12-07-2009, 11:38 PM | #133 | |
My ride: bimmergirl84
22
Rep 302
BMW sets their factory spec alignment to basically 0* front camber and ~-1.XX* rear. So your rears should wear on the inside more than the fronts if you are using factory spec. From my experience, you can run up to -2*F and still have great tire life. |
12-07-2009, 11:39 PM | #134 |
22
Rep 302
Yes I was thinking of track pads, which should only be bedded in on a racetrack.
12-12-2009, 12:17 PM | #136 |
Supreme Allied Commander
3875
Rep 54,430
Drives: F80 M3
Without knowing your tire and road condition, it's hard to say. Did your alignment tech rotate or swap the tire left to right(dismount required for directional tires) to see if it makes any improments?
12-12-2009, 03:10 PM | #137 |
20
Rep 254
The tires were not swapped. They are stock rft but the backs are completely gone. pretty much no thread left on the inside of tires and in general the 1.8 mm marker was hit about 1 mm ago I still need to use them for 5 days until I put my winter wheels (17'') I guess I will see after changing for winters if the problem persists. The thing is that I have to drive 750 miles on tuesday to my hometown where I will change the wheels and I'm kind of worried to drive the car that slightly pulls to the left now.
135i Performance
12-13-2009, 12:26 AM | #138 |
10
Rep 224
J Tyler,
would there be any reason that the stock 135i/135i performance brake upgrades could not work on a 128i? Let's say even with the same 18 wheels. Is it a balance issue? Thinking about the performance upgrade but the 128 seems to get smaller rear brakes even on the upgrade...Thanks for the help. |
12-13-2009, 10:24 PM | #139 | |
22
Rep 302
12-14-2009, 08:56 AM | #140 | ||
111
Rep 810
Experts: I am curious to know if you agree or disagree with my response to a recent thread about a magazine's recent article about stock suspension and wheels outperforming BMW Performance Suspension and Wheels on the track.
Here is the post about the article: Quote:
12-14-2009, 11:49 AM | #141 | |
10
Rep 224
People mentioned brake bias or brake hub offset that could be different. Wondering if the 2 piston rear could work...basically similar car..? thread was here with photos: http://www.1addicts.com/forums/showthread.php?t=303409 |
12-14-2009, 06:27 PM | #142 |
381
Rep 2,926
Drives: Cayman GT4, 135i
J Tyler,
I've never tracked or auto crossed in my life and would like to get involved in these type of events. What would be my best place to start? Can I use a stock car? Thanks in Advance.
Current: M2CS
Gone but not forgotten: Cayman GT4, M2C, 2011 135i, E83 X3 6MT, 2016 SO M3, 2012 335iS, 2010 135i and 2006 e90 325xi |
12-14-2009, 08:00 PM | #143 |
28
Rep 1,035
I'm not J Tyler, but I did stay in a Holiday Inn Express last night.
...well not really, but I've been doing these types of events for nearly ten years now, and I would recommend the experience highly. I started with a BMW Club event, even though I had an Audi at the time. I've since done events with BMW, Audi, Porsche, Mini, and independent clubs, and have instructed for most of them as well. You can absolutely track a bone stock car, you'll be amazed at how capable the car is once you learn some basic skills. I would recommend going to the BMWCCA.org, finding your local chapter, and going to an event just to check it out. If you feel intimidated, you can always go just to check it out and see what it's like. You shouldn't be anxious though, because everyone's a n00b at some point, and the clubs all have easy-entry beginner classes that focus on teaching the basics of proper car control. Generally, at that level , you will do structured exercises to teach some concepts before being "let out" on the track. Of course, as a beginner, you will have an instructor with you at all times, helping you learn. I would caution you against doing any track events with an organization that does NOT require an instructor to be in your car 100% of the time during lapping as a beginner. BMW/Audi/etc clubs will not allow that anyway, but you may find some independents that are slightly more...how shall I say..."careless". But anyway - you will have a blast. Check out the BMWCCA.org website and read up, I'm sure there are events in your area. Before you know it, you'll be a junkie like the rest of us... |
12-14-2009, 10:19 PM | #144 | ||||
22
Rep 302
