05-06-2024, 08:48 AM | #1 |
Rep 2
Reverse camera module location?
Does anyone know where the reverse camera module is located? I’ve had the rear side panels removed and also taken out the carpet in back but nothing. Also checked under the passenger footwell up front.
05-06-2024, 01:45 PM | #3 |
66
Rep 49
Drives: Bmw 435d Xdrive
It’s in the Drivers side kick panel.
05-06-2024, 06:36 PM | #5 |
66
Rep 49
retrofit instructions attached to aid finding what you're looking for..
Ragnar The Redneck45.00 Oksamit78294.50 |
05-07-2024, 12:58 PM | #6 |
Rep 2
I just retrofitted a reverse camera to my 2014 F34.
I can't for the life of me see a way of routing the cable from the tailgate into the cabin. At the moment it is looped so not a great position but at least the camera works. I can't find instructions for removing the trims and accessing the cars loom to get the cable through. How do you get those funky instruction leaflets? |
05-07-2024, 03:58 PM | #7 |
8316
Rep 16,199
I installed one of these, with the camera mounted on the hatch right next to the OEM camera.
https://www.amazon.com/dp/B0811Q28N6...A2KR0J0CK34VOC I ran the cable under the various trim pieces all the way to the rear view mirror that it attached to. There's no funky instruction leaflets, you have to figure it out, but it can be done. |
05-07-2024, 06:52 PM | #8 | |
243
Rep 499
Source: I retrofitted reversing camera the OEM way.
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo |
05-08-2024, 05:10 AM | #10 |
288
Rep 540
Depends what you're using. I've fitted camera emulator boxes which just required me to code the HU and the REM but if you're fitting the genuine BMW reverse camera hardware (pre-LCI) then you'll have the TRSVC module which also needs coding.
With an emulator there's no TRSVC to worry about and with an LCI car there is no separate module so it's ICAM instead of TRSVC. As the retrofit guide linked above mentions, if the car is pre-LCI and it came with reverse camera from factory or has had the genuine BMW retrofit then the TRSVC module is located under the trim in the driver's footwell - there are different mounting brackets for LHD and RHD cars, so it will be on your driver's side regardless. Not the best picture and my car is RHD but you can see the silver module at an angle above the foam padding: You can also see it here through the cutout I made when I was cutting a hole in my dash for the storage compartment: |
05-08-2024, 07:19 AM | #11 |
243
Rep 499
05-08-2024, 07:43 AM | #12 |
8316
Rep 16,199
No, this was with my OEM camera. Among the things I coded, all in REM, were:
REM 3203 V_SCHWELLE_2 werte = FF (default werte = 0F) The speed when it auto disables rear camera view (FF = 255 km/h) REM 3203 D_SCHWELLE_2 werte = FF werte = 00 The distance when it auto disables rear camera view (default FF = 255 meters) |
05-08-2024, 12:47 PM | #13 | |
243
Rep 499
https://www.realoem.com/bmw/enUS/sho...diagId=66_0291 It’s possible you installed an ICAM and also coded HU, though.
05-10-2024, 08:31 AM | #15 |
295
Rep 487
On the contrary, my 2017 LCI F34 has the rear camera module installed from the factory. Car is North American spec.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
