Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > CIC/NBT FSC Generator - Windows/Linux/OSX
      03-17-2019, 07:25 PM   #177
Jagaer
430
Drives: 2011 E91 328xi 6MT
RyanC1384
The headunit shouldn't let you start installing until you enter a valid FSC code. If you entered a code, and it started installing then the FSC code is valid and either the install was interrupted or corrupted.
If you put the installer USB back into the headunit, the system should continue installing where it left off.
Alternatively, check to see how much free space is left in your media partition. If it gives you a question mark on your hard drive, then the NBT headunit doesn't see your hard drive, which is a whole new set of questions.
      03-17-2019, 11:57 PM   #178
e91Owner
e91Owner
Drives: 2011 e91 & 2010 e60
Sorry to hijack this thread, but after no luck with the FSC generator, I purchased one online for $8 and it worked like a champ... until I tried to load the maps. I used a single USB stick for 2019 NA premium maps and at 88%, the I drive said that the “DVD” was unreadable.
My vin on the hex file came a 1234567 number vs the correct VIN, which explained why the FSC generator wouldn’t work; however, this is the stock CIC that came from the factory (9/09 2010 build). Is there a chance that this is just a bad map file or does the VIN has something to do with the USB not completing the map install?
Thanks!
      03-21-2019, 03:54 AM   #179
leeks
Drives: BMW 325i LCi
Jagaer do I need to generate separate codes if I have a 1-USB Europe Premium East/West Map 2019-1? They look like the full set, about 23.4Gb. In your FSC tool, I had the option to generate codes with 2019-1 and 2019-2. I wasn't sure if it meant that it is the code for 2 separate USB keys or is there a 2019-2 version somewhere out there.
Thank you in advance. Amazing tool.
      03-25-2019, 05:39 PM   #180
Jagaer
430
leeks
The generator uses a Lookup file to determine the information needed to make the FSC. It is possible that the 2019-2 information has been added to the Lookup, before the maps themselves have been released.
You will need to generate different FSCs for Europe East and Europe West, as they have different map codes (3E vs 38)
      03-26-2019, 11:55 AM   #181
QueenOfDarkness
QueenOfDarkness's Avatar
Latvia
Drives: 2010 E90 330D Sedan
Hello all!
Tried to update to BMW ROAD MAP EUROPE PREMIUM EAST 2019-1 but without success.
Seems like my problem is similar to many here with production time close to my car's trying to use portalseo's script.
My BMW E90 330D production date is 2009-10-29, script does the job but pulls out incorrect 1b 319 bytes without my VIN in the hex file (123456. 1234567.x.1234567).
My VIN is A738203 (WBAPR91000A738203).
Dear Jagaer , is it possible for you to fix this? I saw, that for someone it worked, after you edited the hex file.
At this time with this hex all generated FSC codes, of course, are incorrect, I tried. As well as, I tried some of the closest to my production date, also without success.
My 1b.hex pulled out using the script is in the attachment.
Thank you in advance!
File Type: zip 1b-A738203.zip (462 Bytes, 291 views)
      03-28-2019, 08:09 PM   #182
Jagaer
430
QueenOfDarkness It appears that PortalSEOs script does not work properly on early versions of CIC firmware.
The issue with the "123456" Serial Number is different than other people that had corrupted 1B files. Corrupt 1B files still have the correct information to generate an FSC, the "123456" Serial Number has a default key and will not create a valid FSC.
The only way to get your 1B file is either:
1. Get an ENET Cable, a certain USB/Ethernet Cable (ASIX Chipset) or ICOM to pull the 1B through FTP; or
2. Find a friend with an ICOM than can perform a firmware update on your CIC.
      03-29-2019, 06:33 AM   #183
chrisymarr
19
Drives: 318d
Hi All,
Apologies for the stupid question but just want to make sure before I do this that I don't break anything.
My 2007 E92 M3 has a CIC retrofitted and Navigation currently works, I bought it off ebay and never done anything to activate the Nav don't have an emulator attached and never provided my VIN for an FSC code, the CIC is running version C1A. As the Nav already works in the car I am assuming some form of script activation has been used by the previous owner - He did state the CIC was a retrofit in his car.
I retrofitted the combox to my car and apps worked until the car went to sleep now ConnectedDrive has reverted to BMW Services and I have lost apps.
Does anybody know do I need to remove the script activation from my CIC first before running this?
If so I am assume the only way to remove the script activation is via connecting to the CIC using FTP via ethernet as I don't have an ICOM cable. Is this correct?
