02-28-2016, 03:12 PM | #177 | |
European Editor
10642
Rep 22,992
Having a spare one or two coils on hand when doing your spark plugs isn't a bad idea as well. Maybe stop by your dealer and ask a tech or two their experiences about the coil packs sticking together to the plugs. I bet most dealers would have a set of coils in stock. Dack
09-28-2016, 04:16 PM | #178 |
9
Rep 49
I know, I know.. I'm resurrecting an old thread, but I wanted to find out if anyone has ever gone this route to get plugs. It's a good price, and the part number matches my 2010 128i, according to realoem.
https://www.amazon.com/BMW-Spark-Gen...MW+12122158253 I just flipped over 100K miles, and I have no idea if/when the last time the plugs were changed, as I bought the car used. I DO know that I'm well over the 40K miles mark sine I've owned it, and it's started to act funny when under acceleration (surges, hitches). I'm gonna change these and the fuel filter, and I'm hoping that clears it up.
My 1st BMW:
2010 128i / Completed mods: exhaust flapper disable/ Audio overhaul - Kenwood Excelon/ JLAudio XD600-6/ all new speakers/ More to come! Last edited by cpnbnanamn; 09-28-2016 at 07:14 PM.. |
10-01-2016, 09:05 AM | #179 | |
European Editor
10642
Rep 22,992
128i's have a 100K replacement interval. But I would probably replace them every 50K. 135i's have a 45K replacement interval. 30K(or even 25K) miles IF your tuned or are a 1M. It seems that only the turbo car are very sensitive to OE plugs. You could probably go with some NGK's and save a bunch on plugs. You might need some new coils - bc the old ones will probably break when you start tugging on them. Dack
ShocknAwe3244.50 |
10-01-2016, 05:59 PM | #180 | |
1Addict
3245
Rep 7,913
I have been using them since upping boost to 18-19psi (0.022) and they have definitely smoothed things out. Good thing to keep in mind with NGK (as opposed to OE BMW) is that the service interval is shorter, more in line with 15k lifespan, and gap should be checked every once in a while. The N54 is very sensitive to plug gap, things get wonky quick.
10-05-2016, 04:02 PM | #181 | |
9
Rep 49
Oh, and the one pictured, is the BEST of the 6!! -Roger
My 1st BMW:
2010 128i / Completed mods: exhaust flapper disable/ Audio overhaul - Kenwood Excelon/ JLAudio XD600-6/ all new speakers/ More to come! |
Dackelone10641.50 |
02-13-2017, 04:26 PM | #182 |
Loves his G20
265
Rep 2,507
Gonna replace my plugs this weekend I already got the BMS socket tool and the plugs are on the way from getbmwparts.com. Anything else I should look into? I'm not very mechanical or great with my hands. I can change the oil and replace a tire but my experience has been pretty limited. I did change out plugs on a 1990 325is when i was 17 but that was a real basic car.
Thanks.
2020 330ix-Msport Past- 2013 135i 2011 135i |
02-13-2017, 06:34 PM | #183 | |
32
Rep 209
Dackelone10641.50 |
02-13-2017, 07:33 PM | #184 |
4231
Rep 5,732
Drives: 2019 M2 Competition
02-14-2017, 04:01 PM | #185 | |
European Editor
10642
Rep 22,992
Don't use any anti seize on spark plug threads. Change the plugs on a cold engine. Use a torque wrench with a low scale calibration: 23Nm Before starting work... double check that you have the correct part number spark plugs. Quite a few people have gotten N54 plugs for a N55 motor. They are not interchangeable! Double check. Also... you might want to have a new spare coil pack on hand... incase one of your old coils breaks when removing. I used a six inch 1/2" extension inside the coil's "loop" pull tab as I slowly pulled up on the coil. Go slow... some of those coils are really stuck into those "holes". You can also use some dielectric grease(just a smidge) on the top of the plug where it snaps onto the coil pack. But I did not use any. Also having some 6mm allens or 6mm hex 1/4 sockets or bits might help in removing that one rear hex bolt that holds the fake valve cover on. Also have one of those telescoping magnetic tools for finding anything you drop down into the belly pan. And lastly... IF you can change your own oil... you can change your spark plugs. Its not hard. Btw... its almost time for me to change my plugs again too. I just bought a set of six coil packs from Oembimmerparts.com for $176 for the set of six coils. Just FYI. I didn't get any kickbacks... I just thought it was a good price on OEM factory coils. Now I just need a warm day to go work on my car in the garage. https://www.oembimmerparts.com/1-Ser...rts-s/2196.htm Good Luck, Dackel
kioneo31.50 |
02-14-2017, 04:14 PM | #186 |
4231
Rep 5,732
Was it foolhardy of me not to check the gap on BMW OE plugs?
02-14-2017, 04:19 PM | #187 | |
European Editor
10642
Rep 22,992
Dack
02-15-2017, 12:02 PM | #189 |
Loves his G20
265
Rep 2,507
Forgot to mention one of my neighbor's has one which he will let me borrow. Well I did not get an extra coil pack, I plan on being extra careful since I have read on here that they're delicate.
2020 330ix-Msport Past- 2013 135i 2011 135i Last edited by doublevanosrc; 02-15-2017 at 12:40 PM.. |
Dackelone10641.50 |
02-15-2017, 12:04 PM | #190 | |
Loves his G20
265
Rep 2,507
Thank you sir!
02-25-2017, 05:53 PM | #191 |
Loves his G20
265
Rep 2,507
Just finished changing out the spark plugs and the now the car is running lumpy. The SES light just came on, sounds like a misfire.
Just got error code P305 on the obdII scanner indicating a misfire on #5. I bet a million bucks its a bad coil, whos with me?
2020 330ix-Msport Past- 2013 135i 2011 135i Last edited by doublevanosrc; 02-25-2017 at 06:50 PM.. |
02-26-2017, 02:45 AM | #192 | |
European Editor
10642
Rep 22,992
Also make sure you have the correct spark plugs. Its common to get the wrong ones. N55 vs N54 plugs. Also check the flip top coil connector - it's easy to install the electrical connector wrong. Remove the connector and reinsert it. good luck Dack
02-27-2017, 03:15 PM | #194 |
18
Rep 99
Is there directions or video in how to change the Cabin Microfilter inside the box glove?
Used to own the eclipse (avatar pix).
Sold it and post it in memory |
02-27-2017, 03:53 PM | #196 | |
18
Rep 99
Oh, this is the long rectangular filter in that panel. So, there is no "air filter" inside the glove box to replace?
02-27-2017, 05:23 PM | #197 |
4231
Rep 5,732
mighty mouse doesn't know about the secret mini micro filter for the elves that live in the glove box...
MightyMouseTech4337.50 |
02-27-2017, 06:13 PM | #198 | |
European Editor
10642
Rep 22,992
