M2 Technical Topics > Track / Autocross / Dragstrip > B-street setup
      06-05-2023, 09:29 AM   #375
Charles33982
Drives: 2021 Silver M2C
Originally Posted by Lappy View Post
Also no rubbing at all with 255/35/19s in the front.
Just to confirm, this was on the Apex 19x9's? What is the offset?
Trying to determine if I can pull this off on my 21' M2C on the OEM wheels assuming I'm around -2 front camber.
      07-18-2023, 01:36 AM   #376
Phab
Drives: 2017 BMW M2 LBB DCT
For the OG M2, 275/35R18 and 295/35R18 in RE-71RS the way to go?
      12-14-2023, 12:36 PM   #377
daeqsw
Drives: BMW M2
How much more competitive is the M2C in BS?
      12-24-2023, 08:58 PM   #378
E90convert
Drives: F87 M2 DCT, F15 X5
Looking at previous pro solo records, looks like its a wash. The M2C is heavier, but has more power. The OG M2 makes torque sooner in the RPM band, and is a bit lighter.
      02-24-2024, 11:12 PM   #379
mykrrrr
Drives: Perhaps an F87 M2
Originally Posted by dabootski View Post
I've run a set of MCS 2 way, non-remotes custom built for B Street on my OG M2 the past couple seasons and will be posting them for sale soon if you're interested. These were purchased from Jeff @ ProPartsUSA with his recommended valving. My co-driver Jay and I had much success running these at SCCA national tour events the last 2 years and really felt they improved the handling the car, especially on lower grip sites which we struggled with the previous 2 years on stock dampers.
The improved handling from compression increase unfortunately does come at the expense of a harsher street ride. If that's a concern, I wouldn't hesitate to valve these a bit softer as we never ran them anywhere near full stiff except at Lincoln airpark which is a high grip surface. One other thing to consider with the MCS/ProPartsUSA setup is the slightly different end link mount location on the strut. I had custom length Ground Control endlinks built for this since the Dinan end links were too long. Those will come with the setup.
Where did you get those spring perches from? I looked at ProPartsUSA and didn't see it listed.
      02-25-2024, 04:34 PM   #380
GJMills
9
Drives: BMW
I’m also wondering if anyone has tried this combo. Especially a direct comparison to Falken 660 275/35/19 and 275/30/19.
      02-26-2024, 04:06 PM   #381
mykrrrr
Figure I would update this post with my solution to a 100 percent legal MCS shock. You need to either cut your stock perches, or find some from a member that did the sleeved lowering kit. Once you acquire the stock perches the modifications are relatively simple, cut the bottom of the perch level, removing the endlink tab completely, and clamp it on the mcs with collars top and bottom. You can line the mcs shock where the stock perch will sit with a 12 inch inner bicycle tube to ensure a tight fit and no wiggle prior to clamping, also assures the perch is centered on the shock. Once you center and clock everything, measure from the hub to the top of the perch on your stock shock, and set the MCS to be the same. From memory this equaled about 7 and 1/4 inches on my car. Let me know if you guys have any questions.
Attachment 2779290
Attachment 2779289
Attachment 2779288
Please note, that current offerings are not legal and you can be protested if someone wants to go that route. Flipping the spring upside down is not legal, running supra perches is also not legal. Unless you want to have a spring perch made, this seems like the easiest option that retains correct orientation of the spring, includes isolators and clocks everything the same as factory. Let me know if you have any questions.
Lappy, is removing the stock perch difficult? Is it a press fit item?
      02-26-2024, 04:30 PM   #382
Lappy
220
Drives: 2020 BMW M2C 2018 BMW M4
You can press or hammer them off. Look up any HAS install video to get ideas of what works best for you.
      02-27-2024, 02:08 PM   #383
mykrrrr
Thank you Sir.
      02-27-2024, 06:25 PM   #384
not.ramos
Enthusiast
not.ramos's Avatar
Drives: 6MT 20' HSM M2C
18x10 +25 with a 275/35/18 Nitto NT01 sits nicely.
IG: brandon_rramos
ULTRA MOTORSPORTS
      03-15-2024, 10:47 AM   #385
mykrrrr
Anyone running RT660's in on a base F87 in BS? Wondering how the compare to RE71RS's
      03-15-2024, 06:25 PM   #386
GJMills
9
Drives: BMW
I did last year. They are very similar. Bridgestones are a hair quicker and have a little more grip in cooler temperatures. I had to run a different front tire size so it’s not a direct comparison.
m2