As my car isn't prewired for ethernet as its an 07 is there another way to access the CIC or will I just have to wire the the OBD port to the CIC for ethernet?
Thanks
      04-01-2019, 01:44 AM   #184
leeks
Originally Posted by Jagaer View Post
leeks
@Jagaer Updated fine, turns out all it needed was the 2019-1 codes. I was confused if it thought the 2019 update was chopped into 2 parts. Turns out it is probably referring to a newer update called 2019-2.
Thanks for the tip
      04-06-2019, 06:30 AM   #185
kutluay345
Drives: bmw 320d
I update my cic premium (west europe 2019)unit by jagaer way.thanks
But Turkey map not detailed
Could anyone share Turkey premium torrent map?
      04-13-2019, 04:58 PM   #186
John Grey
Drives: BMW 328i
FSC CODE not working.. Help!
Hey Guys - I could use your help with getting my NAV active again. I was able to retrieve the 1b file via the glove-box. selected the file with the generator for the premium north america 2019 map. Code was generated fine. But NAV update says incorrect code. Can anyone help me resolve this problem? Thanks
      04-13-2019, 07:37 PM   #187
Jagaer
430
@John Grey - Can you post your 1B file? I'm going to guess that you have an early version of the CIC firmware, and your 1B file will show VIN 123456 instead of your actual VIN.
      04-15-2019, 07:46 AM   #188
John Grey
Drives: BMW 328i
Thumbs up
Thanks for your reply Jagaer - I've posted my 1b file for you to review. please let me know what you find.
Also you should know , the head unit was replaced with a used one from another vehicle. never got the NAV to work since. "my 328i vin ends with F346745"
File Type: zip john_grey_1b.zip (485 Bytes, 263 views)
      04-16-2019, 08:13 AM   #189
Jagaer
430
@John Gray,
Since the headunit is a retrofit, you may need to activate Nav using either an emulator or script activation. (Script Activation DIY: https://www.e90post.com/forums/showthread.php?t=1399746 )
I've amended your 1B with your VIN, instead of the donor's VIN...can't hurt to try.
File Type: zip 201210182249_F346745_001B0001_Decode.fsc.zip (497 Bytes, 224 views)
      04-17-2019, 11:48 PM   #190
leventince
Drives: BMW x5
Hi everyone,
I'm moving from Canada to Belgium this summer and will take my BMW x5 2015 with me.
A short explanation will be very appreciated regarding the update of the map since I will change the region (from NorthAmerica to West Europe). I think a simple map update (i.e. installing Europe NEXT 2019-1 ) will not be enough.
      04-17-2019, 11:50 PM   #191
leventince
Drives: BMW x5
Everything seems to be correct, the only other thing I can think of is if the vehicle is from a different region.
The CIC/NBT needs to be "activated" for a region of the world, then maps are "activated" for that region.
If the car was originally from a different region (Turkey, Egypt...), attempting to activate Europe maps will fail.
Other than that, I do not know why it would not work...
Hi everyone,
      04-18-2019, 08:24 AM   #192
John Grey
Drives: BMW 328i
@John Gray,
Hey Jagaer - thanks for taking the time to correct the 1b file for me. I've tried it but unfortunately with no luck. I'm no expert but will have to figure out this "https://www.e90post.com/forums/showthread.php?t=1399746"
option. Any pointers before I head down this rout. I've already purchased the k+DCAN cable, it's the one with a switch selector and limited instructions... which position should the switch be in for my 328i? Anyway wish me luck. lol
      04-22-2019, 11:57 AM   #193
teodorescu_cos
Drives: BMW E91
FSC code not working
Hello! I have a bmw e91 since 2009 and I can not get the FSC code.
now I have the European 2018-1 europe west premium and I want to put it European 2018-1 europe east.
Can you help me with the code? Atached is the 1b.hex file.
https://we.tl/t-Q3AGAnbvpm
Tanks.
      04-25-2019, 12:12 PM   #194
hpack
Drives: F31 2015 328D
New Links
Free download is now expired. Any way to get them reposted or an alternative location to download from?
      04-26-2019, 07:20 PM   #195
Jagaer
430
teodorescu_cos
For CIC (Premium Maps), Europe East and Europe West both use Map ID 0028, so you should be able to load either set of maps with your 1B and a valid FSC.
I am in North America, so I have never tried to switch between Europe East & West regions. I do know that you need a new FSC (or use Intel123's patcher) to switch between North America and Europe
      04-27-2019, 02:43 AM   #196
teodorescu_cos
Drives: BMW E91
I do not accept any code. FSC do not know what to do to change their maps. some idea?
