11-07-2023, 03:51 AM | #1 |
161
Rep 77
Drives: BMW G20 320i M Performance
My G20 320i Retrofit List (OEM & After)
Hi Friends!
I'm BMW G20 320i Youtuber at South Korea. Freelancer without work I bought G20 320i for $100,000 for some problem. And, so far, the tuning amount is $20,000. The tuning details are as follows. -OEM List- Strut Brace Bar Hood Insulation Headlight Upper Cover Galvanic Switch (4U0) Gesture Control (6U8) Automatic Tailgate (316) Alarm System (302) Glass Gear Panel with M Logo Fine-wood oak grain open-pored Trim (4KA) M3 Steering Trim (Under & M Button) M Sport Brake (2NH) 792M 19inch Wheel (1PV) M Performance Exhaust M340i Rear Diffuser Bowers & Wilkins Audio System (6F1) Iconic Glow Grille -After List- M Performance Door Lamp M Performance Front Lip M Performance Side Lip M Performance Rear Diffuser M Performance Rear Spoiler M Side Mirror Cover Carbon Exhaust Tip Drive Mode Module about M Button M Track View Cluster Crystal Gear Knob & iDrive & Start Button Gear Panel Storage Bowers & Wilkins Speaker Ambient Light Center Console Ambient Light Sunroof Ambient Light Kufatec Active Sound linked Iconic Sound Trunk Upper Cover FiTCAMX Dashcam (Sponsor) -Wish List- Ventura ECU Chip M340i M Sport Seats Ventilation Seats Acoustic Glazing
8
the3mw79.50 Makaco4617.50 Eljefe2596.00 Correct-Rule13.50 330eJL115.50 dhock_holiday222.50 hybrid-flipper3.00 mikeyb74120.50 |
11-07-2023, 12:43 PM | #3 | |
80
Rep 160
the link is his job.. He has done incredible retrofit jobs haha.. I have learnt a lot from his channel. |
11-07-2023, 02:10 PM | #4 | |
114
Rep 178
11-14-2023, 02:00 AM | #7 |
161
Rep 77
Maybe work!
BDC, FZD is same...
11-14-2023, 02:01 AM | #8 | |
161
Rep 77
bmw oem wires harness very expensive
12-05-2023, 01:29 AM | #9 |
Rep 25
Man this is incredible, I wish there was a shop in the US that does retrofits like this. It would be great to be able to use your videos as a guide, but idk that I would even be able to. If you, in some way, “sell” your retrofit service or product in the US, let me know as there are quite a few I’d like to do myself (power tailgate, kick to open, etc..)
soi3847160.50 |
02-29-2024, 05:05 PM | #11 |
Rep 24
Drives: BMW G20 ///M340i xDrive
Hi very nice car and I'm enjoying watching your YT channel for DIY, keep it going
Did you figure out how to install Active Ventilation Seats? I can see that it can go directly from G80 M3 or X3M, X4M and M8, but from G80 its all straight fit because pattern also can be matched with rear bench, and rear bench is also with heating option. I also noticed (but I'm maybe wrong, maybe our can be just coded) that front ventilation module IHKA has to be changed from G80 ones and recoded to G20 any info regarding this retrofit
2020 G20 M340ix Individual 1997 E39 540iA Last edited by CaleCro; 03-01-2024 at 02:07 AM.. |
soi3847160.50 |
03-16-2024, 08:32 PM | #12 | |
161
Rep 77
Hk's booster is only subwoofer wired. Bot bw booster is mid & subwoofer. |
03-20-2024, 04:56 PM | #13 |
67
Rep 35
Wow, so many questions!
Do you have a part number for the trunk upper cover and the under hood insulation or are they custom? For the M340i Diffuser + Exhaust, I saw online I would need a new bracket too. Is that the case? If you ordered diffuser brand new, did it come painted? For the brake upgrade, did you need to change anything other than calipers/pads/disks? |
03-20-2024, 07:47 PM | #15 | |
161
Rep 77
hood insulation is a genuine part. trunk upper cover sold by AliExpress. diffuser needs to change the bracket and has glossy black or carbon color. For the brakes, you can buy the m340i used parts set. As a rule, the booster and cylinder should also be replaced for 4p only, but it doesn't matter much.
Pickle of the Turk67.00 |
03-20-2024, 07:48 PM | #16 |
161
Rep 77
I put in English subtitles separately as possible, but I'm sorry for the incorrect part because I did automatic translation.😢
Davg31110.00 |
05-03-2024, 12:55 PM | #17 |
Rep 5
Love how it’s turned out bro it looks amazing everything looks original i would never ba able to copy that!
I am curious tho about the iDrive controller i have wanted a crystal controller and gear for a while but will the touch control still work? As always keep up your amazing work |
soi3847160.50 |
05-03-2024, 06:40 PM | #18 | |
161
Rep 77
hybrid-flipper3.00 |