The reason manufacturers are doing this is to maximize braking performance in snow/rain/low-grip. Think about it - if they set the mechanical brake bias to be perfect for dry pavement when the car can stop really hard and transfer a lot of weight off the rears onto the fronts, they would need to set it to something like 70%F/30%R. If that car ever has to do an emergency stop in the snow, it will have way too much front bias (because grip is low in the snow, the car may only get to, say, 60/40 front/rear weight distribution). So they set the mechanical bias to ~60F/40R and then rely on ABS to keep the rears from locking during hard dry-pavement braking. This is something we have to live with (unless you want to try mixing brake pad material: use aggressive front pads and medium-level rears). All that having been said, I am not impressed with the factory 135i brakes. They transfer too much heat to the pads & fluid -- I boiled the Motul Racing Fluid in the 135i very quickly on track. They also do not have very good feel. The only other brakes I have tried on these cars are the StopTechs on the HP Autowerks 335i, and they are absolutely phenomenal in both feel and stopping performance. If they are in your price range, I'd look at what StopTech has to offer. But if that is out of your budget (or you have to stay OEM), the 135i brakes are fine for spirited street driving and occasional track use. Quote:
I also agree -- BMWCCA puts on good events for beginners. They are very structured/controlled/safe which is a good thing when you're starting out. However, once you progress beyond 'beginner' status and are talented/comfortable enough, and if you are serious about driving, I would look into Jim Russell/Bondurant/Skip Barber racing schools. They will teach you about the physics of vehicle dynamics, and you get to beat the crap out of their cars while learning said physics first-hand. I also recommend the book Going Faster! by Skip Barber to beginners (and intermediates). Reading that first will get your mind thinking the right way before you even leave pit lane. Personally I am not a fan of Autocross. I think it teaches bad habits: jerkiness, tunnel-vision (focusing intently on that one apex cone rather than taking a broad view of the road ahead of you), stabbing at the brakes.... these are all characteristics of every autocrosser I have instructed. Once they get on a real track, those habits are hard to break. This is why I say, just go straight to a real track. Quote:
Personally, I prefer the "careless independents" because they let me do what I want (drift, pass people, go out in different groups to get a little extra track time, etc). But I would not recommend groups like that for a beginner. Happy Motoring ya'll |
12-14-2009, 11:49 PM | #145 |
10
Rep 224
J Tyler,
Thanks a lot for the information. I didn't think it would matter but I'm pretty sure no one has put the 2 piston in the rear on the 128i. Maybe I could be the first and can review. I also heard those StopTech's were great on the E46 M3 too (as per Edmunds Insideline)..but I was fine with the stock ones on that car. Probably will be fine with the stock one's on the 135 too. |
12-16-2009, 01:33 PM | #146 |
381
Rep 2,926
Thanks for the info =)
Current: M2CS
12-28-2009, 09:47 PM | #147 |
22
Rep 302
Hello,
I recently had the opportunity to test HP Autowerks' E90 335i project car at Buttonwillow Raceway. Buttonwillow is used by everything from 'Lemons' cars to Indycars for testing, magazines for shootouts, and clubs for open track days. And it happens to be THE benchmark for TimeAttack time trials in the U.S., which is why HPA chose it for a test day: to see how their project car would stack up against the fastest street-legal cars in the country. We had just set the record for all N54-powered BMWs (135i/335i) at the Autoclub Speedway Roval in Fontana, CA with a time of 1:52.811 -- beating the next N54 car by over 2 seconds. This was at the Redline TimeAttack season finale in November. We were hoping to set the bar again at Buttonwillow -- but we knew it would be close as Buttonwillow suits the smaller/lighter 135i's a bit more. To make a long story short, we spent 2 sessions working on setup and then laid down a hot lap of 2:00.1 -- the best for an N54 car so far. What's really impressive is that this 335i is a 4-door with full interior/AC/stereo/etc on DOT tires and no wings/aero work. It is a daily driver with ~45,000 miles on the clock, not a dedicated track car. For it to run a 2:00.1 is very impressive to me (and to everyone else who saw it!). Unfortunately we did not get the fastest lap on video (SD card ran out of memory), but we did get a lazy 2:01.1. Here is some video from the day, hope you enjoy it! http://vimeo.com/8363135 As always thanks to you guys for watching and a big thank-you to HP Autowerks for trusting me with driving duties. I had a blast driving this car! |
12-30-2009, 12:37 PM | #148 |
104
Rep 2,474
Thats awesome!!
AW 135i w/ blackette, performance short shift kit, BMW alarm, Performance rotors, APEX ARC-8 wheels, Direzza Star Spec 235/275, Dinan stage 3 suspension, M3 wishbones/tension rods/front sway/rear subframe bushings and thats all folks! |