      05-02-2019, 07:46 AM   #197
Shin3220
Drives: 320d
Hi, is it possible to crete an FSC code from the generator tool for the new EUROPE WEST Ruote 2019-2?
      05-04-2019, 10:09 AM   #198
fabietto77
fabietto77's Avatar
Drives: bmw f23
This is (hopefully) a more user-friendly CIC/NBT FSC Key Generator for Windows, Linux and OSX based off of the work of the original FSC Key Generator and Intel123's certificate Patcher.
Input Files
  • The Key Generator will auto-detect and accept either Base64 (Text) or binary FSC file inputs, as well as the file type (1B or NBT). (You can over-ride the detection setting, using the "CIC/NBT" radio buttons).
Support Files
  • The Key Generator will download and use the most recent copy of the BMW "Lookup.xml" file for key generation parameters. In Linux and Windows, this file is stored in the same directory as the Key Generator. For OSX, it is stored in ~/Downloads/
  • The RSAKeys.txt file keeps a copy all submitted RSA keys. The Generator will download and use the most recent copy of the file. In Linux and Windows, this file is stored in the same directory as the Key Generator. For OSX, it is stored in ~/Downloads/
Unsupported Feature
  • It appears that the key stored in the "FSC" file pulled from the car is not necessarily unique to the car, but may be shared across multiple cars built within a short time window.
As an example:
Code:
FSC Date	VIN Build Date			Days Difference
200910211749	Thursday, October 22, 2009	-1
201001271515	Thursday, January 28, 2010	-1
201004011026	Monday, April 04, 2011		-3
201006071536	Tuesday, June 08, 2010		-1
201107121301	Wednesday, July 13, 2011	-1
201110310756	Wednesday, November 02, 2011	-3
201201111004	Thursday, January 12, 2012	-1
201203301822	Monday, April 02, 2012		-4
201204181719	Wednesday, April 18, 2012	0
201205242316	Friday, May 25, 2012		-1
201210010521	Tuesday, October 02, 2012	-1
201210010703	Tuesday, October 02, 2012	-1
201210241654	Thursday, October 25, 2012	-1
201211081709	Friday, November 09, 2012	-1
201305140635	Wednesday, May 15, 2013		-1
201308142104	Friday, August 16, 2013		-2
201403071931	Monday, March 10, 2014		-3
201404091427	Thursday, April 10, 2014	-1
201404300545	Friday, May 02, 2014		-3
201406241001	Tuesday, June 24, 2014		0
201406241307	Tuesday, June 24, 2014		0
201409161938	Wednesday, September 17, 2014	-1
If you would like to help out, and have pulled your FSC file, please send me a copy. I will not include or publish any car-specific information, but will add the FSC file date and RSA key to the RSAKeys.txt file. Hopefully if enough are gathered, some people will be able to create an FSC for their car, without having to pull any files.
Links expire 26 May 19
  • Windows: https://ufile.io/pijyntbl
    Windows users must extract the file to a writeable directory (Desktop, Downloads, etc...), not run it from the zipped file. The generator needs to download support files (Lookup.xml and RSAKeys.txt) in order for it to run correctly.
  • Linux: https://ufile.io/9s3yzj9z
    Linux users must extract the file to a writeable directory (~/) and will need both QT5 and OpenSSL installed.
  • Linux Console: https://ufile.io/3ggt9mri
    Linux users must extract the file to a writeable directory (~/) and will need both QT5 and OpenSSL installed. Network not required.
    Code:
    Usage:  ./BMW_CIC_FSC_Generator_Console FILE.fsc TYPE [TYPE] YEAR [YEAR]
                    Example ./BMW_CIC_FSC_Generator_Console FILE.fsc 0x28 0x0A
            FILE.fsc - 319 byte hex OR BASE64 encoded version of hex
            TYPE     - 1 or 2 bytes representing the map type
                       If TYPE is two bytes, YEAR must be two bytes
            YEAR     - 1 or 2 bytes representing the map year
                       If YEAR is two bytes, TYPE must be two bytes
Code:
Version History
v1.9 - Add support for F0 Files.  NBT EVO Headunits which use NEXT style maps.
v1.02 - Allow Numerical First Digit for VIN.  Bug Identification & Explanation provided by txomin in post 71
v1.01 - Unhide "Lifetime" Checkbox
v1.0  - Initial Release
Hello
it is possible to have the fsc code for life for road map europe 2019-2
with frame v: 328514
thank you
