01-08-2022, 02:26 AM | #68 |
Rep 73
how far is wheel off center just using the m3 control arm without m3 tension strut? is it visually noticeable? any one have problems after install? will an alignment shop raise hell about it when they go to align it or can they align it like factory specs for the f30 335i and be done????
i was actually runnin it hard on hwy in high winds and had that slow sway left to rt/hard to keep straight. i already hate the electronic power steering. so i thought this may help me im just not convinced yet/ does it actually help this in headwinds? Last edited by jjjccc; 01-08-2022 at 02:39 AM.. |
01-30-2022, 10:21 AM | #69 |
Rep 8
Hello,
This is my first post here, i'm french, so sorry for my bad or non appropriate language. I would like to install F80 LCA on my F31 330D RWD, so i read everything i can in the internet and there is a lot of good informations here. in my opinion OEM F80 LCA are a bit expensive so i found that Delphi seems to provide the good ones, at a really good price. Does anybody install that LCA ? can you confirm that the lenght (365mm) is the same as the OEM LCA ? Thanks a lot for your answers LCAF80 by |
01-31-2022, 11:53 AM | #70 | |
Rep 73
01-31-2022, 03:12 PM | #71 |
Rep 10
Aren't the BMW ones from Lemförder as reported by some other users where Lemförder 38258 01/38259 01 should be basically the same as BMW 31122284529/31122284530 but with M logo brushed off (and almost half the price).
01-31-2022, 03:44 PM | #72 | |
522
Rep 1,148
02-01-2022, 12:03 AM | #73 | |
Rep 73
02-01-2022, 06:07 AM | #74 | ||
522
Rep 1,148
Delphi are aftermarket to oem spec, lemforder is the oem supplier to bmw for the f80/f82 arms, when you do find lemforder and purchase them, the m logo is ground off. |
03-16-2022, 07:45 PM | #77 | |
1615
Rep 3,958
Stick with genuine unless there is going to be a quality alternative like MeyleHD or Lemforder. |
03-17-2022, 07:28 PM | #78 |
115
Rep 1,004
ive had the delphi for a year with 3 track days and so far so good. about 5000 mile on them. which bushings failed? inner or outer? i also installed the thrust arms same time from rockauto.
08-19-2022, 12:03 PM | #80 |
Rep 77
how about these adaptable caster bushings?
the idea is to be able to put the F80 arms and not rub. https://powerflex.es/es/f32-f33-f36-...le-avance.html |
08-20-2022, 11:27 AM | #81 | |
Rep 8
If you have F80 arm, with F80 polybushes, you certainly need some washers to fit. |
08-20-2022, 11:47 AM | #82 |
Rep 8
Hi,
As you helped me a lot, I will (finally) report back on my assembly of F80 LCA and TS. I used Delphi TC3884, TC3885, TC3586, TC3587 arms. These are not original BMW M parts as the logo is not present and not erased. Regarding the LCA, the assembly is identical to the original and the wheel moves forward a lot and rubs the wheel arch, but it is possible to drive the car like that. As I adjusted my parallelism myself, note that the steering rods must be lengthened by 8 turns. Regarding the ball joint of the xenon sensor I took at the graveyard a little ball joint on a Mini R56 Several weeks later I installed the TS with Stronglex polybushes. Bad idea. The width of the F80 arms is greater, so the polybush does not install correctly (system with two half shells) with a washer I managed to install it but there were squeaking noises in the suspension. Finally I put back OEM silent blocks, reference Lemforder 36954 01 and it works very well and i do not took pictures I am really very satisfied with this modification, the steering of the car reacts better, it is more incisive and precise, for the moment the wear of the tires is good and is no longer on the outer edge. Another important point the visual aspect is much better with negative camber .... |
FrankDK173.00 |
09-05-2022, 03:01 PM | #85 | |
65
Rep 127
Also, this thread contains several notes about the inner tie-rod being close to (or at) it's limit. Has anyone tried the M-series inner tie rod? It's a different part number from the F30 inner tie rod, but the outers are the same.
2017 430i w/ Strut Brace / M-Perf brakes / M-Sport anti-sway / 255/40/18 square / iDrive-6
09-05-2022, 05:04 PM | #86 | |
Rep 8
But with TS/LCA F80 arm it does not rub the wheel arch. the idea of installing F80 inner tie rod crossed my mind. But as i told few months ago we need to lenghten them for 8 turns when we install F80 arms. When the car is stock, the inner tie rod is screw for about 15 to 20 turns. |
10-17-2022, 02:10 PM | #87 | |
65
Rep 127
So, the question now becomes how the F80 corrects this issue. Is it in the Knuckle. the Subframe or both?
11-19-2022, 05:50 PM | #88 |
Rep 27
Just sharing my experience with the F8x LCAs on my 335i since there is information missing in this thread about the retrofit.
Because the F8x LCA’s are longer than the F30’s the wheel gets pushed forward (positive caster) as stated in this thread already, and introduces 2 problems: 1. How to correct the caster/push wheel back to avoid rub in the front - I decided to install caster adjustable bushings on the OE thrust arms instead of opting for the F8x thrust arms, as many have stated that they do not correct the caster. The bushings I went with are PowerFlex part No. PFF5-1901G black race series and I believe can be adjusted to +/-4 degrees . Before taking the oem thrust arms off, I could tell that the bushings were worn as I could see cracks in the rubber and was able to rock the arms a bit by using force. This would result in a lot of deflection once under load. The powerflex bushings are solid and have no deflection, which I was worried would make the ride harsh, but they’re surprisingly not too bad. They did push the wheel back slightly but not to the original position which is fine with me. The steering is way more sharp and the car turns in much easier even after the LCA install. Also, braking has improved dramatically since there’s now more camber and less deflection in the bushings. 2. Because the F8x LCAs are longer, the OE tie rods need to be threaded out pretty far. - After installing the F8x LCAs there was only about a 1/4 inch left on the tie rods which made me really nervous. I didn’t find any info on whether the F8x tie rods fit the 335i so I took a gamble and ordered them. The outer tie rods are interchangeable, ie same for F3x and F8x. The inner tie rods are definitely longer by about an inch compared to the OE 335i rods. However, they thread right on just like the OE rods and worked out perfectly. Did this for peace of mind but I think it’s also a must if you’re doing this retrofit. Imagine you hit big pothole or some sort of road imperfection, the shortened rod could possibly snap or bend as a result. Alignment specs in the front are now LR -2.1/-2 Camber, 7.7 caster and 0.12 toe. https://www.fcpeuro.com/products/bmw...-31122284529kt https://www.fcpeuro.com/products/bmw...9389kt#fitment https://www.powerflexusa.com/shop/pr...=1790#attr=515 Hope this helps. Last edited by Marq_z; 11-19-2022 at 08:58 PM.. |
Pussiwillow522.00 |
