03-24-2020, 03:53 PM | #1 |
84
Rep 346
Bootmod3 tune, launch control doesn't work
I have installed bm3 tune on my m5.
Car feels faster for sure, but the launch control doesn't seem to work. I have tried both 91 and 93 maps but the flag doesn't show. I have to manually shift, it wont auto shift. I know how to use launch control and have used it many times, Stock and with jb4. Contacted bm3 haven't heard back from them yet. |
03-24-2020, 07:55 PM | #2 |
107
Rep 411
Be careful you might have made an oversight when it was flashed:
When you flash the car, all of your preprogrammed settings default back to stock... so pressing the m2 button (if you have preprogrammed it to engage launc control) won't work ... I made this mistake Make sure everything has been reset Select Sport plus across the board Turn stability control fully off Put inManual Reset m2 button If that doesn't fix problem, then it could be a tune issue |
Jamesmick131.00 |
03-24-2020, 09:56 PM | #3 | |
84
Rep 346
03-24-2020, 10:00 PM | #4 |
84
Rep 346
You are right man, thanks alot. The car was in MDM settings changed after the flash, put back in DSC off in m2.
Will try again later. Muuaahh to you. |
03-08-2021, 12:53 PM | #6 | |
93
Rep 713
Click "Appreciate" if I helped you.
03-08-2021, 08:12 PM | #7 | ||
475
Rep 608
G80 Comp, Hcp custom e50, 9.69@141
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53 F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml. Ig @mcc420 |
03-09-2021, 08:02 AM | #8 |
93
Rep 713
Ok, thanks for the answer, so you changed some settings after car have been flashed? I mean some setting reset? Can you guide me how you are able to execute LC?
Casue a lot of people faced with the issue when LC doesn't work after flashing bootmod3 . Thank you.
03-09-2021, 09:07 AM | #9 | |
62
Rep 117
So if you had M2 button saved as predefined settings that would allow you trigger LC it won't have same settings again. You can either re-set the button to how it was before flash or just manually put the car in DSC OFF, AWD SPORT, Gearbox in S3 and it will trigger if you do everything right. |
