10-28-2019, 05:28 PM | #1 |
40
Rep 637
Hi there I have wired the escort radar to my rear view mirror and now I have an issue of the radar picking up the laser signal all the time it seems not working right I have had it wired on the f10 with no problems any one have this issue please let me know thanks
10-28-2019, 05:36 PM | #2 |
2269
Rep 3,293
Gesture control uses emitters that trigger the Laser detection.
Search, there are many posts/threads on this with various work arounds. I turned laser off on my V1. Laser not commonly used here. Mike
10-29-2019, 03:34 AM | #3 |
260
Rep 560
Drives: '23 M5 Comp
I don't use the gesture control, so this is what I did on my car with the sensor. Had to keep the ///M theme going.
11-11-2019, 05:37 PM | #5 |
564
Rep 640
That is true, laser detection is ostensibly worthless. If your detector can pick up the laser signal, it means you have already been pinged. Might as well turn off the laser detection feature on the radar detector.
11-12-2019, 05:50 AM | #6 |
264
Rep 272
Only workaround is a laser jammer which is mounted outside the car anyway.
11-12-2019, 07:20 AM | #7 |
15
Rep 47
Have you factored in that the law might hit a car in front of you causing an alert??.......
11-12-2019, 05:39 PM | #8 |
369
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
Because of the nature of laser, that is very rare. The reflection of laser light off of other cars is scattered and not strong enough to detect easily. 99% of the laser alerts you get with a radar/laser detector are direct hits and mean you have already been tagged.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. |
A Need For Speed377.50 subterFUSE563.50 |
