F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F80 M3 controls arms install questions
Extreme Powerhouse
      01-10-2024, 10:40 PM   #111
milanski
milanski's Avatar
10
Drives: 2016 B58
Crazy, I just replaced the thrust arms /tension strut and didn’t think about upgrading to f80 🫠.
Is the consensus to upgrade the f80 lower control arms and tie rods, or is the lower control arm ok to do alone? Also, thoughts on the thrust arm being upgraded to f80 as well?
Thanks!
      01-10-2024, 10:47 PM   #112
jjjccc
Drives: bmw f30 335i sedan
henry at bimmer world has aftermarket bushings for the original thrust arms that will center back our tires once or when u do the install F80 lcas.
      01-11-2024, 11:02 PM   #113
milanski
milanski's Avatar
10
Drives: 2016 B58
Thanks man, I'll reach out to him. Appreciate it!
      01-16-2024, 07:13 AM   #114
WallaceK
Drives: F30 320i
2014 320i  [0.00]
Thanks!
I advice to go with the tie rods too. IMHO the F30 tie rods will be a bit too short to be safe to ride, specially if you drive in bad roads. It can be done with the F30 tie rods tho
      04-17-2024, 01:24 PM   #115
Ausmurry
24
Drives: 2017 340i Mppsk THP
Well I did the f80 control arm swap, and also tried to install some et30 18x9 ARC8 with 255/40r18 RE71RS tires. Definite rub, Gotta figure out if I can roll fenders and do a caster camber plate to adjust, or if I need to ditch the M3 arms.
      04-17-2024, 03:18 PM   #116
jjjccc
apex told me 245 40 18 is highest u can go without rubbing. and thats without f80 arms.
danb19791968.50
f30post
