eBay Bluetooth Streaming Box DIY and Reveiw
06-14-2018, 09:26 AM | #45 |
260
Rep 714
Nick-
I've read through this, and if I understand correctly- since I have the CD changer option on my screen already, I can go ahead and run through this install without any coding at all? It's essentially install the box, and have Bluetooth streaming with steering wheel controls? I'm a 2007 e90 without idrive, with the HK Logic 7 professional head unit. The ebay link declares idrive. I'm also wondering why you're so inclined to install idrive in your car. Any idrive car I've ever been in is so outdated, that I'm glad my car is a non idrive. I personally prefer the classic simple dash of BMW's though.
06-14-2018, 01:55 PM | #46 | ||
1489
Rep 1,917
My iDrive retrofit was under $450 and iDrive cars hold a 1k premium over non iDrive cars. At that price why not and I can make my money back selling the old parts. |
06-18-2018, 06:38 PM | #47 | |
Rep 78
06-19-2018, 02:39 AM | #48 | |
627
Rep 2,099
This device leaves a single DAC process at the deck (or MOST system). Already a better potential. Whether you can notice the difference is what’s debatable and personal. |
06-19-2018, 07:32 PM | #49 |
1921
Rep 13,128
Y cable uses the aux for the actual audio .
We know the aux is crap. Might be closer to a usb stick played directly through the usb port. |
06-19-2018, 09:14 PM | #50 |
1489
Rep 1,917
06-20-2018, 10:26 PM | #51 |
Save the manuals!
6035
Rep 6,754
If you have 6FL or even AUX and a cigarette port in your armrest, this is all you need:
https://www.amazon.com/FIREFLY-Small.../dp/B01HDO66NK
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
06-21-2018, 10:32 AM | #52 | |
1489
Rep 1,917
Thorin117.50 |
06-22-2018, 10:26 AM | #53 |
125
Rep 445
Anyone know another person who sells this box. This seller has been away and when he comes back I bought the box and he disappeared again? He womt take payments and I'm getting payment past due notices from Ebay-_-. Wanna follow the OP and just do.an idrive retrofit.
08-06-2018, 03:49 PM | #54 |
Rep 9
I successfully added this to my 2006 BMW 325i.
The only thing I cant seem to get to work is activating Siri with the steering wheel button (face). I can hang up the phone with the steering wheel "phone" button though. Am I missing something? |
08-06-2018, 03:56 PM | #55 |
1489
Rep 1,917
I am not sure if the box supports that.
09-25-2018, 05:42 PM | #56 |
2197
Rep 1,322
Just installed one of these in my car (with some help from Nickco43 on the coding). Id say the audio quality is the same if you have a GOOD aux connection. I had to replace my jack once already because the pins were worn and Id lose a channel from time to time. I checked the bitrate and codecs using a bluetooth sniffing app and its not supporting any other codecs so the quality is going to be limited. Just open SBC.
