EXXEL Distributions
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M3 (F80) and BMW M4 (F82) General Forum
      11-26-2012, 01:53 PM   #23
Boss330
Boss330's Avatar
1718
Drives: BMW
The blue handle fuel nozzle IS for E85 (at Statoil gas stations anyway):
Statoil warns against using E85 on a regular car due to the issues associated with etanol on gaskets, fuel lines etc. SAAB used specific fuel system components on their E85 models.
In the US there has been 10% etanol added for a number of years, meaning that US cars might be more compatible with E85? On the other hand I doubt that BMW and other manufacturers choose different material for fuel components for the Euro vs US versions.
GM stopped using different materials in 2005 after no ill effects had been detected from E85.
Maybe the E85 "issues" is just a urban myth? Something for Mythbusters to investigate
      11-26-2012, 02:02 PM   #24
DASHOCKER
The power of V!
DASHOCKER's Avatar
Germany
99
Drives: 2007 335i coupe steptronic
1998 Lexus Gs400  [0.00]
2010 ebony & ivory  [0.00]
2006 BMW X3  [0.00]
2009 pics  [0.00]
2009 e92 335 xdrive  [0.00]
sayeth what? "mabby" you should pass this on to our boy gugs..
2007 335 coupe Alpine white, steptronic, sportpack, etc. (gone)
2006 X3 3.0 steptronic Titanium Silver, 2009 E92 335xdrive, next.... Caddy CTS_V! 13 Lincoln MKZ? hmmm.
      11-26-2012, 02:05 PM   #25
rado
Drives: F30 328i M Sport
So why didn't the "astute witness" just ask the test driver if he was intentionally filling with E85? Even if the test driver didn't want to answer the question, it would likely be obvious from his reaction whether it was intentional or not.
-Ed
2013 F30 328i M Sport
2008 Lotus Exige S240
      11-26-2012, 02:14 PM   #26
mkoesel
Moderator
Drives: No BMW for now
Thank you for verifying.
The EPA has ruled that cars built from MY2007 onward for US sale are safe for up to E15. Cars built from model years 2001 to 2006 may be safe for that blend as well. Cars built before that are most probably not (and will accept E10 at most).
For any blend above E15 (and especially something as high as E85) I cannot imagine that it would be safe for use as a general practice in any arbitrary vehicle (even if the ECU was programmed to make proper use of it or at least allow for it). As someone mentions above, some other countries employ higher ethanol blends as standard practice. This fact may mean that some manufacturers decide to build all cars on a worldwide basis (or at least some models, particularly global ones) to run on such higher ethanol concentrated blends without incident. But I certainly would not make that assumption. There is more than likely some room for error (say, E20, as an example), but I think E85 could make non-metal engine parts (gaskets and seals) break down.
      11-26-2012, 02:15 PM   #27
FogCityM3
FogCityM3's Avatar
499
Drives: M3 (E90) & Porsche GT3 RS
Yeah, knowing what exactly went on at the scene probably has more explanatory power vs the fact that E85 was pumped in. It is weird that a presumably German BMW driver isn't able to properly identify which side the fuel door is, which then begs the question, was it a German driver.
As far as E85 efficiency, I thought E85 can be well harnessed in turbocharged engines with reasonably high compression ratios, if the engine is specifically built/tuned for E85. Here's something that was tested on a vehicle from now defunct Saab, where more power was acheived with no penalty in efficiency:
http://www.popsci.com/cars/article/2...oes-it-quicker
Originally Posted by mkoesel View Post
Emissions may be better (I don't know, honestly), but efficiency is generally worse.
http://ask.cars.com/2008/07/e85-gas-mileage.html
So any decrease in emmisions on a per unit of fuel basis may be negated by the fact that you will probably need more fuel to cover the equivalent distance.
I am sure BMW has explored E85, and probably has ongoing tests involving the alternative fuel. But I have my doubts that the F80 M3 is part of this research.
