11-14-2022, 11:08 AM | #46 |
Rep 11
For all those that are seeking a solution to the Fuel level, I have a workaround that will allow you to see fuel and much more data than the AiM preset offers for F-Models straight from canbus.
I will need to be able to remotely access your AiM display to load the preset, it can be done for the MXG, MXG 1.2, Strada and street icon versions. Last edited by Project_Rogue_Motorsport; 11-14-2022 at 11:14 AM.. |
7
11-14-2022, 10:18 PM | #47 | |
Dom
1080
Rep 1,721
12-20-2022, 03:19 AM | #48 |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
ROBM2C is this the part # for the surround or do you mind sharing where you ordered from?
Part# 51458323945 Thanks
-2021 M2C, HS, 6MT
-AST 5100, AP Racing 9660, BMW-788M, RF-GT4, BW-TA5R, APR GT 250 Wing & Front Splitter -TMS Diffuser, TMS F80 Skid Plate, HEX Armor PPF, CAN-Checked Data Logger, RaceBox -Recaro Pole Position , 2kBody Half Cage, Pinnacle Motorsports Half Cage (On order), CAE Shifter -Remus Race + BR EL Mid |
12-21-2022, 06:55 PM | #49 |
314
Rep 438
Correct that is the part number I ordered from my dealer .
CoffeeLife397.00 |
02-02-2023, 10:35 AM | #50 | |
78
Rep 127
That is the correct part for the dash surround. There is none available in the US when I checked in Dec 2022. Ended up getting one special ordered from Germany but I decided to install a dash surround from Wilvern motorsport instead. If anyone needs an Aim MXG 7-inch dash surround I have one!
1997 Dakar M3
1999 Cosmos M3 2004 Imola M3 CSL clone 2017 Alpine White M2 Performance Edition |
02-02-2023, 01:25 PM | #51 | |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
-2021 M2C, HS, 6MT
02-11-2023, 07:47 AM | #55 |
78
Rep 127
Hey guys, mounted the Aim MXG and ran into an issue. The Aim MXG still needs the original instrument cluster connected to the vehicle since it acts as a conduit for the CanBus to get the needed signals such as fuel level, odometer reading, etc.
Per Martyn at Project Rogue. "If you want to run the AiM permanently then you can disassemble the original instrument cluster as much as possible without damaging the internals, wrap it in something protective and hide it behind the dash. But it is not recommended if you plan to switch back to the orginal cluster. However, you can still hide it somewhere behind the dash in near full size without the outer case." Can you guys that mounted the Aim MXG share what you did to mount the instrument cluster? The stock dash wirings are short. TIA!
1997 Dakar M3
1999 Cosmos M3 2004 Imola M3 CSL clone 2017 Alpine White M2 Performance Edition Last edited by imolam3; 02-13-2023 at 05:32 AM.. |
02-19-2023, 06:31 PM | #56 | |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
-2021 M2C, HS, 6MT
04-05-2023, 07:24 PM | #57 |
Rep 20
Does anyone else have issues with the fitment of the dash surround. Mine doesn’t seem to fit in the space correctly. Mine is RHD so I’m not sure if that is the issue but the clusters are the same part number for both LHD and RHD so not sure that’s the problem.
Anyone have any suggestions of how to make it fit in correctly, maybe I’m not doing something right when trying to put it in? Also anyone found a way to get the fuel level and oil pressures working without having the cluster still installed? |
05-03-2023, 04:28 PM | #58 |
78
Rep 127
Some updates. Martyn got my Aim dash working with all the needed parameters. However, the OE cluster is still needed. I ended up wrapping it with foam and bubble wrapped the crap out of it and zip tied it under the steering column area.
I used the precalculated gear function with the published gear ratio for the M2 in the Aim math channel to get the gears to display on the dash but for some reason, it only reads correctly in gear 1-3. In 4th gear, Aim dash is showing 3rd, 5th is showing 4th, and 6th is showing 5th. Aim support couldn't help so I ended up adjusting the 4th gear ratio in RS3 and got it to work to display in 4th gear. Now just need to do the same in 5, and 6th.
1997 Dakar M3
DRLane3996.00 |
