513M Wheels and Tire Fitment on E92
03-27-2017, 05:10 PM | #1 |
32
Rep 93
Hi all, I'm looking into getting a set of 513M wheels that have the tires they came on from the factory for my pre-LCI e92. I've used willtheyfit.com as well as the size calculator at the top of the page but I just want to get some opinions as to whether I could bolt these on directly or not.
Current 193 Setup: F: 18x8 et 34 (225/35/r18) R: 18x8.5 et 37 (255/40/r18) 513M Sizes are: F: 18x9 et 29 (255/40/r18) R: 18x10 et 40 (275/40/r18) Any advice would be appreciated. Thanks! |
03-28-2017, 09:47 AM | #2 |
326
Rep 613
I'll be running 235/40/18 up front, and 265/35/18 on the rear.
An aspect ratio of 40 in the rears is likely a bit too tall, and will rub over bumps, or if you're lowered. I also believe you can fit up to 275 wide in the rears, but that may require a small spacer.
2009 E90 335i
Black Sapphire || Oyster || M-Sport || 6spd BMW-Performance||OEM+||Cobb||Wagner||CP-e||AFE||Forge||ER||BMS||Lux||RB||Bridgestone||Manz o||Bilstein||Eibach||Whiteline |
03-28-2017, 10:13 AM | #3 | |
32
Rep 93
03-28-2017, 11:34 AM | #4 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
yep definitely going to need 275/35.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
feuer4277.00 |
04-20-2017, 09:09 AM | #7 |
154
Rep 1,677
I'm running 19x10 +38 in the back on 275/30/19, no rubs and lowered. At most, you'll need a 2mm spacer to stick out a bit more. I'd try without it.
On the 513m, I'd run 265/40/18 and the front 235/35/18 but not sure if they will rub on the strut side or not. EDIT: I guess they fit on this guys E92 335i, looks like pre-LCI http://www.pictaram.com/user/jasonna...41236_30146301 Last edited by blisstik; 04-20-2017 at 09:18 AM.. |
04-20-2017, 09:18 AM | #8 |
326
Rep 613
40 aspect ratio in the back will rub.....especially if you intend to lower it.
Running 235/40/18 and 265/35/18 on my 513M. Stock suspension...for now. Fits like a glove. You could probably squeeze 275/35 in the back, if you wanted
2009 E90 335i
04-20-2017, 09:22 AM | #9 |
32
Rep 93
Awesome. Are you running a spacer in the back? I'd probably go with 275.
04-20-2017, 09:52 AM | #10 |
326
Rep 613
Nope. No spacers.
Here's how they look on my E90: Very slight stretch in the back with 265's, but still have good rim protection Alignment with the fender (kind of a bad angle, but they are pretty well lined up in person)
2009 E90 335i
04-20-2017, 02:18 PM | #11 | ||
32
Rep 93
04-20-2017, 11:31 PM | #13 |
870
Rep 2,615
Pre-LCI is a bit different to LCI and you may need spacers on the back as you are 8mm narrower.
I run 513m on an LCI E90 with 235/40 and 265/35 Michelin PSS lowered on BMWPS. No rubbing with passengers in the back and over dips/bumps. Friend runs 275/30 on his 437m in MPSS sport suspension and no rubs either. But can not guarantee on pre-LCI. |
04-21-2017, 10:26 AM | #14 | |
199
Rep 649
04-22-2017, 12:34 PM | #16 |
32
Rep 93
So I purchased a set of 513M's yesterday. Thanks everyone for the advice. I'm probably going to buy a set of 12mm spacers as well, just in case, and I'll have to get the different tires for the rear. I'll talk with the installers as to whether they should be 265 or 275.
04-22-2017, 02:28 PM | #18 | |
154
Rep 1,677
04-22-2017, 05:03 PM | #19 | ||
32
Rep 93
A guy was selling his on eBay. Had a long history of good ratings so I pulled the trigger. |
04-25-2017, 06:57 PM | #20 |
84
Rep 256
Excited to see how this turns out - I've been looking for some shots on an E92
2013 E92 M-Sport | Black Sapphire Metallic | Dinan S2 | M Performance exhaust | Wagner Evo 1 | Evolution Racewerks CP | Bilstein PSS9 | M3/Meyle HD/Dinan suspension bits | 18" AG M359, Michelin PSS
04-27-2017, 01:47 PM | #21 |
32
Rep 93
Just got the notification they were delivered today. After reading through all this again I think I'm going to go with 265/35/18 and hopefully that avoids needing any spacer? We'll see this weekend.
04-28-2017, 04:02 PM | #22 |
154
Rep 1,677
Got them installed with OEM tires 255/40 and 275/40. No rubs for me on PSS9 coilovers.
