10-27-2019, 08:30 PM | #1 |
34
Rep 63
Correct tire pressure?
My 2018 M5 has YOKOHAMA 19" tires and now that its getting a little colder, I am getting low tire pressure message. Do you set the pressure based on what computer tells you or the recommended pressure the door jamb. just curious...
10-27-2019, 09:55 PM | #2 |
235
Rep 838
32 front, 33 rear like the door jam says. I used 3 pounds higher once and you can definitely the harder ride (maybe cause mine is a comp pkg)
19 MBB M5C
16 Yas MarinaM4 (gone) 05 E46 M3 HPF/ProEfi Stage 2.25 (Gone ) |
10-28-2019, 10:10 AM | #3 |
155
Rep 317
i use what's on the door and when it got colder the car started warning me and requesting a higher pressure . i guess it's an update needed to resolve the problem as stated in another thread.
10-28-2019, 05:41 PM | #4 |
2267
Rep 3,281
It is odd, the car states the proper pressure in the dash app as a function of temperature outside I guess. It's always different.
Mike
