xDrive Suspension Compatibility List
12-31-2012, 02:35 PM | #177 | |
581
Rep 4,393
< Click picture for photoshoot
E90 335i xDrive 6spd, Nav, Prem, Cold Weather, & Sports package - Msport Conversion Mods: JB4 + MHD, Doc Race ST, Pure 6266, AD-Eng PI/Mounts, Fuel-It st. 3, Custom Exhaust, Tuned by TwistedTuning More Pictures: Build Thread /// 683AWHP/675AWTQ |
12-31-2012, 02:37 PM | #178 | |
196
Rep 6,136
12-31-2012, 02:42 PM | #179 |
581
Rep 4,393
I can gaurentee KW will honor the warranty and replace them if I have an issue. Coilovers are meant to be tracked not babied imo so I doubt that would prevent them from replacing them. I'd call it track use not abuse. I don't even know how many times they were brought to the track but if KW coils can't handle normal track use, they shouldn't even be considered high quality coils.
12-31-2012, 02:45 PM | #180 | |
196
Rep 6,136
12-31-2012, 02:50 PM | #181 |
581
Rep 4,393
Yea to each their own I guess. I can provide KW with the receipt from the original purchase and I doubt they would be that strict if something went wrong. They're an extremely reputable company known for great customer service so i'm not worried at all. My theory behind buying all used parts is as long as they're not broken buying someones parts that have 8k on them is no different from having parts on my car that I bought new and driving them past 8k. I love saving money wherever I can so I try to buy used whenever I find a good deal and save some $$. I should have a thread up with pics and thoughts after they get installed this weekend
01-01-2013, 09:35 AM | #182 |
28
Rep 488
Drives: 2008 335xi E90
If I'm not mistaken, the front one is missing its dust cover. Could this be a sign of excess wear or problem? How important are the dust covers?
01-01-2013, 12:49 PM | #183 | |
581
Rep 4,393
Edit: Did some googling and I know what your talking about. Isn't that the black thing under the bumpstop? I was also reading a lot of people reuse the oem dust covers?
E90 335i xDrive 6spd, Nav, Prem, Cold Weather, & Sports package - Msport Conversion Mods: JB4 + MHD, Doc Race ST, Pure 6266, AD-Eng PI/Mounts, Fuel-It st. 3, Custom Exhaust, Tuned by TwistedTuning More Pictures: Build Thread /// 683AWHP/675AWTQ Last edited by psmitty95; 01-01-2013 at 01:02 PM.. |
01-04-2013, 07:15 PM | #184 | |
28
Rep 488
01-05-2013, 11:43 AM | #185 |
581
Rep 4,393
Yea I checked with KW and it's not a big deal. They're like $10 so I ordered some new ones but i'm installing it anyway. They said theres no issue running without it for a while you just shouldn't do it for that long
01-07-2013, 10:57 AM | #186 |
11
Rep 58
so just double checking but when the list says BMW performance springs, you guys mean the Yellow springs correct?
cuz im on tischers website and there is no specification. also im planning on running the yellow springs on Bilstein HDs im not looking for a height drop but just more of a stiffer suspension. would the stock springs on HDs be good enough or would i feel more of a difference if i slapped the yellow springs on too? |
01-11-2013, 10:37 AM | #187 |
36
Rep 311
I would suggest that anyone changing out springs or struts to inspect the dust cover before you tear into it. Its a shame if you have to reinstall a torn boot just cause you don't have one.
Strut bellow part number: 31331094749 (not sure about LCI) Also do some research about front bump stops when buying lowering springs. Bilstein have internal bump stops, koni and stock struts need external bump stops. Koni does not supply them with their yellows. Some have been fine but I had to cut mine at the time of my eibach and koni install. I later tore it apart again to install shorter bump stops, I chose the e36 M3 (same as z3 m) as others have recommended. I wish I would have done some more research before and spared another 3 hours to tear the front suspension apart again. E36 m3 bump stop part number: 31332225377 |
03-25-2013, 05:17 PM | #189 |
dual Afe intake/ cobb/ forge dv's/ 94 oct.
