10-02-2020, 05:20 PM | #1 |
38
Rep 70
Drives: 22'G80 M3 18'F80 M3 18'GLC63
Loud clicking noise when turning at low speeds.
Ever since I switched to a wider setup 285/35/20 295/35/20 my car has been making this loud click noise when turning or pulling out a parking spot. Sometimes it's quite other times it sounds like a loud snap. The sound is pretty worrying so if anyone has any idea what it could be please let me know. Also I'm lowered on H&Rm550i springs. Thanks in advance for the help guys.
10-04-2020, 11:38 AM | #2 | |
1104
Rep 1,607
Drives: 2020 M8 Comp First Edition
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
10-04-2020, 12:31 PM | #3 |
268
Rep 380
If I recall correctly, there was a thread about people experiencing clicking on turning a while back. Click was related to slight movement related to not torquing down a subframe plate or brace after having service done. Could it possibly be that when you had suspension mod done they did not tighten something back down to spec? I have no probs running my 285 / 295 R35 set up on 10” front and 11” rears (Titan 7). Then again I did not change our springs or lower so not one had to loosen up any components underneath.
10-04-2020, 12:36 PM | #4 | |
38
Rep 70
10-04-2020, 04:38 PM | #5 | |
1104
Rep 1,607
GT
10-04-2020, 09:33 PM | #6 |
268
Rep 380
Here lads, I found that old thread. Hope it helps and is the solution to your problems
https://f90.bimmerpost.com/forums/sh....php?t=1529616 Stiffing plate bolts need to be tightened Edit: recopied link - should work now. Last edited by northtorque; 10-04-2020 at 09:48 PM.. Reason: New info |
10-05-2020, 12:26 AM | #7 | |
1104
Rep 1,607
GT
10-05-2020, 11:00 PM | #8 |
268
Rep 380
Go to the F90 General section and the sticky thread header area that usually is hidden - at least on my phone it is. Download the F90 technical manual and check out section 3.1.1. The stiffening plate is item #4 as illustrated on the screen shot below underneath improving rigidity of front subframe. Some people have had a sound similar to what you are describing after having mods / service / etc done and it is possible the plate got loosened and then improperly torqued back up if was removed to get, say, better inner access to suspension components / etc. Not saying it is your issue but you know what they say - Either horses or zebras. Good luck
10-07-2020, 08:41 PM | #9 | |
38
Rep 70
10-07-2020, 08:47 PM | #10 | ||
38
Rep 70
GTATX1104.00 |
10-08-2020, 10:43 PM | #12 |
38
Rep 70
I couldn't agree more I asked mechanics, bmw service and friends no one knew. I'm just still in shock a couple of bolts on the stiffening plate could affect the car that much and make such a crazy noise! The more you know lol.
