Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > F30 Performance brakes in E92 335i
      10-10-2023, 09:19 AM   #2135
ottowerke
Drives: 2009 bmw 328i
I have a question that I have tried reading through the pages for the answer. Maybe I missed them?
I have a 2009 e90 328i. Recently got the m performance brembo front (370mm) and rear (345mm) with rotors.
Front is in, waiting to get the rear calipers back from machinist.
My question is: for the rear parking brake, do I need to put 335 rear parking brake since 328i has smaller parking brake? (to accommodate the 345mm rotors) If so, do I need to change the knuckle? Thank you in advance. Learned a lot from this thread
      11-29-2023, 12:24 AM   #2136
Seattlesquash
Car Enthusiast
Seattlesquash's Avatar
Drives: E92 328i 2007 SC
Basically just a 328 brake pad spring/seat attachment welded to a 335 brake shoe. Don’t know where my pictures are but I bet if you search something regarding 328/335 rear pad conversion I bet it will pull up. Or go back through the conversation. Good luck and you will love the setup.
Guess you can look for my posts. I definitely posted about it and just had a muffler shop cut and weld it for me. And I was not the first one to do it for sure.
E92 328i|6MT|ESS SC VT-1 (G.2)|3 stage|22 RPD SC/Meth tune|AA Headers|Snow Performance Meth Injection|Rotiform KPS|R139|PS4S 275.245.19|M3 front|M3 side skirts|MTEC rear|Akrapovic C tips|Koni Sport (Yellow)|Eibach PS|Hotchkis SB|C high-kick spoiler|C mirror Covers|C trim|LCI tails|M3 Control arms|M3 MS|Black E trim|Black kidney's|Full LED Conv|BMW F30 370/345 BBK|ECS SS|ECS Strut Tower Brace|034 Engine-Trans-Rear Mounts
      12-06-2023, 02:08 AM   #2137
Shredded
Drives: 2007 BMW 328i E90 Sedan
Anyone using 380mm front rotors with Apex Arc8-18x9.5 et22?
      12-06-2023, 01:27 PM   #2138
335i54n
317
Drives: e90 335i, e39 m5
no way, 370 is super tight for 18. 380 is standard 19 wheel rec
      12-06-2023, 03:04 PM   #2139
LMB335IS
Sua Sponte
LMB335IS's Avatar
Drives: 2013 LMB 335is
2013 BMW 335is  [8.84]
Not true. The M3/M4 came with a 18 inch wheel, the 513. I run them on my 335is with the 380mm rotors
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
Appreciate 2
335i54n317.00
BSM n54iS2684.50
      12-12-2023, 12:35 PM   #2140
Igor.v_a
29
Drives: BMW E92 330i, ESS Supercharger
I installed brakes on a Bmw E92 from a Bmw F82 380mm/370mm.
Tell me, is it necessary to install the brake master cylinder and vacuum brake booster from M3E92?
I currently have the master cylinder and vacuum booster installed from a 325i.
      12-12-2023, 01:16 PM   #2141
rbryantaz
Drives: 2007 E70 4.8i, 2008 E90 335i
2008 BMW 335i  [7.67]
2007 BMW X5 4.8i  [10.00]
Originally Posted by Igor.v_a View Post
I installed brakes on a Bmw E92 from a Bmw F82 380mm/380mm.
Looks nice.
The M3 master cylinder should be installed or you might not be pushing enough fluid for the larger brakes. The larger cylinder will also make the pedal more firm and require more effort to push.
I have e90 M3 brakes on my 335i and I didn't change the booster.
The booster is the amount of assist you get rather than the amount of fluid you move so it is optional. Some have said that the M3 and 335i booster are the same but they are a different part number so the M3 likely has a different amount of brake boost. The M3 booster may offer more assist to counter act the larger master cylinder which would increase pedal effort. Or they could have said "this is a performance car, the brake boost should be less and the driver should have to apply more effort than what a non performance minded driver would expect."
I wouldn't bother changing the booster unless you feel the pedal effort is too high. It should be higher than stock with the M3 master cyl given that it has to move more fluid in the same stroke. I haven't it to be too firm for me or my wife with the e90 M3 brakes and a regular non M booster. It seems fine to me without going through the hassle changing it.... I even have and M3 booster that came with the master cyl and didn't bother with it.
Does anyone know if the e90 M3 booster has more or less assist than the non-M??
The 335i and 325i seem to have the same booster.
-Rich
2007 E70 X5 4.8i with 10" android screen Running 265/60/18 AT34s All Terrains (Mainly for road trips)
2008 E90 335i with 10" android screen, 7" intercooler, inlets, Dinan intake, JB4 BEF, E85 conversion, Mfactory LSD, M3 suspension, EDC shocks with custom controller.
      12-12-2023, 01:21 PM   #2142
Igor.v_a
29
Originally Posted by rbryantaz View Post
Looks nice.
-Rich
The main brake cylinder for 325 and 335 is the same (one catalog number)
But vacum amplifiers are different.
      12-12-2023, 04:09 PM   #2143
rbryantaz
Is that "vacuum amplifier" difference mainly because of the turbo(s)?
It would need a check valve (and/or a pump), so that it holds vacuum under boost.
At least that is how other more simplistic turbo cars that I have owned work. I haven't looked that closely at my 335i actually.
Or do you just mean brake booster by "vacuum amplifier" I thought I checked the boosters and they were the same for hte 335/325.
-Rich
      12-12-2023, 04:58 PM   #2144
335i54n
317
i would, after upgrade it felt little softer and longer travel, m3 master only fixed it.
      12-12-2023, 11:26 PM   #2145
Igor.v_a
29
-Rich
I have an ESS supercharger installed and everything works great.
But, if it is possible to improve the braking system by installing a master cylinder and vacuum booster from the M3E92, I would like to do it.
I would like to understand whether it is worth doing this or not.
How much does this improve the braking system?
      12-13-2023, 12:45 AM   #2146
Seattlesquash
Car Enthusiast
I did the upgrade several years ago, and I did the M3 master too and recall that being strongly suggested. I may have bought with booster and replaced both. Great feel and been flawless since installed. Just remember to re-code to performance brake option.
      12-27-2023, 10:16 AM   #2147
Igor.v_a
29
Tell me where to get performance brake coding?
      12-27-2023, 03:47 PM   #2148
Seattlesquash
Car Enthusiast
Not a coding expert but you can do it yourself. Set to performance brake option, or take it to independent shop w scanner etc, what I did and paid like $50 and took 5 min + he coded out my bulb check as I did a full LED conversion and did not want to mess w any resistors.
      01-03-2024, 09:51 AM   #2149
wrevilo
45
Drives: 2010 E92 335i N55 6MT
I'll have to look into coding for my setup of the Fxx 340/345mm Brembos combined with an E9x M3 master cylinder. The initial bite isn't as strong nor the pedal as firm as stock, but the brakes are still very effective.
      05-01-2024, 11:39 AM   #2150
bshambam
bshambam's Avatar
198
Drives: bmw e91
Hey guys,
I'm about 90% done with this upgrade but I have my 2cents.
The rear brake conversion on specifically, the all wheel drive LCI rear hub is very tight, if not 'barely' fitting.
It looks as if there is a tighter tolerance between the emergency parking brake and the ears of the rear caliper. As such, fitting the Fxx rear caliper w/ an adaptor has much less tolerance and in fact, everything is a SNUG, SNUG fit. I have to use a rubber mallet to get the caliper into place.
I haven't run the car yet but the caliper ears now touch the parking brake backing plate.
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
