04-29-2024, 11:53 AM | #1 |
8
Rep 33
Cracked turner rotors through to inside edge after 20 laps
Hey all,
I recently installed the turner motorsport fully floating discs. I noticed last week that both the fronts had cracked through to the edge in multiple places on the outside of the discs View post on imgur.com Turner are saying they overheated, I'm not sure what to make of that reason. My car is stock, they've done 3 track days, maybe 7 sessions of 3 hot laps. I warm them and cool them extremely carefully. They're sold as track rotors. https://photos.google.com/share/AF1Q...pXSS0xeFdldVNn Has anyone had anything similar with any other aftermarket brake rotors? They are offering to replace them under the lifetime warranty, but that still costs me money and I'll have to get new front brake pads too, which are pagid rs29s so not cheap. I'm concerned this will keep happening. My car is now out of action until I get new front rotors and I'll miss a track day this week. |
04-29-2024, 12:43 PM | #2 | |
1127
Rep 1,322
Why do you have to replace your pads? Do they show a concerning wear pattern? In another thread I mentioned how I've been using the 034Motorsport option (lifetime warranty from FCP). They've held up after 12-13 events last season, waiting to get back out there this season and see how much more they've got. |
04-29-2024, 02:33 PM | #3 |
2485
Rep 5,974
This crack formed due to a stress concentration at the peak of the “arch/semi-circle” between floating mounting tabs. This will likely occur again with future disc replacements. A rotor with good metallurgy should be able to withstand the SCF (fracture analysis to show a maximum flaw size doesn’t grow after X number of thermally-induced cyclic stress. As an FYI, there is no real stress that’s called a thermal stress - you need a mechanical strain to produce stress).
As jfritz27 stated above, why do you need to buy new Pagid pads? You can mix any of new or old rotors with new or old pads. You’d only buy new pads if cracks have formed thru the pad material or you’re close to the wear limit (min 2 mm but some people use 4 mm with is ~1/4 of the starting pad thickness!). Did you ask Turner what temperature needs to be reached to “overheat” their rotors? |
04-29-2024, 05:19 PM | #4 |
8
Rep 33
Thanks guys, glad we're on the same page about the cracking.
I've always used new pads with new discs but the current pads are fine so I'll just swap out the discs. I have asked Turner what I can do to avoid this cracking in the future, and I'll ask the question about temperature M3SQRD! With hindsight I should have followed your advice jfritz27 and gone with the 034s but I thought it would be fun to try something new. I guess the proof will be if it cracks again. I'll only be doing 3-4 laps per run so hopefully not. Turner offered a replacement without any arguing so they stand by their warranty, though I did just notice that the discs are now half price for a set, well under the competition so they can't be selling well. |
04-29-2024, 06:38 PM | #5 | |
1127
Rep 1,322
Thanks for taking one for the team and reporting back! At least they're standing by the warranty, definitely keep us updated... |
04-29-2024, 08:39 PM | #6 | |
2485
Rep 5,974
04-29-2024, 10:58 PM | #7 | |
8
Rep 33
04-29-2024, 11:54 PM | #8 |
2485
Rep 5,974
Valid and scary point. The fact that they’ve discounted them 40% for the F and R pairs and 40% for the R only suggests they be doing just that. It’s odd the F is discounted only 3%. So maybe they’re trying to either get rid of all stock or just R stock. Either way you lose out. There’s a company called Coleman that will reproduce rotor rings at a low cost. They’ve been around for a while and their rotors are used in racing/track days. I recommend them recently to a f8x owner that has a Stop Tech brake kit with their wide annulus rotor rings which they stopped making. He contacted Coleman and couldn’t believe how inexpensive it was to have two custom rotor rings manufactured. I know you’ll have lost your warranty but at least you could continue to use your F and R aluminum mounting hats. Unfortunately, once ECS bought out the Turner Motorsport part business, the quality of products aren’t at the same level they once were.