      11-26-2012, 02:18 PM   #28
macadam
macadam's Avatar
Sweden
Drives: 320D M
I ran my BMW 1991 E36 320i on E85 for 3years and 50000 kilometers.
I just put in a new Walbro255 fuelpump, used larger injectors and aftermarket engine management system.
Ran just fine! No issues at all with gaskets etc. Passed emissiontests yearly!
E85 has had a bad reputation but that is probably since all the ethanolcars so far have been made in order to be able to run regular fuel as well.... 13:1 - 15:1 in compression for a N/A engine on E85 should show much better mileage and economy.
Mythbusters would probably find that regular fuel is more corrosive that ethanol on most hoses..
It's only untreated aluminium that will show signs of wear/corrosion. So plastic or stainless steel is better material for the fuelrail!
      11-26-2012, 02:21 PM   #29
mkoesel
Moderator
We can only speculate, but, perhaps he did not want to embarrass the gentleman, or he just did not feel comfortable approaching a stranger, especially one driving a test car whom we all know would prefer to go about his business with the least amount of attention and drama.
Also, it is not clear to me from the account that the test driver didn't correct himself on his own before fueling up (or at least putting too much fuel in). Maybe the photographer started to walk over so as to keep the guy from "bricking his car" and before he could, the mistake was corrected.
      11-26-2012, 02:22 PM   #30
SoCali E36
BMW Client Advisor
SoCali E36's Avatar
Drives: X5 40e/e36 M3 Sedan
anyone else notice that it does not have the power dome or a hood vent
      11-26-2012, 02:22 PM   #31
Boss330
Boss330's Avatar
1718
Drives: BMW
According to the datasheet from Statoil the European 98 octane gas does NOT have any etanol at all.
Table 3 lists the contents of the fuel:
http://www3.statoil.com/MNE/SVG02326...2?OpenDocument
E85 (still Table 3):
http://www3.statoil.com/MNE/SVG02326...A?OpenDocument
      11-26-2012, 02:24 PM   #32
Boss330
Boss330's Avatar
1718
Drives: BMW
The corrosive quality is due to the fact that etanol can contain more water and that used to be a problem on older fuel tanks etc.
We used to have a couple of cars that were converted to run on CNG. Worked fine for a long time... Until the catalysts disintegrated and the cylinder heads corroded (the combustion chamber in the head looked like it was smouldering away... Very pourous). Ending in a cloud of smoke and a major engine rebuild...
      11-26-2012, 02:32 PM   #33
mkoesel
Moderator
Yes, that stands to reason I suppose. Ethanol, I believe, in general has a higher octane rating than standard petroleum based fuel, so the more of it you use, by that reasoning, the higher octane the blend will achieve. If an engine is built to properly take advantage of that (higher compression, rather than just spark advancement for example), it would naturally be more efficient than one that was not.
I see macadam has basically covered this point in his post as well. His points about corrosiveness are good too. I admit my knowledge is limited here. What I would say, then, is that, building an engine to run on higher concentrations of ethanol may require the use of certain materials which aren't used in general for engines that just run on E15 or lower. It would probably not be a good idea to go testing out E85 blindly or mixing in E85 with your E5-15 just to see what happens.
      11-26-2012, 02:33 PM   #34
GOLFFRR
GOLFFRR's Avatar
10817
Drives: GOLFFRR cart
interesting. makes you wondering seeing how he pulled into the pump on the wrong side. lol
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST!
Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101
vipfinance@bmwofcamarillo.com for warranties!
      11-26-2012, 02:37 PM   #35
bimmerjph
bimmerjph's Avatar
Drives: 2005 Z4 3.0
Correction: GM found no ill-effects during the warranty period.
      11-26-2012, 02:43 PM   #36
mkoesel
Moderator
He was probably all flustered after running from the spy shot paparazzi.
In seriousness, he may have a car with a driver's-side fuel neck for his daily. I'm not sure if that would rule out all BMW's, but perhaps not Mini? I don't know. Or maybe these guys don't make enough to scrape together the funds for a BMW. I think they cost about twice what they do over here, no? For the money, I might choose a Focus ST or something else with more power than a 316d.
