 140k miles.
I'm going to be doing my VCG and I was looking to maybe tackle this as well. I don't believe I'm having any issues at the moment with slack, although I was going to pickup the tool to check the slack. |
05-14-2024, 12:00 AM | #56 | |
217
Rep 413
On a picture is a N47 engine on X1; the gap between bolt and engine block is so tiny is next to impossible to put any socket onto it, I am still figuring what it takes to replace this bolt. But if your can be done using procedure described in this thread without removing much, then I would definitely have done this.
1995 E34 525td auto • 2016 F30 320ed auto
