M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > M2 N55 over revs/boosts between shifts
      02-21-2024, 06:45 PM   #1
Harry_11K
Harry_11K's Avatar
Drives: F87 M2 N55
I've had my 18' M2 for a few months now and have an interesting problem.
The car is currently running BM3 stage 2 93 tune.
In comfort mode only between shifts at around >60% throttle when clutching in the RPM's will jump up.
Example: 2-3 shift at WOT, clutch in at 5500 RPM the RPM will jump to 6000+ RPM. Definitely doesn't feel safe. It does not happen in sport or sport+ only comfort. Also didn't occur with the stock tune flashed.
I have a feeling this might have to do with the diverter valve but any input would be great. (Not sure if my car has stock DV or not)
      02-21-2024, 06:59 PM   #2
ericlr1225
ericlr1225's Avatar
Drives: 2018 M2 LCI 6MT
any clutch/shifter mod?
      02-21-2024, 07:23 PM   #3
Harry_11K
Harry_11K's Avatar
Drives: F87 M2 N55
Just a clutch delay valve (CDV) delete. Happened before removing it though. And no amplification of the issue after being removed.
      02-22-2024, 05:11 PM   #4
Harry_11K
Harry_11K's Avatar
Drives: F87 M2 N55
Going to run a few datalogs and add it to the thread.
      02-23-2024, 09:15 AM   #5
designatedposter
175
Drives: m235i
do you have latest version of the tune? i recall bm3 made some tune changes for shifting logic in the m2 n55 a while back.
i recommend you reach out to bm3 help directly.
M235i rwd 6mt
      03-04-2024, 07:50 PM   #6
Harry_11K
Harry_11K's Avatar
Drives: F87 M2 N55
Reached out to BM3 with datalogs and they said boost spikes are normal when you let off throttle. Waiting to hear back from them since I attached this video now.
Each time you see the RPM’s jump is when I clutch in. Also forgot to mention in original post that I have a CDV delete.
video
      03-05-2024, 11:05 AM   #7
ericlr1225
ericlr1225's Avatar
video
I'd run ISTA to check first and re-calibrate the throttle.
If the issue remains, check plugs and injectors. Logs would help
      03-05-2024, 11:50 AM   #8
Harry_11K
Harry_11K's Avatar
Drives: F87 M2 N55
I have to find someone with ISTA but good point. Here is the logs.
https://bootmod3.net/log?id=65e2aa7dc589af3c359f0d7a
https://bootmod3.net/log?id=65e2aa7d909e963e4e3c2157
      03-07-2024, 06:38 PM   #9
Harry_11K
Harry_11K's Avatar
Drives: F87 M2 N55
Update 3/7/24:
Recieived a test map from BM3 and the issue is resolved. Great support as always!
m2
