09-18-2020, 06:46 AM | #23 | ||
6525
Rep 3,072
Drives: M2 CS, 18 Vantage AMR, 00 WRX
09-18-2020, 07:53 AM | #24 |
Mmmm... Bavarian
2129
Rep 1,690
Are you saying that because of the Cup2's or something else? Trying to understand your perspective here. I'm used to getting 4-5 track days of that length out of a set of RE71R's without issue on my E36 which is only about 200lbs lighter.
M2 CS
2023 CB X5 45e 2018 i3 94 2014 Cayman S |
09-18-2020, 08:12 AM | #25 |
64
Rep 69
I think it held up very well, especially considering Hockenheimring is pretty hard on brakes and it was hot. However, I think more negative camber in the front would be beneficial for track use, and for the longevity of tires.
On a side note, the carbon ceramic brakes did experience some fading, but it was gradual and braking points could be adjusted. I am not sure if the pads and brake fluid were stock, or not. Another M2CS was getting occasional overheating warnings on dash when following to close in dirty air -- I didn't experience that. |
09-18-2020, 11:55 AM | #26 | |
1779
Rep 4,516
Wear on both my road (MPSS)/track (AD08RS) front sets of tyres is both even wo any excessive heat cycling blisters / craters on AD08RS
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
WoodyOGM21.50 |
09-18-2020, 12:18 PM | #27 |
2030
Rep 2,672
great info
after testing m2c on backroads it reminded me of my e90 before camber plates and suspension upgrade. This tread confirms my opinion that these cars need -2+ front camber and wider stickier rubber of at least 255f 275r re-71 or similar Currently -2.5 front and -2 rear on e90. On track and spirited driving with 255 square RE-11 there is even wear. Had the tire wear checked out by Bstone team ar Summit Pt Main and they said perfect wear don't change geometry. Thinking of getting m2c and learning about the platform. |
Bee Pee1779.00 |
09-18-2020, 03:03 PM | #28 | |
1779
Rep 4,516
PFA
09-18-2020, 03:27 PM | #29 | ||
2030
Rep 2,672
do you have a side and rear view photos? |
09-18-2020, 03:32 PM | #30 | |||
1779
Rep 4,516
Mavus2029.50 |
09-19-2020, 12:35 AM | #31 | |
6525
Rep 3,072
So I guess you take it easy on these sort of track days then? I'm used to supersprints. Maybe 4 or 5 sessions of 3 timed laps. Stock camber usually means your outside edges are toast after 4 events. |
09-19-2020, 07:54 AM | #32 | |
Mmmm... Bavarian
2129
Rep 1,690
I think you maybe answered the cause - I run a little more than stock camber, and I also flip the tires after a couple of events. Plus on my e36 I'm not staggered so they are rotated to the rear as well. That was part of the perspective I was trying to figure out - if you were actually seeing full out complete tire wear in 4 events, or setup or tire area specific wear. So if your frame of reference is camber limited, staggered setup, and a tire that can't be flipped, then that all makes sense. Hell there are tires I've seen that can't make it through 2 autocross events (a whopping 12 minutes of race time) before cording the shoulders on certain cars.
M2 CS
2023 CB X5 45e 2018 i3 94 2014 Cayman S Last edited by sdhotwn; 09-19-2020 at 08:00 AM.. |
09-19-2020, 10:42 PM | #33 | ||
6525
Rep 3,072
Yes I had some Hoosiers de-laminate on an e36 after one event. Those things are so camber dependent but incredible when everything is set up nicely. |
09-20-2020, 07:01 AM | #34 | |
Mmmm... Bavarian
2129
Rep 1,690
Internet isn't the best conveyance of intent always! Yeah, the Hoosiers were super finicky and a quick route to the poor house, but amazing when setup and to temp! |
Davil6524.50 |
09-21-2020, 07:55 AM | #35 |
2723
Rep 3,337
Ah the vaunted Hoosier A6...brings back 14+ year old memories for autocrossing the ZHP with my daughter co-driving, stock class, only allowed suspension change then was a front sway bar (Turner motorsports) and shocks (TC Kline valved Koni SAs).
New and then after only 16 total runs . Bottom pic is RF tire off the ground at max cornering = Hoosier A6 grip + front roll stiffness.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
09-21-2020, 08:16 AM | #36 | |
Mmmm... Bavarian
2129
Rep 1,690
Everything about that is classic!!
M2 CS
CSBM52722.50 |
09-21-2020, 11:09 PM | #37 | |
6525
Rep 3,072
CSBM52722.50 |
09-28-2020, 03:48 PM | #38 |
4398
Rep 2,856
Drives: BMW M2 CSL Turbomeister
I measured another M2 CS and this was the finding:
Front axle Toe left: 0°04' / min 0°03' to max 0°07' Toe right: 0°12' / min 0°03' to max 0°07' Toe total: 0°16' / min 0°06 to max 0°14' Rear axle Toe left: 0°10' / min 0°06' to max 0°10' Toe right: 0°09' / min 0°06' to max 0°10' Toe total: 0°19' / min 0°12' to max 0°20' Camber front axle Left: -1°37' / min -1°54' to max -1°04' Right: -1°46' / min -1°54' to max -1°04' Camber rear axle Left: -1°40' / min -1°55' to max -1°45' Right: -1°22' / min -1°55' to max -1°45' Trail front axle Left: 7°33' Right: 7°31' I also measured the heights! This means top wheel arch to lowest point of the rim: Front height 62.2 cm left front, 61.8 cm right front Rear height Both sides 62.5 cm Just for people who want to know how much lower the M2 CS is. Not sure it is much lower than a M2C. MR Last edited by MR.; 09-28-2020 at 03:55 PM.. |
09-28-2020, 03:55 PM | #39 | |
1779
Rep 4,516
Basically more neg camber upfront than on the rear for m2cs - opposite stock geo for the rest of F87 variants.
01-13-2021, 10:26 AM | #40 |
98
Rep 103
How does the M2CS achieve 1.8 degrees of camber? I thought the M2 and M2C were limited to 1.5 without camber plates or hubs. Ive seen ~1.8 is achievable with the added camber from lowering ride height, but the CS is noted to be about the same height as previous F87’s.
01-13-2021, 11:47 AM | #41 | |
1774
Rep 1,262
Drives: BMW 1M
Keeping stock height with camber hubs gives between 1.7-1.8 neg camber. Lowering with camber hubs (like I have done) you can end up with 2.2 neg "fixed" camber with the correction hubs. |
CSBM52722.50 |
01-13-2021, 04:34 PM | #42 | |
7122
Rep 4,008
Drives: M235i, 420i, and now the M2 CS
I recall reading cooling went from 7L to 7.5L
M2CS,
The second coming of ///M! |
01-14-2021, 04:11 AM | #43 | |
1779
Rep 4,516
Stock - 1.5deg neg std Mperf coilovers - 1.8deg neg As above c/w oem camber correction - 2.25deg neg. Based on the above, adding oem -0.5 hubs would net -1.8 to -2deg front camber on an otherwise stock F87...
Current '22 X3M LCI.. Last edited by Bee Pee; 01-14-2021 at 04:18 AM.. |
M2C_PLUS1774.00 |
01-14-2021, 04:23 AM | #44 | ||
6525
Rep 3,072
