M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Lag between shifts...
      03-02-2020, 09:50 PM   #1
Nezil
Nezil's Avatar
1404
Drives: LCI '18 6MT M2
I can't remember who posted it, so I apologise for not giving credit where it's due, but I'd heard it suggested that the lag between shifts with the 6MT is a software thing, and not true turbo lag.
This bothered me quite a bit, mostly because it went against established thought, including my own thoughts on the subject, but it could explain why this lag between shifts
a) doesn't improve by making engine modifications that in theory should
b) doesn't happen when shifting above 6,000 rpm.
I'd also heard that this phenomenon also happens with the M2C. The S55 is fundamentally very similar to the N55, but the induction system is different enough that I'd expect a different characteristic between shifts.
So I started investigating this a little deeper by looking in to some logs. These logs were captured with 100% accelerator pedal input, shifting from second to third but before 6,000 rpm.
I'm no expert at reading logs, but it appears that the Waste gate Duty Cycle trace shows the waste gate opening after I've got back on the gas, for a period of 1 second. This prevents boost from building until it again goes to 100% duty cycle and boost again climbs.
I have some questions then about this finding:
  • Can anyone comment on if I'm reading this log data correctly?
  • Can anyone comment on if the 6MT S55 M2C also has this behaviour?
  • Can anyone comment on if the DCT OG MG (or M2C) has this behaviour if you shift manually below 6K rpm whilst flooring it?
  • If this is a software defined / controlled behaviour, can it be fixed or improved in a tune?
2018 ///M2 LCI, LBB, 6MT...
Current Performance Mods:
CSF FMIC, ER CP, Fabspeed Cat, Aquamist WMI, GFB DV+, NGK 97506, BM3 (Stage 2 93 OTS), CDV delete, UCP, M2C/M3/M4 Strut Brace, M3/M4 Reinforcement Rings
Appreciate 3
243Racing1447.50
David.m437.00
      03-02-2020, 09:57 PM   #2
243Racing
1448
Drives: M2
Funny, I started a thread with a similar question, but yours is much better.
Subbed for info
No shit? Isn’t the optimal shift point around 5500 though?
      03-02-2020, 10:21 PM   #3
Nezil
Nezil's Avatar
1404
So the chart above was a shift at 5,800 rpm. I tried on the way home today logging a shift at 6,600 rpm:
To my surprise, the WGDC still drops for 1 second, but the turbo lag was definitely less noticeable. To be honest, I had to brake immediately after the very short pull, so I need to test again on a bit more of an open road.
I'm not sure this clears anything up... The WGDC drops lower than my other log with the earlier shift, but it still drops and slows the boost building.
One other thing that I think is worth noting, is that in the earlier shift, the boost drops to as low as 1.6 psi, whereas when I shifted at 6,600 the lowest the boost went was 4.5 psi. The duration I was off the gas for the shift was slightly longer in the lower rev shift - 0.12s @ 5,800 vs 0.07s @ 6,600.
243Racing1447.50
      03-02-2020, 11:40 PM   #4
Anthony1s
756
Drives: 2018 Mineral Grey M2
I have a DCT but am not 100% sure what you're asking for. If you want me to shift while 100% on throttle (most of my logs are this way). Or apply 100% throttle, let off and shift, then reapply 100% throttle. (doubt this exists in many of my logs as it's not something I normally do). Repeating these both above and below 6000rpm.
Just in case I've already done what you're asking for, here are the previous logs I've taken. Maybe the condition you're looking for exists in them.
http://www.bootmod3.net/log?id=5e18b4b2c090c660d027da23
http://www.bootmod3.net/log?id=5e18b461c090c660d027da1d
http://www.bootmod3.net/log?id=5e179de4c090c660d027d6a2
http://www.bootmod3.net/log?id=5e179d34c090c660d027d69b
http://www.bootmod3.net/log?id=5d70036ac090c652e3aa39b1
http://www.bootmod3.net/log?id=5ce6e0cdc090c61a0ab45557
http://www.bootmod3.net/log?id=5d6ece54c090c652e3aa34c3
http://www.bootmod3.net/log?id=5d6ecec5c090c652e3aa34c5
http://www.bootmod3.net/log?id=5d6ed0cec090c652e3aa34cc
http://www.bootmod3.net/log?id=5d6ed12dc090c652e3aa34cf
http://www.bootmod3.net/log?id=5d700199c090c652e3aa39af
http://www.bootmod3.net/log?id=5d7001bfc090c652e3aa39b0
http://www.bootmod3.net/log?id=5cc1cf55ae729b069556a605
http://www.bootmod3.net/log?id=5ce6df7ac090c61a0ab45556
I let off to 30% throttle in this log between shifts:
http://www.bootmod3.net/log?id=5ce6e1ffc090c61a0ab45558
      03-02-2020, 11:54 PM   #5
Nezil
Nezil's Avatar
1404
Since you have DCT, I think it would be helpful to see logs of fully floored 100% throttle upshifts at < 6,000rpm and at > 6,000 rpm.
