03-11-2020, 08:05 PM | #1 |
170
Rep 241
F90 comp almost stalling
Guys I put a video up of what my car has been doing lately basically when I start it sounds like it’s going to stall and then it catches itself. Also I started it one day in the odometer and the tachometer went black on me and then the traction light came on I’m at a loss here
03-14-2020, 06:18 PM | #4 |
62
Rep 240
few guys on here had fuel pump issues, BMW swapped them out under warranty try that first
KennyM340ISouthFLA.169.50 |
03-14-2020, 07:17 PM | #5 |
109
Rep 411
It's a fuel pump.
I had same issue Eventually car will turn off Just bring it to dealer Car will also run better once fixed |
03-14-2020, 09:19 PM | #7 |
170
Rep 241
i swear the car is not pulling the way an F90 should. i test drove a X4M and i swear that felt faster. call me crazy but can this fuel pump cause the power to be held back?
03-14-2020, 09:21 PM | #8 |
109
Rep 411
Yes. My car was driving horribly before changing the fuel pump. My 0-60 was low; quarters we crap; and my ignition timing was very low . I think it will make a big difference. It did for me. Faulty fuel pump can have problems giving engine enough fuel af start and under stress, such as WOT = slower.
03-14-2020, 09:30 PM | #9 |
170
Rep 241
i just called and left a message on my SA voicemail at the dealer 10:15 tonight. I'm here in Fort Lauderdale ,Fl. i said Joe make sure the tech changes the fuel pump , a lot of people are having issues with their F90"s. i don't want the car back unless its changed. i got all disturbed about all this . 120K car dealing with this nonsense! thanks again for the update.
03-14-2020, 09:58 PM | #10 |
109
Rep 411
I hear you. I am in Palm Beach. Let me know if you want me to link your SA up with my SA @ Brahman. It's a common issue with the 2019 M5s, and I'm hoping that's the issue for you. It's an easy fix. Once they changed my fuel pump - which was faulty - all the starting issues disappeared and the car felt much better.
03-14-2020, 10:07 PM | #11 |
170
Rep 241
I'm going to be honest. if they do not change the fuel pump, i am going to bring the car to your SA and have them do the work. i appreciate that .can you IM me ill send you my cell number just in case they don't .
03-14-2020, 10:10 PM | #12 |
170
Rep 241
If you can send me your SA name at Brahman that would be great. i guess lets see what he tells me but I'm insisting they change it . very unhappy how the car is performing. my M4CS i had felt quicker.
03-14-2020, 10:12 PM | #13 | |
4092
Rep 5,237
I have the same issue on a 19' M5C. Thanks in advance.
03-14-2020, 10:49 PM | #15 |
170
Rep 241
@JOESEC70 are you feeling loos of power at all as well? if you do some hard pulls ? as i told JBA87 my car is running like a dog due to this issue . its at the dealer as we speak.
03-15-2020, 11:33 AM | #16 | |
379
Rep 544
03-15-2020, 11:33 AM | #17 |
379
Rep 544
03-15-2020, 05:53 PM | #18 |
4092
Rep 5,237
Thanks!
03-15-2020, 05:56 PM | #19 |
4092
Rep 5,237
I've not really felt a loss of power .... or maybe I've gotten used to it. Car goes for an oil change in the coming weeks and will address it with my SA.
03-15-2020, 08:14 PM | #20 |
253
Rep 663
Your car has Coronavirus
03-18-2020, 12:04 AM | #21 |
204
Rep 386
No wonder I felt my car low on power recently. just did not pull as hard and feels considerably slower. maybe I should get the dealer to have a look over on the fuel pumps.
Born in M Town
03-18-2020, 09:46 AM | #22 |
170
Rep 241
Yes i would get it checked.Handful of people are having these fuel pump issues. So my car is at the dealer and they found my issue which was fuel pumps. The bad news is that they told me they have to order the parts from Germany which can take 7-10 days to receive . I'm assuming my car will be with them for two weeks. They gave ma loaner , which was the new X7. this thing is a Bus!!!! HUGE. I am appreciative they gave me a 90K loaner , thats the least they can do being my M5 will be down for quite some time.
