03-05-2022, 09:38 PM | #1 |
31
Rep 85
Minor shake in AWD but none in 2WD
So my car is lower on dinan springs and im running spacers… but i have always noticed a shaking in the steering wheel when reaching 100mph and higher, i always thought it was maybe the spacers, i rarely drive the car in 2wd and decided to tonight and noticed the steering wheel didnt shake or was very very minimal in 2wd was getting to 110 and 115 and no issues had to actually look down at speedometer because i didnt feel it.. anyone notice anything similar where it shakes in awd verus 2wd
Jeffrey jaquez
03-06-2022, 01:27 AM | #2 |
2511
Rep 4,381
At steady speed it shouldn't make any difference whether you are in 2WD or AWD...according to BMWs manual the front wheel drive is not engaged unless the system discerns that some parameters are being exceeded such as slip at the front or rear wheels .
Maybe try without the spacers? |
03-06-2022, 01:59 AM | #3 |
141
Rep 401
Just to rule out other issues, i would get the wheels balanced with hunter road force and see if that solves the problem. Sorry, i know my comment does not answer your question but had an issue at those speeds on a private track and the tires were way out of tolerances to the point we could not get them to reduce the tolerances to acceptable levels and so i had to change the front tires. Speeds for me anywhere up to 100 mph there was no vibration, but for sure over 115 mph and above. Probably cost $100 to have all 4 wheels checked and make sure you get the rears done too. Unless you conduct a series of testing on the same day using 4 wheel and 2 on the same stretch of road i would be inclined to get the wheels balanced properly first. Good luck and hope you manage to get this sorted.
03-06-2022, 07:57 AM | #4 | |
31
Rep 85
Jeffrey jaquez
03-06-2022, 07:58 AM | #5 | |
31
Rep 85
Jeffrey jaquez
M5 F90 (2018)141.00 |
03-09-2022, 01:27 AM | #6 | |
39
Rep 204
03-09-2022, 08:01 AM | #7 | |
983
Rep 1,800
03-09-2022, 10:10 AM | #8 | ||
39
Rep 204
I won't bother replacing it since I'm okay with it now |
03-09-2022, 07:54 PM | #9 |
18
Rep 173
That’s so dang weird. I have the same exact friggen issues.
Anything above 130MPH-140MPH the car shakes when in 4WD I had the inclination that it was the front diff. Also too if under heavy load 5k-6.5k RPM the car has tendencies to actually pull hard right. Kinda scary if I’m honest. I’m on KW coil overs Running 285/30/20 front and 305/30/20 on the rear. The car never did that before except after I did tire changes. I’m so confused. 🤦🏻*♂️🤦🏻*♂️🤦🏻*♂️ Any ideas would be greatly appreciated. |
03-10-2022, 12:20 AM | #10 | |
1543
Rep 2,021
03-10-2022, 01:26 AM | #11 | |
2511
Rep 4,381
03-17-2022, 11:20 AM | #12 | |
18
Rep 173
Awesome thanks so much. I’ll have an alignment done here shortly. Also too would having let’s say 285/35/20 front and 305/30/20 rear do it? The height of the tire upfront maybe? |
01-30-2023, 04:25 PM | #13 | |
Rep 2
02-01-2023, 09:47 AM | #16 |
322
Rep 400
Drives: 23 M5C, 19 X5
Base on the dealer tech guides from TIS if you are feeling something different in AWD vs 2WD on the highway at a steady speed the transfer case must be engaging the clutch when it isn't supposed to:
"In contrast to the rear-based standard all-wheel drive of the BMW VTG control, the BMW M VTG control only applies torque to the front axle after the rear axle exhibits slip and additional drive torque transfer to the rear axle is therefore no longer effective. The slip defined in this way on the rear axle, before the drive torque is transferred to the front axle via the BMW M VTG control, has the effect that the new BMW M5 handles more like a rear-wheel-drive vehicle in terms of the driving dynamics." I don't see how spacer would matter but are you running the stock tire sizes and rim widths? It has this disclaimer in the guide: "The tire tread depth as well as the tire manufacturer should be the same on the front and rear axles if possible in order to ensure proper functioning of the xDrive. It is also advisable to only use tires that have been approved or recommended by BMW." If you are all stock then I would take it in and complain. The clutch should be fully open when cruising at a steady speed. |
02-02-2023, 11:13 PM | #17 |
31
Rep 85
I guess the 5mm wasnt hubcentric and when i switch to 10mm hubcentric the shaking almost completely went away which didnt make sense either, but it was the only change i did… the car is on dinan adjustable springs with spacers, thats it, also when i first noticed the shaking i had the wheels road force balenced which helped alittle but problem consisted until i changed the rear spacers
Jeffrey jaquez
