03-11-2020, 12:14 AM | #1 |
Rep 21
Secondary Downpipes Installed - Review
Hey all, had a lot of trouble finding information on secondary downpipes so figured I'd share my experience. I made a late-night impulse buy a few months ago and finally got around to installing over the weekend.
Goal: A little more sound (success!) Other mods: Nothing other than disabling the ASD Downpipes: Evolution Racewerks Secondaries (~$500 shipped when purchased from x-ph ) TLDR; 20-30% louder at WOT, shifts/pops/bangs are ~50% louder. Almost no difference at idle and cruise. What's it like? Cold start: Boomier, louder (but they are boomy/loud stock so...) Warm idle: Can only tell if standing behind the car - slightly more burble Revving: Pops are much louder Cruising: Can't really tell if any different Mid-throttle: Slightly louder Full-throttle: 20-30% louder, deeper tone - just what I was looking for Shifting/Decel: Pops are much louder, probably the biggest difference How's the install? I did the install with a buddy on jackstands. Took ~4 hours. Notes as follows: - There is a tiny round gasket you need to swap over from the original downpipes. I didn't notice until installing the drivers side, so we had to redo the passenger. Whoops... - Biggest PITA is getting the v-band clamps back on. There is very little space and lining everything up is tricky. I had to climb on top of the engine to get it done. - 2nd biggest PITA is you have to remove the entire cat-back (it's one piece). That means pulling off the rear under-tray and rear cross-brace. Because of the exhaust it's definitely a two-man job. - Fit for aftermarket pipes is excellent. The v-band clamps don't close up quite as much as stock, but otherwise fitments was spot on! Final verdict For <$500 and some cursing it's hard to complain. I'm very happy with the WOT sound change, but didn't get the idle and cruise sound I was looking for (think E63 loudness). If I had known you had to remove the entire exhaust to install them, I would have gone for a cat-back instead and kept all the cats. Hope this helps. Any questions, ask away. |
03-11-2020, 11:04 AM | #2 |
Joint Chiefs of Staff
24193
Rep 190,805
Congrats and thank you for the review
Do you have any downpipe pictures you can share with us?
03-11-2020, 11:14 AM | #3 | |
31
Rep 137
I just deleted the resonator. I would say 10%-15% louder. I want a little more volume. Was considering going catless secondary. Do you recommend it? Also can you post a sound clip please. Thank you !
~Mamba Mentality~ 8/24
03-11-2020, 07:16 PM | #4 | ||
41
Rep 71
I have a comp amd just received my GT haus cat back only Was debeating between either resonator delete or secondarys Any thought? |
03-11-2020, 08:09 PM | #5 |
In the Details
1810
Rep 867
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
I have the same secondaries and they barely change the sound, now I’m thinking I’ll just do primaries too.... this car is so quiet inside, love it.
I have a Comp btw. |
03-12-2020, 12:32 PM | #6 |
Rep 21
My car is a comp too. Can't recommend mixing resonators/catbacks/etc as I haven't tried yet.
My gut is that a full cat-back is probably the best solution for sound and likely wouldn't require the removal of any cats. If I were to get a catback, I would probably put the stock down pipes back on. |
03-12-2020, 12:43 PM | #7 | |
31
Rep 137
03-12-2020, 09:48 PM | #8 |
366
Rep 804
I'm running the GThaus SGT rear section with ER secondaries and I still want more sound in idle, cruise. Idle revs and Wot sounds good, and the pops bangs are loud but you can always hit the exhaust button and it cuts off the pops and bangs leaving you with just the exhaust note. I think a full cat back eliminating the resonator and a set of secondary pipes is ideal. It's the most sound you can get without going fully catless.
06-19-2020, 12:56 AM | #9 | |
1105
Rep 1,607
Drives: 2020 M8 Comp First Edition
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
06-19-2020, 03:56 PM | #11 |
1105
Rep 1,607
Waiting on ur video eagerly
GT
BMWDriverX365.50 |
