2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning 2nd gear grind in manual transmission
      03-04-2015, 11:24 AM   #23
Wheelwright
Wheelwright's Avatar
463
Drives: M235i (6MT fakerich edition)
So, about 6-months after my gearbox was replaced the symptoms are back: grinding in 2nd gear unless making slow, deliberate shifts. I know Honda used to have similar problems but I expected more from BMW which costs twice as much and its gearbox was advertised as "borrowed from upcoming M3/M4".
      03-05-2015, 02:11 PM   #24
ocN55
ocN55's Avatar
Drives: '15 M235i 6MT/ '16 M3
hm not good.. keep updating OP
      03-05-2015, 02:36 PM   #25
2msport
Drives: '14 228 MT
dang goodluck.. Not sure about Canada but 3 times gets you a lemon law in California. Full money back. I've heard a number of cases where BMW just directly replaced the car so you don't have to go through the courts.
      03-05-2015, 05:44 PM   #26
Wheelwright
463
I think it is only applicable if they can't fix an issue after 3 consecutive attempts. In my case that's not technically correct: they fixed an issue on first attempt by replacing the gearbox, the problem is that those gearboxes tend to only last about 6-months. And before you say I don't know how to drive I drove daily Focus SVT for 8 years and then 128i for 4-years and never had a gearbox issue requiring a complete replacement.
      05-25-2015, 02:59 PM   #27
Wheelwright
463
So my dealer's foreman is denying there is a problem because even though he heard me grinding the transmission a month ago today he claims he cannot replicate it himself (he shifts slowly and barely knows how to use a manual transmission). Word of explanation: there was a month delay because back then I was told I must setup a new appointment for them to check it out and it took one month for a loaner to become available.
      05-25-2015, 03:25 PM   #28
overcoil
3074
Drives: M235i 6spd
Can you make a cell phone vid of the grind so this forum can listen ?
      05-25-2015, 03:35 PM   #29
tccox
tccox's Avatar
Drives: 2014 228i Msport
Well, I've had my 228 manual for over a year and 11,000 miles with zero issues with the 1-2 shift. Wonder if it could be a clutch related ? Doesn't make sense that two trans could go bad in six months. Some other issue causing the trans to fail ? Wierd
Edit. Sorry just noticed you have a 235. Must be all that extra power
A peasant and proud of it
Save The Manuals!!!
      05-25-2015, 05:40 PM   #30
Wheelwright
463
Actually each of those transmissions lasted about 6 months. Now the dealer is very reluctant to replace the second one even though I already replicated the grind a month ago (the foreman acknowledged it then as he sat next to me).
I will try to repeat the problem again tomorrow morning to have it in writing, this time they assured me it will actually count as "problem replication" in their documents after I pressed them on the issue.
I am surprised they themselves can't replicate it because even my brother was griding 2nd gear when he tried to shift M235i the way he does his 12-year old Mazda 3. Or maybe they say they can't replicate it only to protect BMW because two failed trannies in a row makes the manufacturer look bad.
      06-20-2015, 07:24 PM   #31
Wheelwright
463
I had an illuminating conversation with my service manager today (an approachable and courteous guy BTW). It turns out BMW already had "several" failed 6MT transmissions in the USA so they are starting to investigate their supplier (I assume BMW outsources manufacturing to ZF but I may be wrong). BMW wants to know if their supplier's manufacturing processes are up to par and in particular if the molds they use are within specs.
In view of the above my service manager told me the transmission will be replaced for the second time pending BMW tech actually being able to replicate the problem that I have (2nd gear grind and vibration when engaged relatively quickly). I guess time will tell if BMW will institute a mass recall or if it is an isolated problem. Or maybe a secret TSB will be established to address this issue ?
      12-10-2015, 11:10 AM   #32
Wheelwright
463
The dealer said my clutch components are broken and they want me to pay more than $4,000.00 (four thousand) dollars to replace them. My car only has 25000km on it (it is about year and a half). The car has transmission and everything removed so it is struck. I never abused my car, never did a burnout, never dumped the clutch and I rev-match every time.
Any advice on how to proceed would be greatly appreciated. Thanks in advance.
      12-10-2015, 09:24 PM   #33
Luftwaffe1O1
230
Drives: M235i, 2000 Z3
Well I would firstly yell at the service manager. Tell him you have complained about this for almost a year now. (I assume there are records of you complaining about transmission issues right?)
So point to him that you had been having these issues, and the techs said there is no problem. Now there is a problem... they didn't look into it.
if they refuse, contact BMW NA, if they don't get you far, contact a lawyer. I guess the one thing in your favor here is that there is a fairly long paper trail of you complaining about this.
But the biggest curiosity is that even the 2nd tranny started failing after 6months. That's odd.
      12-11-2015, 07:21 AM   #34
abirmaher
abirmaher's Avatar
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
  [0.00]
2018 BMW M2  [10.00]
That's extremely disappointing that I have to granny-shift a car which allegedly has a manual transmission "borrowed from M3/M4" (quote from official BMW propaganda brochure).
