BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Transmission, transfer case, front and rear diff fluid change
      10-28-2021, 11:32 AM   #1
Demon Barber
292
Drives: 2018 M5, 2022 911 Turbo S
In case anyone is interested in changing these fluids down the road, I went to my local dealership parts department and had them look up the part numbers for these fluids. Attached is a pic of what they gave me, although they couldn't tell me specific volumes. I am fairly certain the diffs and transfer case are drain with either a drain plug or vacuum pump and refill to the level of the fill plug, but someone feel free to correct me if I'm wrong. Transmission, I'm not so sure. May need ista computer to purge the fluid and cycle the new fluid. Will have to research that procedure more in depth.
Appreciate 3
Holset272.50
Rup9167.00
shawnhayes1829.50
      11-11-2021, 08:06 AM   #2
Villy
Romania
13
Drives: BMW M5 F90 Competition
Any information at what KM/Miles these should be changed? I have not been able to find any official information on it and it's been a concern recently..
      11-11-2021, 09:10 AM   #3
Demon Barber
292
I cannot find any recommendations from BMW about when to change any of them. I suspect that there will not be any rec at all regarding the auto transmission fluid, as they seem to staunchly claim "lifetime fluid, do not change" but I'll definitely be changing mine, probably around 50k miles. I think I'll do diffs and transfer case fluids at 50k as well.
      11-11-2021, 03:47 PM   #4
AHall
982
Drives: 1993 Nissan 240sx
There is a maintenance manual. It lists the mileage at which certain service are to be performed. Oddly enough, the front differential is not mentioned. The service manual only goes up to 60,000 miles.
      11-11-2021, 03:48 PM   #5
Danny D
228
Drives: M5
I typically do all my main Fluids like these and coolant etc. every 50,000 KM.
Regardless of what the say, I keep my cars for a long time.
I just did the diffs, in the caddy and the front one had some silver in it, probably metal shavings.
      12-07-2021, 10:55 AM   #6
afk8445
Drives: 2018 M5 Blk sp Metallic
My 2018 F90 is requesting me to change these fluids, current mileage is 28K miles, car is March 2018, so close to 4 years.
quote from dealer is obviously way more
rear diff -->315
front diff -->315
transfer case -->408
      12-08-2021, 10:05 AM   #7
Demon Barber
292
rear diff -->315
front diff -->315
How did it notify you? Only by dealership scanning the key, or did it pop up in idrive?
      12-10-2021, 11:31 AM   #8
afk8445
dealership scanning the key.
and so, i asked for a quote.
