08-15-2016, 10:37 PM | #1 |
1222
Rep 1,372
DIY Experiment - Dual Cone Filters in Custom Colors
A few weeks ago, I was reading through a thread looking at some beautiful engine bays when I was inspired to try and clean my own up a bit. My BMS dual cone filters were looking a bit dirty these days and ever since installing my amber halos, I'd thought of doing some type of amber/orange filters to break up the all black.
Here are the supplies I started with:
I used a stainless steel sink, so I wouldn't have to worry about making a permanent mess. I also watched the video published by RIT on how to use their liquid dye, and they suggest adding a bit of salt in the hot water when dying cotton and similar materials. After dissolving the salt in hot water, add a bit of dishwashing liquid to the mix. Add the liquid dye. I used about half the bottle and then stirred everything up. Slowly submerge the filters into the water and dye mixture until they're sitting on the bottom. Do the same for the second. Keep checking in on the color of the filters and remove once you get to a desired shade. After letting all of the dye/water mixture drip off as possible, I transferred the two filters to the other side of the sink. To ensure no staining, and to stay on good terms with my girlfriend, I gave the sink a good scrubbing with a soap pad. Rinse thoroughly. This may take a while before you see the bleeding colors stop dripping. Eventually the water will run clear though. I then added a bit of dishwashing liquid to the sink, refilled with fresh water, and gave the filters a good cleaning, just as I would with a dirty set. Place on a towel you don't care about and let dry. I sat mine outside on a hot summer day to speed up the process. From there I applied the Green Filter orange oil so I wouldn't compromise the intended color of the filters. Add the anodized black aluminum couplers and they're ready to install. And the final product with black DME cover and brake fluid reservoir: I can't see how dying the filters, cleaning them thoroughly, and re-oiling them would have any negative effects. RIT also comes in about every color imaginable, so the possibilities are endless.
08-16-2016, 09:29 AM | #2 |
3442
Rep 79,211
Very neat. I'm sure this dye method is probably very similar to how other companies get their color on them anyway. That or the oil used, depending.
08-16-2016, 12:29 PM | #3 |
Loves me some MHD!
1866
Rep 1,725
Good on ya for doing it yourself. Many would have just purchased a set of red filters. Frankly I think the roughly two tanks of gas money you saved and pride from a job well done brings way more value to the party.
Even better I bet it wont be long till you see a post from somebody doing the same thing, but in purple, or red/white/blue or something fancy like that. So, good on ya for opening up a nifty thing!
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla . . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg |
08-16-2016, 08:02 PM | #4 |
California-bound
385
Rep 1,480
Man, I was proud of myself for just getting mine clean again. Ha. This is great.
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
08-19-2016, 03:17 PM | #6 |
Joint Chiefs of Staff
24457
Rep 191,382
I like that, i need a new filter for my car ... Going to decide on which color to go with and give this a shot
08-19-2016, 06:20 PM | #9 |
1Addict
3239
Rep 7,906
This is great, thanks for posting it up OP.
On the other hand, take those cable traps off and tuck your wiring! Will look a ton better. They're just held on with plastic clips, the wiring tucks behind the engine cover under the braces very neatly. Ran like that for a couple months. Can easily get blue filter oil. I have some sitting in my garage, going to clean and oil them this weekend if I have time.
08-20-2016, 09:36 AM | #10 | ||
1222
Rep 1,372
08-21-2016, 10:55 AM | #11 | |
1Addict
3239
Rep 7,906
08-21-2016, 02:36 PM | #12 | |
1222
Rep 1,372
09-01-2016, 02:27 PM | #13 | |
1222
Rep 1,372
ALSO I've put about 1,000 miles on the filters and have had zero issues and experienced no color loss thus far. Still bright and tangerine-tinted!
ShocknAwe3238.50 |
