05-04-2018, 12:53 PM | #23 |
72
Rep 102
FTP & CTS Turbo are by far the best quality/ looking charge-pipe in the market!
Check out this link of a fellow forum member http://*************/ctschargepipediy/
15' X5M DG, enzotune
17' M2 *** CTS Turbo FMIC, CTS Turbo DP, CTS Turbo CP, CTS Turbo Intake *** Bootmod3 E30 OTS |
05-10-2018, 05:18 PM | #24 | |
1404
Rep 1,466
You'll need 1 x 2792 size, 2 x 2793 size, and 1 x 2795 size. They come in packs of two unfortunately, but aren't that expensive.
2018 ///M2 LCI, LBB, 6MT...
Current Performance Mods: CSF FMIC, ER CP, Fabspeed Cat, Aquamist WMI, GFB DV+, NGK 97506, BM3 (Stage 2 93 OTS), CDV delete, UCP, M2C/M3/M4 Strut Brace, M3/M4 Reinforcement Rings Last edited by Nezil; 05-11-2018 at 12:08 AM.. |
05-11-2018, 12:10 AM | #25 |
1404
Rep 1,466
So in preparation for installing, I have a few questions for those that have done this before. I want to make sure I am prepared so that I can do this all in one hit.
Current Performance Mods: CSF FMIC, ER CP, Fabspeed Cat, Aquamist WMI, GFB DV+, NGK 97506, BM3 (Stage 2 93 OTS), CDV delete, UCP, M2C/M3/M4 Strut Brace, M3/M4 Reinforcement Rings |
05-12-2018, 06:26 AM | #26 | |
468
Rep 1,348
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 |
nothingman522.00 |
05-16-2018, 01:32 PM | #28 | |
1404
Rep 1,466
I'll post a photo when I get home.
05-16-2018, 04:38 PM | #29 | |
468
Rep 1,348
I think if you go vibrant I thought I read you get two in a bag which means I will have two extra as spairs?
05-16-2018, 04:39 PM | #30 |
1404
Rep 1,466
Indeed you will, but it's still cheaper. You can use the spare large one as a bracelet if you want to geek out.
squixs110.50 |
05-16-2018, 04:41 PM | #31 |
468
Rep 1,348
Probably so I agree but the Breeze ones are far greater quality and are far better than the ones that come with the FTP charge pipe.
05-16-2018, 04:42 PM | #32 |
468
Rep 1,348
05-16-2018, 11:43 PM | #33 |
1404
Rep 1,466
Vibrant clamps fitted for size testing pre-install:
Current Performance Mods: CSF FMIC, ER CP, Fabspeed Cat, Aquamist WMI, GFB DV+, NGK 97506, BM3 (Stage 2 93 OTS), CDV delete, UCP, M2C/M3/M4 Strut Brace, M3/M4 Reinforcement Rings Last edited by Nezil; 05-17-2018 at 11:59 AM.. |
Project_F871231.00 |
05-16-2018, 11:46 PM | #34 |
1404
Rep 1,466
Spare clamp worn as a bracelet:
05-20-2018, 08:09 PM | #35 |
1404
Rep 1,466
I fitted the charge pipe a few days back, and the boost pipe this afternoon. I'd say they're about as difficult as each other to install. Getting the pipes of the FMIC isn't too difficult if you follow the suggestions in the ************* post above (cable ties and bits of card).
The factory charge pipe is a pain to actually get out of the engine bay. I removed the MAP sensor first, and then wiggled it out of the top of the engine bay, but I've heard of some people going the other direction. I think if I'd have taken the FMIC out, I'd probably have gone that way and it would have been easier. Wiggling the FTP Throttle Body side of the Charge Pipe through was a bit of a pain, but actually fitting it up to the throttle body wasn't too difficult. I fitted the silicone section to the throttle body side first and clamped it down. Then I pushed the FMIC side into the silicone section at the same time as clipping on the FMIC input before bolting everything up. The Boost pipe side started off fairly easy once I worked out a way to get cable ties etc. in to place to pull of the clip turbo outlet side. The pipe is able to rotate on the turbo outlet, and that helps because the sides of the clip you have to pull out are difficult to get to. The FTP Boost pipe to turbo outlet was super easy to install, it pushes on really easy and clips in. It does feel a bit loose, but my logs don't show that it's leaking so I guess it's fine. The issue with the boost pipe is that if you assume that the silicon coupling needs to be straight, as I did initially, and is shown in my photo above, it won't line up with the FMIC inlet at all. You need to put the silicon coupling at a slight angle downwards for both the machined FMIC inlet section and the turbo outlet section. Just like the throttle body side, I clamped the silicon coupling to the turbo outlet side first, then loosely fit the FMIC inlet connection into the silicon coupling before re-inserting the FMIC, clipping everything together and bolting it down. I found that once you've clamped everything together it's a lot easier removing and re-installing if you need to, because the pipes and couplings are all in the correction orientation and clamped together. It's lining things up the first time that's the pain, and it really is quite a pain. Each side took me about two hours, but that includes removing and re-installing the belly pan and FMIC each time. If I did it in one hit with an upgraded FMIC it would probably be 3 hours all in. When my CSF FMIC finally arrives I'll have to go through a lot of the work again... At lease I know what I'm doing now!