      11-26-2012, 03:34 PM   #37
AhsanU
i can haz horsepowr ??
AhsanU's Avatar
3830
Drives: inconspicuous white van
I severely doubt BMW will ever make a map for E85 fuel.
And if they did.. could you imagine how much they'd charge for that?
Dakar Yellow G80 M3
Ivory White Interior
@dakar.g80 #savethemanuals
Gone but not forgotten: 991.1 GT3, F80 M3 ZCP, E46 M3
      11-26-2012, 03:45 PM   #38
antzcrashing
antzcrashing's Avatar
Drives: 2018 BMW 440i GC
I must be missing something, why is it considered an advancement if the bmw can run on e85 cant my e90 run on it without issue? That stuff is all they have at some usa stations
      11-26-2012, 03:50 PM   #39
positiveions
positiveions's Avatar
Lebanon
961
Drives: 19 Tacoma, 16 Golf wagon
That's interesting.
      11-26-2012, 03:55 PM   #40
727jbh
727jbh's Avatar
Drives: 2020 M8 GC Donington Grey
E85 = 8 mpg city/10 mpg highway
2020 M8 GC Donington Grey Metallic
2013 M5 Moonstone Metallic (sold)
2011 550i Dark Graphite Metallic (sold)
2007 750Li Black Sapphire Metallic (sold)
      11-26-2012, 04:15 PM   #41
Pentium
Pentium's Avatar
Drives: BMW 335i
2011 BMW 335i  [0.00]
lol It seems he is totally lost!
The Best Is Yet To Come!
E36 - E39 - E53 - E60 - E87 - E90
      11-26-2012, 04:36 PM   #42
jerseygirl
Drives: 2010 e92 m3
Originally Posted by M ETT View Post
Here's hoping that the M3 will cope
i dont care about green or ethynol i only care about Power and SPEED.
      11-26-2012, 05:28 PM   #43
Diver
Diver's Avatar
Drives: Black '12 135i - Sold
Most US petrol is now E10. E15 is expected to be rolled out soon. E85 is difficult to find in central Houston.
      11-26-2012, 05:52 PM   #44
135Pats
135Pats's Avatar
Drives: A few BMWs
people run e20-30 with frequency in their n54/5s, for the most part there havent been any real issues other than maxing trims...if youre tuned for it, you can run more aggressive mixes than those stated above. You dont want to throw a full tank of e85 in, but a modest mixture with pump can add power while smoothing out timing. Its really not that weird or exotic for the test driver to see how the car likes it.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII
Tags
2013 bmw m3, 2013 bmw m4, 2013 m3, 2013 m4, 2014 bmw m3, 2014 bmw m4, 2014 bmw m4 coupe, 2014 m3, 2014 m3 engine, 2014 m3 forum, 2014 m3 torque, 2014 m3 weight, 2014 m4, 2014 m4 coupe, 2014 m4 torque, 2014 m4 weight, 2015 bmw m4, 2015 bmw m4 coupe, 2015 m3 engine, 2015 m4, 2015 m4 coupe, 2015 m4 torque, 2015 m4 weight, bmw f80, bmw f80 forum, bmw f80 forums, bmw f80 m3, bmw f80 m3 e85, bmw f80 m3 engine, bmw f80 m3 sedan, bmw f82, bmw f82 forum, bmw f82 forums, bmw f82 m3, bmw f82 m3 coupe, bmw f82 m3 forum, bmw f82 m4, bmw f82 m4 coupe, bmw f82 m4 engine, bmw f82 render, bmw f82 renders, bmw f82 video, bmw f82 videos, bmw f83, bmw f83 m3, bmw f83 m4, bmw m forum, bmw m forums, bmw m3 e85, bmw m3 flex fuel, bmw m3 forum, bmw m3 forums, bmw m3 n55, bmw m4, bmw m4 coupe, bmw m4 coupe forum, bmw m4 coupe video, bmw m4 coupe videos, bmw m4 forum, bmw m4 forums
f80post
