Cylinder head cover gasket brand recommendation?
04-28-2024, 02:59 PM | #1 |
Rep 20
Hi guys,
I'm planning on replacing the head cover gasket on my 2010 330i while doing injectors + oil catch can. The part number is 11127544368 - there are quite a few brands that I've seen make this gasket. Given that this part is not the easiest to replace, I'd rather get one that lasts the longest. What is your recommendation for a particular brand? Is Febi Bilstein any good - they seem to make lots of parts and I got the impression that they are good quality. At the same time they are often the cheapest of any brand - which is a bonus if the quality is there! The brands I can see for this part are: Febi Bilstein topran DrMotor Ajusa elring victor reinz elwis glaser Appears from reading the Internetz that elring, Victor Reinz and febi are top choices with elring likely being OEM. Last edited by s5s; 04-28-2024 at 03:17 PM.. |
04-29-2024, 05:10 AM | #2 |
624
Rep 3,200
Drives: E92 325i MSport Coupe
I would recommend replacing the whole valve cover, not just the gasket. Often there are hairline cracks in the plastic and/or the PCV system is clogged/shot. My indy tells me he always does cover with gasket as he's replaced too many gaskets only to find the cover needs replacing shortly afterwards. Just a thought...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
04-29-2024, 02:44 PM | #3 | |
Rep 20
04-30-2024, 02:33 AM | #4 |
624
Rep 3,200
What do you know of your car's service history? If it's been BMW serviced with long oil change intervals, there's a good chance the PCV system will be clogged. If you can afford it, I'd still say change the cover as well as the gasket...
04-30-2024, 07:20 AM | #5 | |
220
Rep 364
Drives: 2007 BMW 328xi E92 6mt swap