11
Rep 309
i have 2008 335xi with sport package, looking at just replacing the springs with eibach ones, anyone on here that has done this? just like to get some feedback, thanks
03-26-2013, 05:33 PM | #191 |
11
Rep 309
http://www.lowriders.ca/2092-140-Pro-Kit-Performance-Springs-p/2092.140.htm do these fit on a 2008 335xi sedan with sport package, looking to keep the factory suspension with these springs, thank you
03-29-2013, 01:08 AM | #192 |
38
Rep 1,079
Has anyone changed out the rear rotors and calipers for the M3 variants? Hawk Blue brake pads aren't available for the 335.
2004 E46 M3 | Imola Red on Cinnamon | Slicktop | Manual Seats | 6spd MT |
07-12-2013, 12:49 PM | #193 |
681
Rep 3,696
Hi All,
So I read thru the first page and then jump to this last page. I was wondering if someone can summarize an upgrade path which would be best if you just wanted to do a full upgrade of the 2008 335xi e90 factory sport suspension? Things I've heard that we could do (But, I'm looking for what is the best path to get it all done at once and save on labor rates). I'm looking for a daily driver car and I hate how hard the ride is currently. I'm still running the square setup stock 17" rim and RFT tires, but I'm looking to switch out to 19" staggered. * E90 M3 suspension conversion --> e90 335xi? * KW v1/V3? * Camber Plates? * various springs/spring rates to consider? * Anything else you think I should ask/learn about while making my upgrade path Once all this is upgraded, would my alignment shop still try to align for the e90 sport setting on the machine or would they want to align for a different setting like the M3? I've also heard that the M3 tends to get a vibration at around 80 MPH which I would probably inherit? Currently, I'm at FBO performance wise ('08 335xi e90 sport, JB4 G5 integrated boost w/DP Fix @ 5 O'clock, BMS OCC, Full ER FMIC anodized black w/CF shroud, ER Charge pipe anodized black w Tial BOV VTA, and AR DP). Any suggestions on 19" wheel size/offsets that can be run in staggered to make the wheels flush (I'm thinking about running Michelin PSS in non-winter months and go back to style 162's in the winter with All season tires for snow). |
07-12-2013, 03:55 PM | #194 |
365
Rep 5,873
Drives: m
If there is anything I need to update in the first post please let me know, thanks.
07-18-2013, 03:20 PM | #195 | |
Quiet till poked
99
Rep 1,176
Anybody know the differences between the Street Comforts and the V1/V3? |
07-24-2013, 11:07 AM | #196 |
50
Rep 253
Hi guys.. I am new to the XI world. I just purchased a 06' 325xiT for my daily. Currently from the research I have gathered it looks like the best/most popular setup would be KW-V1 coils or Eibach Sport Springs w/Koni Sport Shocks? Im not sure if there is any other "cheaper" (ie. ST Coils, BC Coils, etc...) on the market yet?
I was also wanting to verify if there are any differences between the E90/92 suspension compared to the E91? Thanks in advance... Kyle
2018 Grigio Telesto Pearl Metallic/Amaro Brown /// F80 M3 ||| 2005 ZCP Schwarz II/Imolarot 6spd /// E46 M3 2024 Dravit Grey/Tartufo///M60i X5 ||| 2014 Alpinweiss Uni/Mokka X5 ///M Package (wifey) |
07-30-2013, 02:01 PM | #197 |
13
Rep 342
Drives: E90 Monaco Blue 335i xdrive
Hey just to let everyone know, if you don't know already, ISC Coilovers is already working on an XI fitment and will be out fairly soon.
2010 E90 335i xdrive | Monaco Blue with Black Interior | All Packages except Sport :/ | Apex EC-7 | Active Autowerke Strut Bar | Roc Euro DCI | Roc Euro Hyperboost DVs | aFe Scoops | BMW Performance Exhaust | BMWCCA member