Does make a weird power drillish sound and still go into gear? Or does it just grind and not go in? If its the first, you've got a bad syncro/transmission.
I'm in this boat unfortunately. Going in for service next week hopefully I can convince them of the issue as it is intermittent.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010
The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35
      12-11-2015, 09:01 AM   #35
alexc93
381
Drives: na
I had this on my previous 135i but with 1st gear, was going to be like $6k to replace.
      02-10-2016, 12:39 PM   #36
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
Any updates?
Follow my builds:
      02-10-2016, 01:54 PM   #37
Wheelwright
463
At 25000km I had clutch and flywheel replaced for which I paid about $4800.00. Long story short: My dealer said that the gearbox grind was caused by clutch not disengaging quickly enough (due to it being worn out) which overstressed the synchro.
This bad clutch didn't even slip though because there was still some material remaining so I find it absolutely horrifying that a perfectly functioning clutch, however worn, can cause gearbox grind which in turn can destroy that gearbox (once the synchro is gone the gearbox is gone).
Also, if the gearbox grind was really caused by the clutch not disengaging quickly, why did I only have problems in 2nd gear ? Clutch works exactly the same for all gears therefore all gears should be affected.
The bottom line is: I still don't know what's going on.
Of course, despite dealer's assurances to the contrary, the gearbox still grinds after all those clutch components were replaced, however for this past year I adjusted my shifting to slow down any 2nd gear engagement.
Also I don't downshift into 2nd above 2500-rpm any more knowing how fragile my car is and that if anything goes wrong I will likely be taken to the cleaners again as I was with this bad clutch despite me never riding or dumping clutch, never using launch control etc. etc. There are many people who do those things on a regular basis and their clutch still lasts over 100000km.
I suspect that in my case I got bad parts or something was improperly installed or adjusted at the factory for which I am now made to pay.
      02-10-2016, 03:38 PM   #38
delvec03
90
Drives: 228i Sport/ DSB
your whole situation is absurd. my Rx8 had grinding gears (multiple synchro failures multiple times due to 9k red line ?) and they covered it under warranty.
if it keeps happening I'd suggest they keep replacing parts. get a lawyer. I shift 1-2 at 6500 rpm like butter. in fact, its almost like the car WANTS me to shift faster.
get lawyer and your money back and a new tranny.
      02-10-2016, 03:52 PM   #39
Luminous
Luminous's Avatar
743
Drives: 2019 M5 Competition
Wow sorry to hear you're going through this! I don't understand how they can deny warranty without proving it was user error? Especially when this is kind of a known issue with these trannies? Can't they pull data from the ecu to see if the car was abused?
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      02-10-2016, 08:10 PM   #40
kyoko
kyoko's Avatar
42
Drives: F80, G01
2017 BMW M3  [0.00]
2018 X3 M40i  [0.00]
I have a 335i and had grinding issues shifting into 2nd like you described. It was replaced under warranty. The tech said that there are a few cases of the syncro's having issues and needing replacement.
There must be BMW of CA that you can talk with or something. That just doesn't sound right. Have you tried taking it to another dealer?
      02-11-2016, 09:06 AM   #41
Pray for Mojo
430
Drives: 2014 M235i & 2018 X3 M40i
Those clowns should have replaced the clutch when they did the transmission the first time around. You shouldn't have paid a dime for any of the work.
      03-30-2016, 09:30 AM   #42
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
Update on my end. I finally found time to take my car in. I ordered a new clutch and flywheel as I was having club slip as well and figured if I was going to take it in for this maybe I could have them swap those parts at the same time. Plus seeing as how expensive Bmw seems to think their clutches are I could get way more clutch for the money from another source.
Ended up going with a clutch masters fx350 street/race clutch which I am very excited for.
Anyways I dropped the car off yesterday and got confirmation today that it seems like Bmw will be replacing the transmission. Should have a time line soon and hopefully when I get it back the issues I have been seeing are resolved.
Follow my builds:
      04-11-2016, 02:04 PM   #43
Wheelwright
463
Good news: I just received a call this afternoon that BMW has authorized a manual transmission replacement (this will be my 2nd replacement). I appreciate they are finally doing the right thing after so much ordeal: BMW is back on my list of possible future cars.
However, after what I have been through I will never push this car anywhere close to "performance driving" (not that I did in the past but I wasn't driving it like Prius either). In practical terms this means giving it at least 1-second pause between 1st and 2nd gear when accelerating in a spirited fashion.
I know if I execute that shift the way Honda or Porsche drivers routinely do without a second thought, I will destroy another transmission. As I learned the hard way one shift is all it takes in my car. This scares the crap out of me because, at least in Canada, BMW charges Ferrari prices if anything goes wrong and you're deemed at fault.
      04-11-2016, 02:41 PM   #44
B_Rice
B_Rice's Avatar
Drives: 6spd Estoril Blue M235i
Are you depressing the clutch all the way to when you shift? I've found out that the grab point is pretty much anything above the floor.
Estoril Blue 6spd M235i LSD Sunroof delete AWE touring exhaust Fabspeed sport cat
2addicts