In fact, just thinking about it, you would know if there was lag between shifts. 1 second feels like an eternity when you're upshifting, and while logs would be useful, subjective feeling is actually more what I was asking for.
      03-03-2020, 12:12 AM   #6
Anthony1s
756
In fact, just thinking about it, you would know if there was lag between shifts. 0.1 seconds feels like an eternity when you're upshifting, and while logs would be useful, subjective feeling is actually more what I was asking for.
I don't think my feelings are the best way to go about resolving your question. I'm too busy thinking about how cool I am when I shift, my mind isn't on lag.
What you want is in those logs though. Towards the end of the pulls is where I would be shifting below 6000rpm. Just don't have the motivation to look through them myself.
///M TOWN16566.50
      03-04-2020, 11:17 PM   #7
mr_lab_rat
mr_lab_rat's Avatar
565
Drives: 2017 M2, 2018 X1
I'll try to do some logging before and after installing DV+
      03-05-2020, 12:04 PM   #8
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
WG% does not indicate lag. It simply means how much exhaust flow is needed to quickly build boost to target or stay on target. When it shows 100%, you're off boost that's all.
For example, a laggy big turbo car, floor it. WG instantly open to 100% and stay there for like 5-6 sec, before anything happen.
The channels you really need to look at, are 1) pedal input %, 2) torque request, 3) load target and 4) MAP.
Pedal input is driver's intention.
Torque request is how ECU react to your input.
Load target is the calculated load that's actually going on, not the target of load literally.
MAP is the actual boost the cylinders are seeing.
If you monitor above channels closely, I believe you're smart enough to figure out where the lag comes from...
Lemania 2320
Appreciate 2
      03-06-2020, 02:16 PM   #9
Nezil
Nezil's Avatar
1404
Thank you so much for stepping in @SeanWRT, I know you're a master of interpreting logs.
Yes, I understand this, but I think you've missed my point. I can feel that the car is off boost immediately following a shift, but at that point, WGDC is not at 100%, it's quite a bit lower. After about 0.1s it seems to behave normally, hitting 100% until boost target is reached and then dropping to control it.
I don't have Torque request logging currently, but will turn it on for future runs. The chart below is the same data capture as my first post in this thread, but with Accel. Pedal now shown, along with MAP rather than Boost (Pre-Throttle). You can clearly see that once I get back on the gas after the shift, there is a delay before the Load Target and MAP rise up, and it seems to be caused by the WGDC not hitting 100%.
From what you've said, it looks like the Torque request might be the missing piece of the puzzle, and if this truly is causing this 'lag', then it's a software issue that could be potentially improved... Can you think of any reason why the DME isn't allowing boost to build correctly for 1 second after a shift in 6MT?
      03-06-2020, 02:54 PM   #10
GeraldM2
Drives: BMW M2 (F87) LBB 6MT
The lag between shifts could also have something to do with the CDV. i recommend doing the CDV delete and seeing if that helps
      03-06-2020, 02:55 PM   #11
Nezil
Nezil's Avatar
1404
Good call, but I've already done that. UCP too.
      03-06-2020, 10:15 PM   #12
chris719
7334
Drives: '08 M Roadster
Yeah CDV definitely isn't it. I've removed the CDV on my Z4M and it's just not the same effect. The CDV is barely even noticeable when you're driving hard.
      03-06-2020, 10:53 PM   #13
SeanWRT
SeanWRT's Avatar
3179
From what you've said, it looks like the Torque request might be the missing piece of the puzzle, and if this truly is causing this 'lag', then it's a software issue that could be potentially improved... Can you think of any reason why the DME isn't allowing boost to build correctly for 0.1 seconds after a shift in 6MT?
Hi Nezil,
WG is a not a direct control of boost. It's the DV dumping boost and throttle opening angle that dictate how much MAP cylinders see and get.
When WG delay to close to 100%, as part of the boost control decision ECU make to handle torque/load to pedal input, turbo shaft speed is not so off, given current and anticipated torque demand.
You really need to turn on torque request to see how it's delayed to "ask" the system to serve you...After that, for a turbocharged car, MAP(IAT and timing being equal) got a lot of say on how much power it's really making. So...follow pedal input, torque request, MAP/load target, would be my suggestion.