If anyone sees one that supports aptx (or aptxHD even better) or LDAC lemme know. I looked at all of the more expensive versions that came up and nobody really mentions that. Not a shocker though, it requires a license fee to support the codec. Honestly bluetooth itself is the limitation, but it was $150 to gain steering wheel controls, see the song on the radio screen and to get around the Android "absolute volume" bug that seems to be an issue with all of the chipsets these amazon bluetooth receivers use. The only caveat of this box so far that has me side eyeing it is its sleeping. It seems to go to sleep when I lock the car but I havent figured out how long until it shuts off bluetooth when the car is just off. If its anything like android over a dumb bluetooth interface (which is what this is, nothing proprietary) then its a long press on the play button. So there the limitation would be something translating the voice dial button to a long press, which I doubt BMW even cared enough to send that information to the radio. |
09-25-2018, 07:16 PM | #57 |
1921
Rep 13,128
but it does have usb and sd card playback which is totally
dependent on what kind of files you put on those. Radio or idrive power should make it switch off the same time those do. regular bluetooth should be better than aux because the aux in a BMW really trashes the signal from phones. Last edited by ctuna; 09-25-2018 at 07:22 PM.. |
09-25-2018, 07:26 PM | #58 | |
1489
Rep 1,917
09-25-2018, 08:17 PM | #59 | |
627
Rep 2,099
https://www.ebay.com/itm/True-HiFi-B...5.c10#viTabs_0 I do something similar (well similar in that it goes direct to the amp) for a Hiby R3 device that I have. Powered via USB-C to USB-A that plugs into 12V usb adapter in center console. Run that along side my Tune2Air. So device up front and powered, but RCA lines run to the back (could run optical, etc as well, just like the device above). Control via iPhone (Hiby has an app that lets you browse and control playback on the R3 remotely). So if I want to go pure HIFI utilizing the SABRE DAC in the R3 straight to analog, I control it that way. I have it set off an DRC-100 to swap input presets. You lose steering control while in that mode, but you can software control the R3 for volume (or set gains where you want it via the amp). |
09-25-2018, 08:31 PM | #60 |
1921
Rep 13,128
Trouble is all the other solutions go through the AUX which is
the bottle neck for fidelity. There was a big thread in which the final analysis was DAC plus aux still not as good as USB direct. |
09-25-2018, 09:20 PM | #61 | |
2197
Rep 1,322
Id say you are right. I doubt the combox is using any advanced coding either, just SBC like everyone else, which is the weak point for bluetooth. APTx gets you to CD quality, then there are a couple others that can beat it a bit.
Not knocking the box, just clarifying for those who might be considering this that its, unfortunately, not going to provide true CD quality audio but its going to be likely as good as a "good" AUX connection AND give you bluetooth controls. I think a box like this WITH one of the other codecs would be awesome, but not even the $300+ options mentions it and if you paid for the license you are definitely putting that all over your marketing material. Quote:
Anyone experimented with how many songs you can have in a folder on the SD card? I see it sees each folder as a CD but can it have a 45 track CD? If so I might just load it up as a backup option as well, which each "CD" being a playlist. Last edited by ryan stewart; 09-25-2018 at 09:29 PM.. |
10-01-2018, 07:00 AM | #62 |
2197
Rep 1,322
Couple more follow ups:
1. I confirmed, NOBODY is using anything but SBC for bluetooth audio. Not Grom, m2, whatever. So no point in spending $300-500 for the same audio quality (they advertise all of these DACs but it wont matter in this scenario) since the audio encoding of bluetooth is the weak point. 2. You can put a TON of songs in a folder and it will just cycle through them as a virtual CD. 6 folders and 60 songs worked easy on mine. 2b. the catch being this box doesnt go to the last selected source, it goes to whichever source is gonna feed it when it starts up. Since the SD card reads immediately and bluetooth takes a second it means its going to default to the SD card and start playing and you have to SWITCH it to the bluetooth. I just wanted the SD card as a backup so I just removed it and it went back to bluetooth as the initial starting source. Wishing I had done this years ago. |
11-05-2018, 09:45 PM | #63 |
78
Rep 239
Is the new bluetooth box only active when the CDC input is selected? The reason I ask is that otherwise you risk "losing" your audio into an inactive bluetooth "blackhole" if you're on another input, but your phone is connected to bluetooth. Happens to me all the time with my aux bluetooth input. It's a pain to connect and disconnect all the time.
11-06-2018, 06:44 PM | #64 | |
1489
Rep 1,917
11-06-2018, 09:16 PM | #65 | |
78
Rep 239
Any thoughts on connecting this somewhere more accessible so SD cards can be swapped easily? Maybe the glovebox or the trunk? For that matter, is there a MOST connection in the trunk for the CD changer that could be hijacked? Routing the USB cable to an accessible location accomplishes sort of the same thing I suppose. |
11-06-2018, 10:04 PM | #66 | |
1489
Rep 1,917
Thorin117.50 |
