09-27-2021, 05:35 PM | #133 |
87
Rep 315
I'm kind of hesitant on dsc off 4wd sport I was going up a hill and florred it and legit ended up doing a 360 and ending up on other side of the road thankfully it was like 1 am no cars or anybody around. if I try this option again it will strictly be just for going in a straight line
2020 BMW m5 with some bmc filters, charcoal filter delete, and Dinan turbo inlets.
Previous BMW model 2018 bmw 340i FBO custom e50 tune 500 wheel |
09-27-2021, 05:42 PM | #134 | |
134
Rep 254
For 60-130 I actually use 4wd sport MDM which is safer for traction, usually there won’t be a loss of traction causing power to cut in when starting the run from say 40-50mph so it should give same results in most cases as DSC OFF while being safer. The only reason for launching in 4wd sport we need DSC off is because you need to have DSC off in order to engage launch control, but of course not for a rolling 60-130 run so in that case you can do 4wd sport MDM no problem. Also let it auto upshift as it’s hard to manually shift better and more consistently than the computer will handle it. |
09-27-2021, 05:44 PM | #135 | |
87
Rep 315
09-27-2021, 05:49 PM | #136 |
134
Rep 254
Exactly and I’m stage 2. Imagine stage 2 m5 driving in DSC off 4wd sport lol. Almost like being rear wheel driven with all that power is scary. MDM is amazing because your traction is still there (just less sensitive) and you still get the extra power kicking in from the rear bias torque split. Perfect setup for 60-130 runs without risking it flying off the road.
I found on launching its safe to use it as long as it’s good conditions for grip like hotter day, it should def not lose control, but if it’s a cooler day where traction is not ideal it’s best to use DSC off with 4wd regular. These are personally best way I found to combine performance/safety on the f90. Last edited by SatinblkF90; 09-27-2021 at 06:00 PM.. |
09-27-2021, 05:56 PM | #137 | |
87
Rep 315
09-28-2021, 09:55 PM | #139 |
1658
Rep 1,536
09-29-2021, 07:36 AM | #141 | |
3910
Rep 3,129
Regardless give the guys a call at 1-800-341-5480 this morning and they will get a return label and the correct product out to you ASAP. Will give them a heads up to expect the call when they get in. |
09-29-2021, 11:53 AM | #142 | |
87
Rep 315
09-30-2021, 12:54 PM | #144 |
3910
Rep 3,129
09-30-2021, 01:56 PM | #145 | |
1692
Rep 3,200
09-30-2021, 02:36 PM | #148 | |
3910
Rep 3,129
Would not work together as the mate points are at different points of the intake tract. The Dinan inlets go from the turbo all the way to the airbox whereas a great deal of aftermarket intakes bisect this and make the break point past the bellows section (1/2 way down the full inlet tract). To my knowledge the Dinan and OEM intakes are the only systems that will mate to the Dinan inlets. |
09-30-2021, 02:49 PM | #151 |
3910
Rep 3,129
Which G30? No plans for a 540i intake at present. Just hasnt been enough demand to warrant the resource allocation. The M550i there is demand but there just isnt enough physical room to make it work other than possibly a front mount solution but that doesn't fit our credo for a sealed solution.
09-30-2021, 04:41 PM | #152 | |
50
Rep 266
09-30-2021, 07:55 PM | #153 |
2337
Rep 2,029
Drives: INDIVIDUAL F90 M5C LCI
I love how this has the front carbon fiber piece just overtop of the kidney grills. I was blown away by Gruppe M's presentation of their Intake System for the F90 and now I'm very pleased to see what Dinan_Engineering just showcased. By chance, do you have any sound clips or videos of an F90 with this?
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG | IG: @FSHNGRY |
09-30-2021, 09:56 PM | #154 |
134
Rep 254
Is anyone at all getting a CEL with these inlets? Can’t believe I’m getting a “low crankcase pressure” CEL with these. Uninstalled and reinstalled twice, double checked everything is secure and tight. Stock inlets and cel goes away no issues at all. Even tested these same inlets on my friends f90 and his doesn’t throw a code. Both of us are even running the same stage 2 tune. Can’t believe my car for some reason is literally rejecting this mod. Very disappointed to say the least.
