      11-11-2010, 03:27 PM   #23
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
Originally Posted by gadget12345 View Post
Best measurement I could get for you with the BMW SSK.
3rd to 4th throw distance measured from center of silver ring (I kept the //M gear knob and boot) was [7.125 - 5.125] = 2 inches
Seems that's about 50mm or so.
BTW: From my first gear change with it installed it was really, really noticeable.
So you have only 50mm throws with the BMW Perf SSK.
So...
6MT
N54 = 80mm throws
N54 w/Perf SSK = 50mm throws
N55 = 70mm throws
NOTE: after I had my Performance SSK installed the throws were actually 55mm's!
      11-13-2010, 09:30 AM   #24
dtwyim
dtwyim's Avatar
52
Drives: BMW no more
Not very often a bunch of guys (I assume) whipping out a ruler and wants it short!
      11-13-2010, 06:28 PM   #25
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
      11-13-2010, 09:52 PM   #26
brauheist2007
brauheist2007's Avatar
Drives: 2011 135i
Well played sir...
      03-03-2011, 03:08 AM   #27
N55_NOLE
Drives: 2008 550i
Great thread! Thanks for putting this together Dackel!
      03-04-2011, 07:45 PM   #28
Gtrain
Taiwan
144
Drives: something slowwwww
I wonder if the 1M is shorter than 50mm.
Dackel, you wouldn't happened to have measured it when you were at the Welt would ya?
      03-05-2011, 04:26 AM   #29
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
Noop. Sorry. The lady at the Welt was already giving me the evil eye when I took those interior pics - as she was showing the 1M to a VIP couple. I did not even ask her... I just opened the driver's door and took some pics. Then she locked the car back up.
I was thinking later I should have sat in the car and felt the shifter. Ohh well.
I think one of the "lucky ten" (who went to Leipzig) said the shifter was shorter then stock. Not sure IF that is shorter than Perf SSK or OEM.
Dackel
      03-07-2011, 05:01 PM   #30
Gtrain
Taiwan
144
Originally Posted by Dackelone View Post
Noop. Sorry. The lady at the Welt was already giving me the evil eye when I took those interior pics - as she was sowing he 1M to a VIP couple. I did not even ask her... I just opened the driver's door and took some pics. Then she locked the car back up.
Dackel
I think it was Woland's Advocate that mentioned that the 1M had shorter shifts in comparison to his 135i.
Here's an excerpt from what was written:
"The gearshift’s throw has been shortened and the box on the car I tried was largely slick and intuitive – you can lightly flick it between gears with speed and precision. Only a couple of power downshifts from third to second on the circuit session were a bit baulky and required a firm hand (but that may be me!). The clutch is perhaps heavier but not noticeably so. The steering actually feels lighter but, as ever, doesn’t provide a whole heap of feel through the typically plump steering wheel rim. "
Appreciate 2
      02-22-2012, 09:56 AM   #31
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
IF anyone would care to measure their N55 or 1M shofter throws... I would be interested in double confirming that the shifter throws are 70mm's from 1st to 2nd gears.
tia,
Dackel
      08-13-2012, 03:20 AM   #32
andrey_gta
andrey_gta's Avatar
301
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
6MT
N54 = 80mm throws
N55 = 70mm throws
2008 N52 128i 72-75mm at shift-knob ring
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff
"The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is
      08-13-2012, 11:36 AM   #33
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
So that is on a stock 128i ?
TIA,
Dackel
      08-13-2012, 01:49 PM   #34
andrey_gta
andrey_gta's Avatar
301
stock,
BMP SSK is noticeably shorter, prob 55mm
      08-13-2012, 02:50 PM   #35
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
stock,
You "probably" should go measure it!
      08-13-2012, 03:10 PM   #36
andrey_gta
andrey_gta's Avatar
301
I will, when a buddy returns to canada. I am stock for now debating between RE, BMP and my idea for OEM+ that may be as good as RE or UUC. UUCis too much cost, and B&M has some issues with shift knob
Btw, does ssk reduce distance to 5th gear? I really want to know if it will increase my confort with that gear shift, i dont want to move my seat
      08-13-2012, 03:27 PM   #37
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
With my BMW Performance SSK it only changed the distance to shift from 1st to 2nd gears. I know some have said that fifth gear was up further(post SSK install)... but that was not the case for me. I think those guys had their SSK installed incorrectly. The shifter arm can go in either direction.
You will not need to move your seat. The side to side distance also changed some... but the pattern and spacing is still the same. Everything is just tighter, and snick snick in gear. Shifter effort is slightly higher, but that is to be expected.
shifter SSK install.pdf
      08-30-2012, 08:53 PM   #38
dorkdog
Big Mouth No Filter
dorkdog's Avatar
Drives: 128i Montego Blue 6MT Sport
Originally Posted by davemohan View Post
I would guess that the above comparison is pretty good as it looks like both have the same knob (looks can be deceiving, though) and measured at the same point. But to take it any further you need to standardize the measurement and take the "knob height" out of it.
Perhaps a better way would be to measure it in degrees. Draw a line up your shaft (!) with a dry-erase marker and sit a protractor across the boot edge... should be able to measure the shift angle - then throw distance can be calculated as a function of knob height.
We do not inherit the Earth from our parents; we borrow it from our children
      08-30-2012, 09:15 PM   #39
Suds
/M Enthusiast
Suds's Avatar
Drives: Responsiblish
Ok, on my 2011 N55, I measured 1-3/4" in first and 4-1/2" in second, so 2-3/4" x25.4=70mm throw, it looks to be the same.
I then sat in my 92 Miata turbo with a short shifter, the difference there was the shifter returned to near center on angle after each shift, maybe sloppy but in location, so the movement was about 40 mm between each shifts, really short, grab it and ram it into gear even with a glove on.
      08-31-2012, 01:36 AM   #40
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
This is why a lot of us are so happy with the BMW Performance SSK. The throws are also 50mm's from 1st to 2nd and it really tightens up the shifter linkage. I think its one of the best mods I have done.
      08-31-2012, 02:40 AM   #41
Elsabor67
aiming for 450.....
Elsabor67's Avatar
Drives: Totaled :-(
2009 135i  [10.00]
Gonna have to measure my B&M SSK today. Will let you know.
Quote from Ezeedee regarding car mods:
"you're only done when you sell the car "
      08-31-2012, 07:52 AM   #42
BroDoze
304
Drives: Stuff
I have the newer B&M. It was pretty stiff at first, but after a year or so it was pretty smooth. Love the short throws.
///M
      02-08-2016, 10:36 AM   #43
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
Even after all these years... my Performance SSK still feels great! I buy it again(and have it installed)!!
      02-08-2016, 10:51 AM   #44
chris82
chris82's Avatar
Drives: 128i
2009 BMW 128i  [9.80]
I put the Performance SSK in my car 45,000 miles ago, still feels like it did new.
Appreciate 2
