03-15-2020, 10:41 AM | #1 |
58
Rep 158
Jb4 stage 2 and 3 with cats?
I've been looking cant really seem to get a real answer. I know stage 1 is ok with cats. Was winding anyone running cats on stage 2 or 3. I promised my wife I would leave the cats in well atleast the primary. I'll mostly swap out the secondary. Was also wondering will the stock fuel support E85, if so anyone running E85 and what stages?
03-15-2020, 12:26 PM | #2 | |
575
Rep 754
Basically map1 is like a stage1 tune and you can run it on 91octane and no DP's. Map2 needs a little better octane and you can run with stock DP's as long as you aren't tracking it and driving it hard non stop in which it would overheat your cats and cause issues of them melting or breaking apart (neither is good) Anything after those two maps I wouldn't touch with stock DP's but I'm not exactly sure what Burger Motosports take is on it. Straight E85 is not going to work on any tune or piggy. A lot of guys are running E30-E40 but mostly on a tune where you can adjust things to adapt for the fuel. With JB4 it's a bit more tricky and most guys haven't had a lot of success running E30 on a stock tune with JB4 unless you add meth as well. Hope that helps and GL!
DME: 1848 DA 0-60 2.42 -- 1/8 Mile 6.38 -- 1/4 Mile 9.89 -- 60-130 5.91
Evolve: 1418 DA 0-60 2.48 -- 1/8 Mile 6.47 -- 1/4 Mile 10.05 -- 60-130 6.48 JB4: 1096 DA 0-60 2.54 -- 1/8 Mile 6.50 -- 1/4 Mile 10.05 -- 60-130 6.18 IG: @hockeytyme All runs on street with no prep on 21 inch wheels and PS4S tires |
Blue M558.00 |
03-15-2020, 03:51 PM | #3 | |
58
Rep 158
r33_RGSport12967.50 |
03-15-2020, 05:50 PM | #4 | |
575
Rep 754
03-15-2020, 07:01 PM | #5 |
550
Rep 949
All BMS maps are compatible with the factory cats/exhaust. It's mostly about octane levels. BMS actually suggests keeping the factory downpipes due to minimal gains but lots of odor if removed.
03-15-2020, 08:36 PM | #6 | |
575
Rep 754
I haven't seen a tuning company out there that doesn't require downpipes for a stage 2 tune. In this platform stage 1 seems to range from 20-22 lbs which is similar to Map1 on JB4. Map2 jumps up to 24/25lbs at least for me when it's acting as an additive map at +5lbs. The end result is about the same as a stage 2 with most tuning companies being 24-25lbs. Using stock downpipes and running this kind of boost is probably fine for a year or so around town. But, for consistent hard driving similar to a track is not a good idea and can cause the cats to melt or break apart over time. Neither of which has a good result. I know a few guys that ran up to 5.5lbs on map6 for months on their cars limeypride being one of them who did it on two F90s now and he never had any problems. But, he also didn't keep either car for more than a year.
onfireX53618.50 |
03-15-2020, 10:06 PM | #8 |
58
Rep 158
I dont think it's that bad, but yes it does smell. My wife cant stand the smell. My last 3 cars had no cats. So for this one I promised her I would keep them.
Hockeytyme575.00 BMWDriverX365.50 |
03-15-2020, 10:16 PM | #9 | |
575
Rep 754
Gotta keep wifey happy too!!
Blue M558.00 |
03-15-2020, 11:31 PM | #10 |
420
Rep 862
To be fair, I've never heard of anyone melting/destroying their cats by running JB4 map 2.
I see it advised to run 93 octane but no where do I see it suggested they DPs are needed to safely run map 2. I mention this for feedback as I'm about to pull the trigger on a JB4, intend to run map 2, and have no interest in DPs.
Retired 2016 BMW 550i xDrive MSport | 2013 BMW 550i xDrive MSport | 2012 BMW 535i xDrive | 1988 BMW 325ic | 1984 BMW 318i
03-16-2020, 03:13 PM | #11 | |
58
Rep 158
