12-03-2021, 11:41 PM | #1 |
273
Rep 647
Driveshaft popped off after installing lowering kit
My left front driveshaft popped off after my workshop installed a Dinan Has kit.
The bolt that holds the wheel hub to the drivshaft had completely come loose after driving a bit. My installer put the bolt back in and torqued to 210nm but immediately after to try backing out it popped out again this time we noticed that the short spring thats in between the bolt and the hub was bent so he bent it back in place and then torqued the bolt to 250nm and the driveshaft has then stayed in place since. I think it's possible that the first time he assembled the driveshaft and hub he didn't got the splines in line but the second time? And what we could see the splines looked good. I since then found a video on a replacement of a driveshaft on a F10 5 series that looked to be the same design as my M5 and they torqued the hub bolt to 210nm and then 90 degrees according too spec. We then wondered if the bolts is one time stretch bolts anyone who know? |
12-04-2021, 03:21 AM | #2 | |
1105
Rep 1,607
Drives: 2020 M8 Comp First Edition
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
Holset272.50 |
12-04-2021, 06:04 AM | #3 | |
Perennial PFC
336
Rep 1,274
I have thousands of miles on the car since, with a couple track days as well and no problems with the hubs. |
12-04-2021, 08:20 AM | #4 | ||
1105
Rep 1,607
GT
12-04-2021, 08:38 AM | #5 |
Perennial PFC
336
Rep 1,274
I remember your post, in fact I had to look at the date on this one to make sure it wasn’t the same one! Oh, I might as well say it here, congratulations on the 1/4 mile time and speed you posted over in the M5 vs thread! That’s impressive! Have you been in the 9s before? Or at 140 either?
GTATX1105.00 |
12-04-2021, 09:12 AM | #6 | ||
273
Rep 647
Thanks for the answer thats a really good thing too know for anyone that has too loose those bolts. My car is going in to the dealership soon for exchange to a new gas tank because some baffles has come loose and is making noise i tell them to change out the bolts. |
12-04-2021, 09:15 AM | #7 | ||
273
Rep 647
12-04-2021, 12:35 PM | #8 | |
1105
Rep 1,607
GT