05-21-2018, 04:29 PM | #36 | |
468
Rep 1,348
Did you use loc tight or white tape to prevent leaks ,was it necessary?
05-21-2018, 07:28 PM | #37 | ||||
1404
Rep 1,466
ceedawg467.50 |
05-22-2018, 04:04 PM | #38 |
468
Rep 1,348
I have plenty of the white plumbing tape so I guess I will use it then.
06-01-2018, 04:51 PM | #39 |
1404
Rep 1,466
I have an update on the FTP....
As I posted in my previous post, I had a CSF FMIC coming, and it arrived yesterday, so I installed it last night. This isn't the CSF Thread, so I'll leave the opinions on it for there, but I did have a big issue getting the FTP pipes on to the CSF FMIC. Initially I didn't bother taking the stiffening plate off the car, and I'm still not sure if that is necessary; probably not. I was having real problems getting the pipes to push down onto the FMIC inlet / outlet, and in the end took the machined part of the boost pipe off and removed the FMIC to investigate. It turns out that the green X-ring gaskets supplied in the FTP pipes are too think to slide over the CSF inlet / outlet. There was nothing I could do to get them to slide on. I took the stock gasket out of the stock inlet and charge pipes, and everything slid together without any issues. These are both aftermarket parts, so I'm not sure who is at fault. My guess, is that both are within tolerance, but the FTP is slightly small, and the CSF is slightly large, and the combination makes them not fit. In any case, I found a solution, so I posted it here. I have a feeling that FTP and CSF is going to be a popular combination, so it's worth detailing it!
iam2slow78.50 |
06-02-2018, 04:40 AM | #40 |
4038
Rep 3,546
Drives: 328d Wagon, M2 Comp, i4 eD35
That's weird. The X-rings on my N47 FTP pipes fit on the CSF IC I have and I was able to lock the clips on the inlet/outlets when I test fit those connections outside the car. Did you lubricate the x-rings at all?
06-03-2018, 04:46 PM | #41 |
1404
Rep 1,466
Yes, I lubricated the X-rings. The N55 boost pipe has a machined section that connects to the FMIC and it's straight and short. It was easy therefore to see what was happening; Some parts of the X-ring were crushing up agains the pipe, and others were going on. It was also REALLY stiff. I put the regular seals on from the stock parts and it just slipped on... much better!
06-10-2018, 08:36 PM | #42 |
71
Rep 112
Drives: 2017 BMW M2 - Mineral Gray
Those FTP pipes look really nice, top notch. I bought the VRSF charge pipe but after seeing this I wish I would have gone with the FTP setup. I've read that the boost pipe doesnt really need to be replaced but I'm sure it doesnt hurt to replace it with a nice quality piece like the one in this set up.
10-10-2018, 02:01 AM | #43 |
94
Rep 59
Nezil
Just wanted to reconfirm with you and others, the CSF intercooler works with the FTP boost and charge pipes? No issues with the intercooler inlet/outlet angle or width? Using the O rings that came with the CSF intercooler or the OE rings? Also, the original CSF intercooler mounting hardware issues have been addressed? Thanks! |
10-10-2018, 02:07 AM | #44 | |
1404
Rep 1,466
It's also really annoying to get the angles of the parts correct, particularly at the rubber unions. I'm going to be removing all of this before I take my car for a service next month, and bought a QuickJack to do the work this time, rather than using jack stands like I did before.
dj202093.50 |
