09-04-2022, 03:40 PM | #1 |
262
Rep 561
Drives: '23 M5 Comp
Transmission and differential oil changes
Hi!
My 2019 has a little over 42K miles now. I got a warning light the other day and when I looked into the message it showed that an oil change is required within the next 1,100 miles. I kept probing the iDrive for a while and also found that a transmission and differential fluids changes are also required. I'm getting ready to make an appointment with the service department and I can only get the information for the oil change. Can't find where the notice for the transmission and differential fluids changes is. I just moved to a new state and this will be the first time taking the car to a BMW dealer here. Any suggestions on how to find the "missing" maintenance message? Thanks! |
09-05-2022, 07:31 PM | #2 | |
31
Rep 85
Jeffrey jaquez
09-08-2022, 06:58 AM | #3 |
5234
Rep 10,616
I just ordered the front and rear diff and transfer case fluids. Already have brake fluid and may do that this weekend. At 40k miles on my 2018. Will probably wait a year or 2 to do the trans. Did a partial coolant refresh when changing the thermostat recently and did spark plugs about 15k miles ago.
03-16-2023, 08:39 PM | #4 | |
IG: @M5RCY_
365
Rep 317
According to my research it should be 600mL Front Diff. 1 L Rear Diff. 1 L Transfer Case. Does this sound right to you guys?
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off Dura-Coating - code: M5RCY for 20% off |
