08-31-2023, 06:22 PM | #1 |
Rep 22
dashboard HP and torque
Can anyone of you pls press that button on the tip of the turn signal until you are seeing the hp and torque on the speedometer? What do you see? Mine is attached
08-31-2023, 06:42 PM | #2 |
337
Rep 414
Drives: 23 M5C, 19 X5
Mine goes to 640. I assume that car has been coded.
ResIpsaLoquitur4160.00 MunnyGuy41.50 |
09-01-2023, 01:24 AM | #3 |
4160
Rep 3,706
Drives: 2022 M5C
Not a BMW guy...but certainly an M5 guy.
09-01-2023, 02:39 AM | #4 |
Rep 22
09-01-2023, 06:54 AM | #5 |
337
Rep 414
I really question the numbers shown sometimes. There are times at light throttle it shows 550lbft. I would think the only way to get max torque is WOT. Or they play tricks with the throttle map to make the car feel faster. I haven't figured out the correlation yet. On a given drive cycle I am in 3 different engine and transmission modes so I haven't figured out the exact combo yet that does that. I need to conduct some tests. Either way I'm pretty sure the throttle on this car is not linear in any mode.
09-01-2023, 08:52 AM | #6 | |
5288
Rep 10,686
09-01-2023, 11:44 AM | #7 | |
337
Rep 414
I need to find a time with an empty road to play around with throttle position/engine mode/speed/gear and see what happens. |
09-04-2023, 09:01 PM | #9 | |
1481
Rep 3,955
09-04-2023, 10:01 PM | #10 |
5288
Rep 10,686
So it would be impossible to drive at 2000 or 3000 or 4000 or 5000 rpm without making a substantial amount of boost? I find that hard to believe but have not paid attention. In my other turbo cars, I can drive without making any boost — under low load conditions like level ground and light throttle — in those rpm ranges. The 4.4L V8 won’t make 550 lbs torque without boost.
09-05-2023, 06:38 AM | #11 |
337
Rep 414
That is peak. It does not make that much depending on the throttle position. Frequently I see it read far less. I'm just surprised when it does read max at less than full throttle (fully depressed accelerator pedal. It is an electronic throttle so the pedal position is just a suggestion to the car)
09-05-2023, 07:09 AM | #12 |
2281
Rep 3,305
That is pretty cool. Now the tech can more easily and quickly verify that your car is tuned and more efficiently cancel your warranty. But pretty cool just the same.
Mike
bbradyc5390.00 |
09-29-2023, 11:06 AM | #13 |
Rep 22
09-30-2023, 06:53 PM | #14 | |
2281
Rep 3,305
Mike
