09-24-2021, 11:04 PM | #112 | |
1105
Rep 1,607
Drives: 2020 M8 Comp First Edition
DA was in mid 2500 Road wasn't that great as I had some traction loss initially.
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
09-26-2021, 05:29 PM | #113 |
134
Rep 254
Has anybody else showed any real world gains with dragy using at least the Dinan inlets combined with stock air box, charcoal delete and high flow BMC/K&N filters?
09-26-2021, 05:32 PM | #114 | |
134
Rep 254
Those are the parameters but you can still launch either in 4wd regular or 4wd sport which is rear biased torque split. You should see if you run faster times on 4wd sport vs 4wd I think it makes more power on 4wd sport mode, possibly less drivetrain losses. |
09-26-2021, 05:39 PM | #115 | |
134
Rep 254
09-26-2021, 06:43 PM | #116 | ||
1105
Rep 1,607
GT
09-26-2021, 06:45 PM | #117 | |||
134
Rep 254
09-26-2021, 06:52 PM | #118 | ||||
1105
Rep 1,607
GT
SatinblkF90134.00 |
09-26-2021, 07:06 PM | #119 |
213
Rep 548
Doubt you will see much gains in that sense. Feels like it spools faster, helps with guiding boost, but the way these cars change the timing, you’ll never have the same timing back to back or the same DA. Hit 500ft less da will give you more of a performance gain.
09-26-2021, 10:50 PM | #120 | |
134
Rep 254
Are you saying basically only in hotter weather they would be more beneficial with less power loss in the heat vs stock inlets? |
09-26-2021, 11:44 PM | #121 | ||
1105
Rep 1,607
GT
SatinblkF90134.00 |
09-26-2021, 11:49 PM | #122 | |||
134
Rep 254
09-27-2021, 08:44 AM | #124 |
213
Rep 548
I mean when you’re stage 2 and pushing 800hp… are you going to feel 10hp?? I really doubt it. I’m sure they help make power, but it’s nothing you’re going to see on a draggy run.
1 degree of timing is likely 20hp on these modified engines. If you do a run and your timing isn’t identical, how are you going to quantify the results? For me, my car with JB4 is all over the place, I did a 10.34 on the street in good DA, then went to the track with race gas and map5 and went slower, 10.53 and slower every run after as timing got worse as engine got hot and da higher. Like I said, the throttle response seems better and turbos definitely spool faster, I had to modify the wastegate setting in JB4 as I was over boosting after I let install. Boost and air flow are easy on these engines.. keeping the timing up is the hard part… Last edited by AngryInch; 09-27-2021 at 08:49 AM.. |
Slugsy01157.00 |
09-27-2021, 12:39 PM | #125 | |
87
Rep 315
2020 BMW m5 with some bmc filters, charcoal filter delete, and Dinan turbo inlets.
Previous BMW model 2018 bmw 340i FBO custom e50 tune 500 wheel |
09-27-2021, 12:45 PM | #126 | |
87
Rep 315
09-27-2021, 01:16 PM | #127 | ||
1105
Rep 1,607
GT
09-27-2021, 02:26 PM | #128 | ||
1105
Rep 1,607
Blank
My Insta game is weak just couple of photos but hopefully will get on it soon.
GT
09-27-2021, 02:59 PM | #129 |
87
Rep 315
I will happily follow and ya 5.9. i saw a world record for the 60-130 be 5.9 in this forum long ago pretty sure you can beat that time
09-27-2021, 05:23 PM | #130 | |
134
Rep 254
Also, if doing the runs be sure to use 4wd sport I think it helps to improve times, with DSC off as you now know is an option. |
GTATX1105.00 |
09-27-2021, 05:29 PM | #131 | |
87
Rep 315
my inlets finally coming in the mail tomorrow but im on stock ecu tune since 2020 m5 maybe I can put a gallon of e in with 91 and get a draggy with the dinan inlets installed
09-27-2021, 05:32 PM | #132 | |
134
Rep 254
Either 4wd MDM or DSC off should yield strongest times, also using auto shift I always run better than manual shift. For 60-130. On launches unless 4wd sport spins too much it should be quicker as well but that is more dependent on situation with how conditions lend themself to traction so it can go either way. MDM 4wd sport vs DSC OFF 4wd sport for 60-130 runs won’t make a difference unless you were spinning a bit at the start with MDM possibly triggering traction control, otherwise should be identical. |
