06-12-2020, 04:52 PM | #1 |
38
Rep 70
Drives: 22'G80 M3 18'F80 M3 18'GLC63
M550i Suspension install issues.
So I had the H&R m550i springs installed on my 19'M5 after reading many positive reviews. My installer had told me the driver side rear was throwing a error. He cleared the codes and we drove it no issues. 2 days later I got a error saying "Chasis Function limited" and the car no longer lets me select my suspension setting. So I wanted to ask if anyone has had a similar issue with install or if I ordered the wrong springs. My springs are model H&R 28721-2. Thanks in advance.
06-12-2020, 05:28 PM | #2 |
Perennial PFC
336
Rep 1,274
This is just a guess, but I doubt it's your spring choice. More than likely it's the electrical connection from a rear shock absorber. Either it got pinched on install, or the connection is loose. Easy to check if the wires have been routed properly. Could be front also, but much less likely.
06-12-2020, 05:35 PM | #3 | |
4062
Rep 5,231
06-12-2020, 06:11 PM | #5 |
38
Rep 70
He definitely connected it as he dropped the shock to check it was all set most likely it broke like you said. And yes I didn't think it was H&R just wanted to check my springs were in fact the correct ones.
06-12-2020, 06:13 PM | #6 | |
38
Rep 70
