BMW X3 Forum
BMW X3 Forum
      07-23-2011, 07:58 PM   #1
XB101
31
Drives: 2011 TiAg X3 35i
Post aftermarket wheels on your X3
I searched and found a couple pictures of people with non-oem wheels.
Anyone else? Please post what you have! For me I don't know if I want to spend $3000+ on a set of OEM. Looking for a set of 18" to mount some winter tires.
Let see yours!
      07-24-2011, 02:53 PM   #2
Grzechos
Grzechos's Avatar
246
Drives: E36, E90, F80 M3, F90 M5
I was thinking about posting the same theard.
Pics wanted
      08-09-2011, 09:58 AM   #3
Looker.
Drives: 2011 X3
me too.. lol
      08-15-2011, 08:37 PM   #4
fedinand
fedinand's Avatar
Drives: '11 X3, '11 GTI
These are only 18s, but here are volk racing re30s 18X8.5 front and 18X9.5 rear - offset is 35
      08-17-2011, 10:23 AM   #5
Park2670
Park2670's Avatar
Drives: Tesla Model 3
In for more pictures of aftermarket wheels. We should also add Accessory BMW wheels to this thread as well.
      08-19-2011, 07:38 PM   #6
XB101
31
Considering the following for my winter set up.
17" Rial Salerno
http://www.tirerack.com/wheels/Wheel...racite+Painted
18" M6 Replica
http://www.**********s.com/**********s-M6Wheels.html
For tires depending on what size wheels probably Blizzak WS70, Michelin X-Ice, or Dunlop Wintersport M3 all non-RFT.
Opinions?
      08-19-2011, 09:11 PM   #7
Looker.
Drives: 2011 X3
17" Rial Salerno
18" M6 Replica
Opinions?
Wow! They are both awesome. However, I would go for the 18" M6 Replica as those wheels will keep the original BMW flavor and the gunmetal color will make X3 even more aggressive~And the price are pretty good~
I was also thinking about getting those 20" M6 Replica or VMR V710s unless **********s will have 20" X3 310M replica wheels in the future~
      08-19-2011, 11:10 PM   #8
XB101
31
Actually both set of wheels you can have BMW center caps. Only 17" Salerno available for the X3 how. There are lot of people with these on the 3 series, just do a search there. Both the Salerno and the M6 reps are nice IMO for secondary set.
bmwparts forless have 310's.
      08-22-2011, 10:02 AM   #9
XenaBimmer
XenaBimmer's Avatar
Drives: '14 328i, '14 320i
THe M6 replica wheels look awesome! I'd love a set of those in 20" for my X3, but do they make them in that size? I only saw 18/19" listed in the link above
2014 BMW 328i Sportline--Arctic White/Black, 8 speed
      08-22-2011, 12:31 PM   #10
Looker.
Drives: 2011 X3
I believe **********s have. They do have 20" rims for the M6 replica. As well as 20" for X5M, X6M rims. But X5M and X6M rims may be too wide I am afraid.
      08-22-2011, 01:03 PM   #11
XenaBimmer
XenaBimmer's Avatar
Will those 20" M6 rims fit on the X3? If so, I will probably be picking up a set of these
      08-22-2011, 03:11 PM   #12
Looker.
Drives: 2011 X3
It should. For 20" M6 rims are 8.5 front and 9.5 rear. For tires you can go with 245 front and 275 rear I guess.
Check it out here: http://www.**********s.com/20-inch-M6-Wheels.htm
      08-22-2011, 03:28 PM   #13
XenaBimmer
XenaBimmer's Avatar
Do you know if the bolt pattern is the same? I'm also wondering what the offset would look like. I don't know enough yet about the stock X3 wheels to be able to compare for fitment. I have the 18" M sport wheels for the 28i, so I'm wanting a bigger size obviously, and more offset wouldn't hurt either, however, I don't want to tires to be poking out the side of the wheel wells
      08-22-2011, 05:05 PM   #14
Looker.
Drives: 2011 X3
I would check with the BMW service department to see if that can perfectly be mounted on the X3 or not. I think bolt pattenr is the same. Offset should work fine as well cuz you have the ET35 option. The only thing I am not sure is about the tires. You can check on the BMW accessory website to check what sizes of tires they are using for the OEM M6 wheels.
Have you guys considered about the following 2:
http://www.**********s.com/X5M-Replica-Wheels.htm
http://www.**********s.com/X6M-Replica-Wheels.htm
I feel they look better if we can get them fit on the X3.
      08-22-2011, 05:14 PM   #15
XenaBimmer
XenaBimmer's Avatar
So my 18"m sport wheels are a 35 offset? As Lomb as the bolt pattern and hub bore would match, I think the m6 wheels would work because the tire width should fit without rubbing.
The XM wheels may be to wide though. Personally, I like the M6 look better
      08-22-2011, 05:54 PM   #16
Looker.
Drives: 2011 X3
Yeah, you are right. XM Wheels may be to wide. However, I've notice the suspension of the X3s are quite high and it may fit those wheels. And that's also need to double check with the service department. I am pretty sure 10" Wide is definitely good for Rear wheels but not sure if 10" Wide is also good for Front. The stock fronts are 8.5.
Also, have you considered the VMR wheels? They do look nice too!
      08-22-2011, 11:14 PM   #17
XB101
31
Those are also $900+ a wheel. Too rich for me :-)
      08-23-2011, 08:21 AM   #18
XenaBimmer
XenaBimmer's Avatar
I was under the impression that the price listed was for a set of four, so the 20" M6 replicas would be $1000 for instance. Am I wrong? If so, $1000 is far to much to pay per wheel for replicas!
      08-23-2011, 08:47 AM   #19
ManitouX5
ManitouX5's Avatar
51
Drives: BMW X5e 2024, X3 2018, SL 550
http://www.replika.ca/component/opti...d,6/Itemid,55/
      08-23-2011, 10:26 AM   #20
Looker.
Drives: 2011 X3
Originally Posted by ManitouX3 View Post
Nice website for Canadians. But there is no 20" wheels available tho...
      08-23-2011, 10:27 AM   #21
Looker.
Drives: 2011 X3
Yeah. 1000 for a set for sure. Otherwise it will be even more expensive than the real OEM ones.
      08-23-2011, 06:16 PM   #22
XB101
31
Here is a question. +35 offset would stick out more than +45, or is it the other way around?
xbimmers