In my market there is no manual BMW today. I don't have experience of it...
Lemania 2320
      03-07-2020, 12:08 AM   #14
chris719
7334
Hi Nezil,
Is your thought that it could be tuned out if it's a torque request delay or limit BMW implemented on purpose for safety?
      03-07-2020, 12:20 AM   #15
Nezil
Nezil's Avatar
1404
Yes! That's absolutely my thought.
It seems that 6MT is far more popular in the US than in other parts of the world, and even here it is the minority choice. I have a feeling that in part, this characteristic may have been overlooked because many tuners have DCT cars and not 6MT.
I did capture some logs with Torque data this afternoon though, so I'm going to dig them out now and see what we find... stand by...
      03-07-2020, 12:24 AM   #16
Nezil
Nezil's Avatar
1404
Unfortunately the logs didn't save. I'll try again over the weekend if it's not raining.
      03-10-2020, 11:39 PM   #17
Nezil
Nezil's Avatar
1404
OK guys, sorry it took so long to get this log. I had issues where BM3 wasn't creating logs, and I was able to fix it by force updating the OBD agent.
So here we have a log with Torque Target as suggested by SeanWRT. This was a second to third gear shift at 5,600 rpm, with the accelerator pedal floored. As we saw before, there is WGDC dip as soon as the clutch is released for a period of exactly 1 second. Boost still climbs, but much slower than when the WG closes and what I'm trying to understand is why it doesn't just close instantly? Why is it preventing boost from building when the Accelerator pedal and Torque target both suggest that boost is needed?
This really does look like a software 'feature' of 6MT, and it's robbing us of power and response between shifts unnecessarily.
Your thoughts SeanWRT?
      03-11-2020, 01:40 AM   #18
SeanWRT
SeanWRT's Avatar
3179
So here we have a log with Torque Target as suggested by SeanWRT. This was a second to third gear shift at 5,600 rpm, with the accelerator pedal floored. As we saw before, there is WGDC dip as soon as the clutch is released for a period of exactly 0.1 seconds. Boost still climbs, but much slower than when the WG closes and what I'm trying to understand is why it doesn't just close instantly? Why is it preventing boost from building when the Accelerator pedal and Torque target both suggest that boost is needed?
Can you share the log link here or PM? Thanks!
Lemania 2320
      03-11-2020, 09:43 AM   #19
Nezil
Nezil's Avatar
1404
Here's the link to the log SeanWRT: http://www.bootmod3.net/log?id=5e684a57d10b43215e7f315b. Ignore the stuff at the start, it's only the part at the end that's relevant of course.
      03-12-2020, 01:23 AM   #20
SeanWRT
SeanWRT's Avatar
3179
Thanks for sharing.
It's clear and my intepretation is no issue from BMW tuning. No delay whatsoever in reacting.
From the log, the shift takes 1.4s to complete, from pedal lift to it 100% back on. And in it, there's 1 full sec with 50% or lower pedal angle.
What does ECU do on pedal lift?
1) Throttle closure, which pretty much follows pedal input, as a direct and most effective manifold boost (MAP) control measure.
2) The throttle closure makes the backpressure to the compressor (the cold end of turbo). That's when DV comes in (log doesnt show unfortunately) and release the charge pressure (the boost in the charge pipe, or Pre Boost). To avoid mechanical failure. See there is a short time in the log (shown below) when MAP is cut but Pre boost is significantly higher until they're closer? That's what it is.
3) Wastegate fully open (to 0%) to release the pressure on the impeller. When DV's done with boost control, WG reacts to boost target (or torque target which ultimately is pedal input) with correct opening %. As said earlier, WG is a lagging measure for boost, and only a reflection of turbo shaft speed compared to boost target.
A simple put - Lag is from too much off pedal time.
In this particular case, when you go back to 100% pedal, the boost is already 11.8psi off (MAP=Preboost=3.4psi, rel="" target=15.2psi). See the big boost delta area. It takes a whole lot of time (another 1.3 secs) for boost buildup to target.
Revisit my conclusion - human shift is too slow, ECU has no choice but dump boost for mechanical safety. And boost takes time to recover. Hence the lag. I guess stick shift fun comes at cost LOL
Hope it makes sense.
Sean
Lemania 2320
Appreciate 3
      03-12-2020, 07:43 AM   #21
Happy Motoring
Happy Motoring's Avatar
Drives: OG M2
2017 BMW M2  [10.00]
So don't lift off the throttle?
      03-12-2020, 10:29 AM   #22
MZWIE
388
Drives: M2
Why would you shift at 5800rpm. I never shift below 6500-7000 especially if I am doing spirited driving.
m2
