BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Do I need wheel spacers?
      10-30-2018, 11:25 AM   #1
DallasLife345M
Drives: Uber
When my car arrives I’m going to upgrade the rear tires to 295’s and the fronts to 285’s. That’s roughly .5” wider on each. Will I still need wheel spacers to be flush?
      10-30-2018, 02:01 PM   #2
zuschnell
zuschnell's Avatar
556
Drives: '19 m5, '18 991.2 gt3,
Just depends on how flush you want. The offsets are already pretty aggressive for stock. You will be adding 5mm to the outside by increasing tire size. Most people are going about 10-12mm for spacers. Just looking at my car, I really don't think it needs very much. I'm planning to go with larger tire sizes as well and likely holding off on spacers for now.
Gone but not forgotten: '10 X5M, '14 550ix, '17 M3 zcp, '11 aw e90 M3 zcp, ?11 sg e90 M3, '17 X5M, 19 F90 M5
Current: ?13 e92 m3 ESS 585, 22 f95 x5m Comp, Track - '18 manual 991.2 GT3, Wife's family truckster - '20 Volvo XC90 T8
      10-30-2018, 02:44 PM   #3
DallasLife345M
Drives: Uber
I’m leaning that direction. I’m thinking with the wider tread I may need spacers in the front only. Guess I’ll have to wait and see once I get the wider tires.
      11-10-2018, 07:47 AM   #4
Luke1881
Italy
Drives: BMW M5 f90,
I did the same thing but I put two rims in front of the rear size, the track widened half a inch on each side, with the eibach springs and the 10mm spacers the rear wheels touch on the mudguards, so I took them off. The car is so perfect !!!
      11-14-2018, 06:57 PM   #5
DallasLife345M
Drives: Uber
What do you mean, “I put two rims in front”? I’m confused, can you explain better? Thanks
      11-14-2018, 08:58 PM   #6
zuschnell
zuschnell's Avatar
556
He got a set of rear rims (10.5" wide) and put them on the front. Then he just added 10mm spacers to the rears so they would both (front and rear) have an aggressive offset as the wider wheels in front wouldn't need to be pushed out any further but the backs still would.
      11-14-2018, 09:20 PM   #7
MWcoupe
24k GOLD
MWcoupe's Avatar
Drives: Mineral White M4
I'm thinking 12 mm front and 10mm. Will be playing with my old 12mm set when I get a chance.
